Martin Walsh 1 | 30/10/2013 16:01:36 |
113 forum posts 2 photos | Hi I was wondering if anyone knows of a supplier of 3/8 BSF 1/2 Long grub screws I need 2 for the myford s7 topslide locking screws have tried ebay but no luck thank you very much Martin |
Springbok | 30/10/2013 16:51:08 |
![]() 879 forum posts 34 photos | Martin, Please excuse the pun but will grub around in the workshop to see what I have. Edited By Springbok on 30/10/2013 16:56:38 |
Martin Walsh 1 | 30/10/2013 16:58:35 |
113 forum posts 2 photos | Thank you very much bob
Best Wishes Martin |
Lambton | 30/10/2013 17:06:39 |
![]() 694 forum posts 2 photos | Martin, Please confirm the size you require as 3/8 sounds too large for most Myford applications. Do you want them to replace the two square headed screw with half dog points which are 3/8 BSF item KA26? Eric
Martin Walsh 1 | 30/10/2013 17:15:11 |
113 forum posts 2 photos | Posted by Lambton on 30/10/2013 17:06:39:
Martin, Please confirm the size you require as 3/8 sounds too large for most Myford applications. Do you want them to replace the two square headed screw with half dog points which are 3/8 BSF item KA26? Eric yes that is correct Iam making the hemingway saddle chip tray and the original square screws foul it so heming way recommend to use the grub screws which are used on the newer machines Best Wishes Martin
Edited By Martin Walsh 1 on 30/10/2013 17:16:33 |
David Clark 1 | 30/10/2013 17:17:49 |
![]() 3357 forum posts 112 photos 10 articles | Try Ebay. regards David |
V8Eng | 30/10/2013 17:28:56 |
1826 forum posts 1 photos | Might be worth asking here. |
NJH | 30/10/2013 18:09:42 |
![]() 2314 forum posts 139 photos | As David says £4.15 for a pack of 10 on ebay. Just enter 3/8 BSF grub screw in the ebay search bar Norman Edited By NJH on 30/10/2013 18:11:44 |
JasonB | 30/10/2013 18:36:47 |
![]() 25215 forum posts 3105 photos 1 articles | Norman, the 1/2" long are out of stock from that seller |
Martin Walsh 1 | 30/10/2013 18:44:25 |
113 forum posts 2 photos | Posted by JasonB on 30/10/2013 18:36:47:
Norman, the 1/2" long are out of stock from that seller that's right he is the only seller as well. There is another seller that sells stainless 1 inch long grub screws so I suppose I could cut them to length Best Wishes Martin |
Trevor Drabble | 31/10/2013 00:49:07 |
![]() 339 forum posts 7 photos | Martin, May I suggest you try your local Cromwell Tools branch who list these as Socket Set Screws with Knurled Cup Point under part number CTL - 603 - 2728A at an offer price of £60.44 + VAT per 100 in my 2008 catalogue. In the past I have found them oust helpful and understanding in supplying smaller amounts. Hope this info helps. |
KWIL | 31/10/2013 09:30:01 |
3681 forum posts 70 photos | AHC of Camberley, Surrey for all your needs. Excellent stock of all old and new (ie Imp or Metric) threads and styles. 1 off if you like. |
Bubble | 31/10/2013 11:15:52 |
75 forum posts 6 photos | Martin Emkay supplies www.emkaysupplies.co.uk/ list 3/8" BSF x 1/2" at 0.83p each. First class firm, I would use no other, no connection to them except as satisfied customer! Jim |
Martin Walsh 1 | 31/10/2013 11:48:20 |
113 forum posts 2 photos | thanks for directing me to AHC they do have a excellent stock and I will use them in future they stock bsf bolts. unfortunately they don't stock 3/8 bsf grub screws I going to order from emkay supplies with a few other bits to make the order larger I didn't think it was a good idea in the end to cut 1 inch long ones down as they damage easily when holding them thanks to every one for replying it is very much appreciated Best Wishes Martin |
daveb | 31/10/2013 22:41:06 |
631 forum posts 14 photos | I shortened a pair of longer grub screws to replace the 'orrible square headed ones, the back one always finished up under the tail of the top slide, I kept having to use the end of a 1/2" socket extension bar to get at it, very annoying! I wrapped a bit of copper shim around the grub screws and held them in the 3 jaw chuck, shortened them by 1/4" and turned the dog point using HSS tool, job took less than 5 minutes. Dave |
NJH | 02/11/2013 12:54:33 |
![]() 2314 forum posts 139 photos | Well, prompted by this thread - and with the memory of the contortions needed to get at the right hand locking screw under the top slide - I whizzed off an email order to Emkay Screws on Thursday evening. Delivered by postie at 09.30 today and fitted PDQ. Perfect! The question is though why did Myford stick with the square headed, hard to get a spanner on, screws for so long? Norman
JasonB | 02/11/2013 13:03:27 |
![]() 25215 forum posts 3105 photos 1 articles | Maybe they had a big box full to use up |
Martin Walsh 1 | 02/11/2013 13:59:32 |
113 forum posts 2 photos | Its a breeze now with a 3/16 Hex screwdriver nothing gets in the way I think Myford put them on their newer Machines when they run out of the square ones
Best Wishes Martin Edited By Martin Walsh 1 on 02/11/2013 14:01:23 |
John C | 03/11/2013 02:39:30 |
273 forum posts 95 photos | Thanks for the lead to EmKay Supplies. I ordered Thurs after work, the screws arrived Sat am! Very good service and well priced. No connection etc, just a satisfied customer, John |
