Here is a list of all the postings Martin Walsh 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Sieg C0 alignment |
13/10/2015 21:01:46 |
Posted by John W1 on 12/10/2015 11:09:59:
Sounds clear enough to me. Turned brass 3/8 dia by 30mm long and found he had a taper of 0.0025. First question - if you leave the same cut set and keep running the tool along several times does the taper reduce? Use slow feed. John - Edited By John W1 on 12/10/2015 11:10:18 Sorry for the late reply havent been around that is exactly the problem thank you will try that and the other suggestions Best Wishes Martin
11/10/2015 22:12:30 |
Hi I have just purchased a used sieg c0 micro lathe the problem I have got when I turn 3/8 dia brass rod to a length of 30mm just taking a light cut it is 2 and a 1/2 Thou out which I think is excessive. could someone please advise me how to cure this Thanks in advance Martin
Thread: unimat 3 automatic feed question |
10/11/2014 11:48:17 |
Thanks for that best wishes Martin |
10/11/2014 00:02:45 |
Hi I have been looking for the automatic longitude feed accessory for the unimat 3 they seem to be as rare as hens teeth I was wondering if the one for the sieg c0 will fit on the unimat 3 thanks in advance Best wishes Martin |
Thread: warco 6x4 band saw Blades |
25/08/2014 15:21:05 |
Hello I have a warco 6x4 band saw and what a useful piece of kit it is I want to get some good quality blades for it could you please recommend some thanks in advance
Martin |
Thread: What did you do today? (2014) |
25/08/2014 15:01:27 |
I have been machining some heavy duty angle iron from the scrap bin on the shaper to make my own angle plates
Best Wishes Martin |
Thread: Outstanding Service |
05/08/2014 13:29:09 |
Posted by CoalBurner on 05/08/2014 12:17:37:
Another thumbs up for Tracytools, ordered some taps yesterday afternoon, arrived with this mornings post, on their standard delivery - now why can't all suppliers be this efficient Graeme
I second that tracy tools are a excellent company to deal with I ordered some taps from them. The parcel got lost in the post when I phoned them to say that it didn't arrive they sent another one straight away Excellent service Best Wishes Martin
Thread: The Tool you cannot do without |
04/07/2014 13:07:14 |
Posted by mike T on 03/07/2014 14:16:05:
If I were to start all over again, the first machine tool I would buy would be a good metal cutting band saw. Then the mill and lathe.
I totally agree The thought of cutting 2inch dia bar with a hacksaw makes the cost of a bandsaw a very worthwhile Investment Best Wishes Martin
26/06/2014 21:21:26 |
I ordered some taps and dies from Tracy tools unfortunately they got lost in the post they sent me another lot straight away great service from a excellent company
Thread: Testing Safety Valves |
16/06/2014 23:09:26 |
Hello What is the best way of setting the pressure of a safety valve I have made a couple to use on a mamod type of boiler so low pressures involved
Best Wishes Martin
Thread: Drilling Holes in copper tube |
07/06/2014 13:50:40 |
Hi I'm making a small boiler 2 Inches dia and I need to drill 3 holes 3/8 dia what is the best way to do this. As I have heard drilling holes in copper is a nightmare Thanks
Best Wishes Martin
Thread: Smaller parting blades in dedicated toolholder? |
05/05/2014 09:49:33 |
Posted by John Billard on 01/05/2014 09:57:20:
I have used a hacksaw blade suitably ground in a slotted holder I made. Just the job for smaller work especially brass fittings etc. It is easily reground and even in the event of breakage it only takes a minute or so to sort out. Best wishes John B
Same here I find hacksaw blades make very good parting tools with a suitable slotted holder. Cheap as chips as well I keep all my broken or worn out blades now
Best Wishes Martin
Thread: Who makes miniature imperial combination or open end spanners ? |
29/04/2014 07:45:47 |
king dick make small imperial spanners they are also the highest quality
29/04/2014 07:18:37 |
Try these www.baconsdozen.co.uk they sell small size imperial spanners
Best Wishes Martin Edited By Martin Walsh 1 on 29/04/2014 07:19:30 |
Thread: Spirit fired boiler |
27/04/2014 12:28:50 |
Hi I have some 2 Inch dia 16 gauge copper tubing 5 Inchs long would it be ok to make a spirit fired boiler from this or is the dia too big to get enough heat Also I have some 2 1/2 dia brass if I turned it down and made a shoulder could this be used for the end caps ok. sorry to ask so many questions But would soft solder be ok or is silver solder the way to go
Thank You Best Wishes Martin
Edited By Martin Walsh 1 on 27/04/2014 12:29:38 Edited By Martin Walsh 1 on 27/04/2014 12:30:11 |
Thread: Drill, Tap and Thread Size Chart |
26/04/2014 08:29:50 |
I always use the zeus reference book but there are lots of charts to download on the net then laminate it to protect it
Thread: meddings |
18/04/2014 07:23:51 |
Hi Mike Another place worth a Try is the tap and die company www.tapdie.com 0208 888 1865 He is a helpful chap Best Wishes Martin
17/04/2014 22:46:54 |
Contact Tracy Tools 01803 328 603 they might be able to help you ?
Best Wishes Martin Edited By Martin Walsh 1 on 17/04/2014 22:49:16 |
Thread: machine Installation service |
15/04/2014 19:15:45 |
I had a email from warco and they said they could deliver the machine complete as long as the access was easy which it is its a garage on the side of the house with a drive and it would be a special delivery for 180 + vat which I thought was resonable Best Wishes Martin Edited By Martin Walsh 1 on 15/04/2014 19:16:29 Edited By Martin Walsh 1 on 15/04/2014 19:18:11 |
14/04/2014 17:10:03 |
Just finished off the Hemmingway chip tray for the super 7 Best Wishes Martin Edited By JasonB on 14/04/2014 17:11:17 |
