First Time Milling Cutter Issues Help Needed Please
Jamie Jones24/05/2014 21:49:29
39 forum posts
8 photos
First time Milling Issue Advice Please
Lined up some Steel in the Vice (25mm Thick) and trying tidy up the edges and straighten them up.
Using a 20mm End Mill with the advancing cutter blade facing the top of the work piece as it rotates.
Using the metric speed calculation Steel 100 x 100 = 10,000 / cutter size 20mm = RPM speed of 500
The edge being end milled is not level. The cut on the right is starting to address the un-evenness of the material. I have gently feed the cutter in... Too fast causes the cutter to smoke and jam. Trying a bit slower and there is very little in the way of a cut... Splinters...
I have then tried running along the work piece in a thinner cut, ie the left third with a view to tidying the end in three passes. ie 1/3rd in, 2/3rds in and the last being the whole width of the work piece.
But the second pass is not as deep as the first pass even though the cutter height has not changed. The head is locked off and the work piece is secure.....
I did expect that cuttings to be bigger than splinters from most of the youtube videos I have seen... Just not confident to force the cutter in any faster.. I have tried slowing the cutter speed down by 150 rpm incase it is tougher grade steel than I expected and also increasing it 150 rpm on the original speed.Without any effect...
Can anyone offer any advice?
Neil Wyatt24/05/2014 21:59:44
19226 forum posts
749 photos
86 articles
You'd be better having the steel plate clamped horizontally, packed up from the table. Even a 25mm plate has some flex, and that's a lot of leverage that will exploit any flexibility in the vice..
Mainly though, you are climb milling and the action of the cutter is tending to lift it out of the work, it will also tend to pull the work along in a series of jerks
Try reversing the direction of cut. and see what happens.
Jamie Jones24/05/2014 22:18:28
39 forum posts
8 photos
Hi Neil
Thanks for the advice.. The item is larger then my machines bed.. It had two sides that was at the correct 90' so I used them as a basis to try and straighten up the other two sides.. I was concerned that due to the work piece's size that I might not get a secure enough clamping ..... That is why I used the vice as it would push against the base... Is this wrong?
I will try cutting from the other direction tomorrow.... Is my speed correct for this subject matter?
Any other advice?
stan pearson 124/05/2014 22:30:09
135 forum posts
Hi Jamie
Yes Neil is correct you should always feed into the cutter never with it, your lucky it hasn't dug in and broke the end mill.
Stan
MattK25/05/2014 00:10:49
39 forum posts
7 photos
Are those 'scars' on the plate signs of the dig in of the cutter? I have a bigger mill so don't have first hand experience of how rigid these machines are, but you have three factors stacked against you, climb milling as mentioned earlier, not a very rigid setup (even with a thick plate I reckon these will be a few thou deflection on that much overhang once some cutter load is applied) and maybe quite a large cutter relative to the machine size?
I can see your dilemma though with a plate bigger than the table. Maybe you could clamp to the table with some thin card underneath by clamping across the edge you are trying to mill. Maybe need to carefully move the clamping rather than doing it in single passes.
Andrew Johnston25/05/2014 00:16:50
7061 forum posts
719 photos
A few random thoughts:
1. There's nothing wrong with climb milling, but possibly not suitable for the combination of small mill and big cutter..........
2. I agree with Neil, having the work waving in the breeze and using the side of the cutter is very likely to result in vibration and chatter, as suggested bolt the work to the table on a support, or bolt it vertically to an angle plate.
3. 500rpm is about right for a HSS cutter in low carbon steel, possibly a tiny bit fast, but does your mill have enough power to achieve a decent chip load per tooth at that speed? What feedrate are you using?
4. The cutter just doesn't look quite right, what is its provenance, import may be?
5. I'm not sure what sort of chuck the cutter is in but it seems a bit odd, I would have expected to see a collet, or similar, by the nut rather than an annular space between the nut and collet?
6. There's a lot of overhang in the cutter chuck and the cutter, so the cutter is deflecting when the second and third cuts are taken. It's a fact of life on any machine, so you need to allow for it with finishing cuts.
Jamie Jones25/05/2014 01:46:30
39 forum posts
8 photos
Hi Andrew
Thanks for the reply.
3, Feeding by hand on a slow rotation....... What's your view on the Mills Power? It has an RPM range of 50-2250.
The Mill's Spec is set out below: Plus Link (But without autofeed)
4, Cutters See Link: http://toolco.co.uk/pages/bakery/20-piece-end-mill--slot-drill-set-397.php
5, The cutter is in a collet: This is the collet set I have
6, Not sure what you mean. by 'There's a lot of overhang in the cutter chuck and the cutter'
I am only taking thin cuts at this stage.
I was hoping to mill out slots in this bit of plate so that it could hold specific bits of work that I had planned to bolt down on to its surface. At this stage I am not confident that the mill and the cutters are up to the job.. It is £ 2,000 work of mill
Here is the mills Spec:
Specification:
Max drill capacity: 32mm ( 1.25" )
Table size: 840 x 210mm ( 33 x 8.25" )
Table width: 210mm ( 8" )
Vertical travel: 370mm ( 15" )
Longitudinal travel of table: 565mm ( 22.25" )
Cross travel: 220mm ( 8.5" )
Spindle taper: No.3 MT
Spindle stroke: 70mm ( 2.75" )
Head swivels 90 deg
T - slot size: 14mm
Gearbox range x 2: High / Low
Range of spindle speeds: 50 - 2250rpm in two speed bands
Motor: 1.1kw
Standard Electrics: 240 volts 1 phase
Approx net weight: 240 kgs
Edited By JasonB on 25/05/2014 07:48:49
Ady125/05/2014 02:30:50
6137 forum posts
893 photos
You've got too much overhang, the cutting zone is far too far away from the vice and the milling cutter will create a levering effect
clamp the workpiece to the table, flat, with a support piece underneath to raise it from the table
Stiffness is priority one in a milling situation
 (as mentioned, you're also climb milling)
Edited By Ady1 on 25/05/2014 02:33:25
John C25/05/2014 06:03:44
273 forum posts
95 photos
Have you got the collet set up correctly? On my ER collets the front of the collet is flush with the front of the closing ring when tightened up. The collet has to be 'manipulated' into the closing ring, then the cutter inserted in the collet.
Rgds,
JasonB25/05/2014 07:41:38
Yes does look like the collet has not been snapped into the nut, have a look at this to see how they fit. Also makes them pop out of the body when the nut is undone.
If you clamp it to the table with half the work overhanging the edge of the table facing you there will be enough movement in the x-axis (side to side) to allow you to cut along one edge.
J
Oompa Lumpa25/05/2014 08:27:30
888 forum posts
36 photos
Take the setup apart;
1) Get the plate bolted down to the table as Jason suggests, flat and secure but packed up off the table with parallels or something solid at least.
2) get the head setup vertically.
3) set the collet fully into the collet nut and then put the cutter in.
4) don't climb mill until you have some more experience.
Your setup as illustrated is just so wrong I don't know where to begin but as everyone has said, there is room for error in every direction. Just with reference to your assumption that your setup "would press against the base of the vice" actually, you are "pressing" against fresh air, the cutter's action is edge to edge, not up and down.
I would suggest you get a bit of practice in with more forgiving materials before you take on something as challenging as this and this will give you a bit more experience of workholding.
graham.
Edited By Oompa Lumpa on 25/05/2014 08:32:46
MadMike25/05/2014 10:19:05
265 forum posts
4 photos
Jamie, all first class advice above. Where are you located? There is probably somebody close by who could come and help you with this. HTH.
Jamie Jones25/05/2014 11:14:30
39 forum posts
8 photos
I will re set everything up again this morning and have another go. Thanks for all the advice so far.
I am brand new to this.. Had tried to get a three day course to be better informed. But work won't let me the time off ...
i am based in Llandrindod Wells, Powys, Wales.... Which is a bit in the middle of nowhere. If someone was close by and could offer some advice to get me started I would most grateful. There is only so much that YouTube can show you. And I guess different machines have very different abilities.
Bazyle25/05/2014 11:46:56
6956 forum posts
229 photos
Don't rule out trimming the end of a plate like this in the lathe clamped onto the cross slide.. Sometimes it can be better as the distance between plate edge and table (cross slide) can be reduced to mm keeping it ridgid.
Nobby25/05/2014 12:16:25
587 forum posts
113 photos
Hi
Climb milling on a conventional mill is fraught with danger as there is backlash in the screw and you could end up with damage or injury On CNC machines its fine
Nobby
TomK25/05/2014 12:38:23
83 forum posts
23 photos
Jamie
There is some pictures in my album showing both set ups on how I milled a 8" x 6" 0.5" piece of gauge plate.
You have to get a rigid setup to mill it in the vertical but it can be done, I used 2 cubes an 2 angle plates bolted together. I very rarley use a vice when I milling parts I always try and clamp to the table or to angle plates or cubes
In the picture of the plate being cut the fly tool is held in a morse taper collet with drawbar this give a more rigid set up also more clearance cutter to table.
NJH25/05/2014 12:50:48
2314 forum posts
139 photos
Hi Jamie
Lots of good advice above but, anxious as I'm sure you are to get going with your new machine, I would advise just pausing for a bit and doing a little reading on the subject. There are a couple of little books in the "Workshop Practice" series which will give you lots of useful information and hopefully avoid damage to your work, your machine or, worst of all, yourself!
They are:-
Workshop Practice Series No2 - Vertical Milling in the Home Workshop by Arnold Throp
and
Workshop Practice Series No 49 - The Milling Machine by Harold Hall
( Harold is an ex editor of MEW , a helpful & knowledgeable guy, who also has a website with lots of info. and pictures of set-ups)
regards
Norman
Steve Withnell25/05/2014 13:33:19
858 forum posts
215 photos
I'd strongly support getting a copy of Harold Hall's book as per Norman's advice.
Personal opinion, but I think using a 20mm cutter to skim a 1 inch steel plate at one pass needs a big milling machine.
It's a bit like having a spade when you need a Caterpillar D8.
Steve
John McNamara25/05/2014 14:05:06
1377 forum posts
133 photos
Hi Jamie jones
Your setup is wrong.... Holding the plate vertically in a vice is just asking for the vibration gremlin to rear its head and spoil your work, the plate being so high off the table can lever the vice and the table bending it a few thou also taking up any looseness. If you have a dial indicator check how far you can move the top of the plate with this setup with hand pressure only. Also by rotating the head on your mill you are enhancing the vibration. The spiral teeth of the end mill will pull the work sideways until the resistance builds up in the system, at that point they will cut then the process starts again.... Vibration.
You need to clamp the plate to the table using packers as previously mentioned then cut it vertically.
Here is a photo
Today I was trimming the edges of some 6.35mm aluminium plates to size after sawing them from scrap. note the gap they are sitting on packers, you don't want to cut the table. You may notice there is another plate in front of the one being worked on... After clamping it in position I skimmed one edge with the mill providing a perfectly parallel edge stop to place my parts against. I got a good bright finish.
You should not just get dust chips when machining your part. Check your speeds and feed for the diameter of your cutter, For a light mill you will have to take it in steps down depending on the power you have available. start with a 3mm cut and work up from there.
Edited By John McNamara on 25/05/2014 14:15:18
Russell Eberhardt25/05/2014 14:30:47
2785 forum posts
87 photos
Another good book to get you started is Workshop Practice No.35, Milling a Complete Course. It takes you through the basics by a series of projects making useful accessories for the mill.
Russell.
