wolrikm | 25/09/2013 14:09:40 |
36 forum posts 1 photos | A piece of spring steel literally fell off the back of a lorry outside my house. Part of the leaf spring suspension broke as he went over the hump in the road and it slid along the road as the lorry disappeared into the distance. It's a good job it wasn't school time, as the 'sleeping policeman' is on the school crossing. Is this sort of steel any use? It's about 3" wide by 5/8" thick and a couple of feet in length. Can't think of anything I would want to use it for, and no way for me to machine it, other than with a handheld grinder. Martin. |
jason udall | 25/09/2013 17:14:56 |
2032 forum posts 41 photos | Cross bow? |
jason udall | 25/09/2013 17:19:19 |
2032 forum posts 41 photos | But seriously.. Thats hicarbon steel. To do much with it you will need to anneal it first..cut off what you need . Heat to red heat for a time..hours..allow to cool slowly ..hours..process as needed..heat harden and temper to taste |
wolrikm | 25/09/2013 17:54:03 |
36 forum posts 1 photos | So, chuck it in the scrap bin then? Or in my case, put it back out in the street and the gentlemen with the old Transit pickup will take it in the morning, no questions asked. Martin. |
Michael Gilligan | 25/09/2013 17:58:15 |
![]() 23121 forum posts 1360 photos | Martin, I have a similar item [slightly curved and nicely tapered in thickness], obtained in similar circumstances. Haven't yet found anything to make from it; but it does come in very useful as a crowbar for paving slabs and bits of machinery. MichaelG. |
Bubble | 25/09/2013 20:21:19 |
75 forum posts 6 photos | Hi all Google "Taperlite" spring used on lorries and railway wagons We fatigue tested them in BR Research years ago Jim |
JohnF | 25/09/2013 22:01:42 |
![]() 1243 forum posts 202 photos | Martin, I would keep it as Jason suggests cut into bite size chunks and anneal, it will be a high grade carbon steel with many uses. Don't know where you are but wish I was close I would anneal it for you. Don't waste a windfall! John |
jason udall | 26/09/2013 00:07:23 |
2032 forum posts 41 photos | we are all ignoring the comedy potential..."Excuse me Mr. truck driver,,Should this be attached somewhere ?"..... |
Ady1 | 26/09/2013 00:12:04 |
![]() 6137 forum posts 893 photos | I've got one A crowbar or a crossbow ! |
wolrikm | 26/09/2013 08:39:37 |
36 forum posts 1 photos | I don't see it being any good to me, so if anyone is passing M62 J31 sometime, you're welcome to it. Martin. |
Bazyle | 26/09/2013 09:19:39 |
![]() 6956 forum posts 229 photos | Some people have all the luck - then want to throw it away! In most of Africa that would be quickly turned into a panga (machete). Failing a model engineer your local blacksmith will be interested. Virtually worthless as scrap it gold (well quite nice steel) in the right hands. You could always bring it along with you this weekend to the St Albans Model Engineering Society show and put it on the tools shop, |
colin hawes | 26/09/2013 09:36:07 |
570 forum posts 18 photos | I obtained a broken leaf spring many years ago;it has made various fine cutters and press tools. Colin |
wolrikm | 26/09/2013 09:59:02 |
36 forum posts 1 photos | Colin, I wouldn't know what to do with it without a forge, and I don't have room for one. I worked with the blacksmiths for a number of years when I worked as a welder at t'pit and used to love using the steam hammer. Bazyle, I am in Yorkshire, but by coincidence I will be in St Albans Friday/Saturday, so I will pay a visit to the show and bring it with me. Look for a little bald chap with a grey beard, specs, and black denim Wrangler jacket and jeans, and ask the correct question, ('eyup, is thy from Yorkshire?) then you can claim your prize. (I thought I better add the bit about the black Wranglers as model engineer shows usually have plenty of little bald men with grey beards and specs.) Seriously, if you want the piece of spring, and we do make it down there, you are welcome to it. Martin.
Speedy Builder5 | 26/09/2013 11:36:59 |
2878 forum posts 248 photos | They make good planishing irons for car bodywork, cut them down with an angle grinder / cutting blade. I put a thin cutting disk in my bench mounted circular saw and use it for cutting tough steel. Watch out for max permitted revs etc and make sure there is not too much sawdust to catch fire. Check for fire ignition before you shut the workshop up for the night. Bob H |
richardandtracy | 26/09/2013 11:37:37 |
![]() 943 forum posts 10 photos | A friend of mine many years ago had a knife forged from a truck leaf spring. It was only later that he found out the truck driver didn't know it was being removed. This was in Kano in Nigeria, and that sort of thing was not uncommon at the time (early 1980's). The knife held an edge very well. Regards,
Richard.
Martin Walsh 1 | 26/09/2013 14:29:01 |
113 forum posts 2 photos | Posted by wolrikm on 25/09/2013 17:54:03:
You could use it as a door stop or a heavy duty paper weight
Kind regards Martin |
daveb | 28/09/2013 00:05:27 |
631 forum posts 14 photos | Go outside and wait for the lorry to go past again, gather up the wheels, half shafts and differential. Lots of useful bits there! |
Clive Hartland | 28/09/2013 07:57:46 |
![]() 2929 forum posts 41 photos | Needless to say that when the chap who lost the spring piece goes for MOT he will be very surprised to FAIL it! He will wonder where he lost it so place an advert in the local paper advertising a return for a reward! Clive |
