a viable alternative technique ?
ken king, King Design | 10/08/2013 00:48:32 |
![]() 144 forum posts 239 photos | Does anyone out there have experience of honing small bores ? Can you recommend suppliers of various grade stones, from rapid metal removal to polishing? So far I've come across Sunnen, a Swiss company who trade worldwide. I'm calling their U.K. office on Monday next, but would like to know of others, and discuss the relative merits/problems/costs of the technique. Can you contribute ? |
Bill Pudney | 10/08/2013 02:50:03 |
622 forum posts 24 photos | Ramon "Tug" Wilson did a really good thread on lapping small, under 20mm diameter bore on another site, its probably non PC to mention it here, but it deals with model engine making. It basically demonstrated how to produce a suitable adjustable lap, how to use it, and the grit to use. Very, very interesting. cheers Bill Edited By Bill Pudney on 10/08/2013 02:50:31 Edited By Bill Pudney on 10/08/2013 02:51:06 |
JasonB | 10/08/2013 07:33:16 |
![]() 25215 forum posts 3105 photos 1 articles | I think Ramons Lapping article is due for publication in ME, it does touch on honing but lapping may be more appropriate for a small bore such as an aero engine.
J |
Ian S C | 10/08/2013 11:44:38 |
![]() 7468 forum posts 230 photos | JasonB, I agree that lapping would in my oppinion be the way to go. Ian S C |
Stub Mandrel | 10/08/2013 15:45:09 |
![]() 4318 forum posts 291 photos 1 articles | What's the bore for? If reaming is adequate for teh job, why replace a simple, rapid operation with a fiddly, slow one? Neil |
ken king, King Design | 10/08/2013 18:58:27 |
![]() 144 forum posts 239 photos | Well Stub, my interest stems from recent unhappy experiences with reaming 1" bores. I'm awaiting more info but I think there are some preconceived notions of what can or can't be achieved with honing, and that it may prove to be a suprisingly versatile technique, capable of either rapid metal removal or very fine finishing. As I learn more I'll post it here for all to absorb. Here's another question to test understanding:- What's the difference between honing and lapping, or is each an extension of the other (do they in fact overlap - ouch, sorry), Regards to all, Ken. |
JasonB | 10/08/2013 19:07:17 |
![]() 25215 forum posts 3105 photos 1 articles | Again a lot bepends on what you are trying to do with the hone, yes it will give a good finish subject to the grit of the stones but if you are using the common brake cylinder hones then they won't true the bore like lapping will. Also a hone does not match a piston to a liner, once you get down to lapping the piston into the bore at 1000g you get a better fit than trying to use internal and external hones to acheive the same fit. So a honed surface may be OK for a piston that will have rings but if you are running a ringless piston in a compression diesel or glow engine then it sbetter to lap one to the other. There is a bit of lapping in my Firefly thread, though Ramon goes into far better detail. |
Michael Gilligan | 10/08/2013 19:20:17 |
![]() 23121 forum posts 1360 photos |
Posted by ken king on 10/08/2013 18:58:27:
Here's another question to test understanding:- What's the difference between honing and lapping, or is each an extension of the other (do they in fact overlap - ouch, sorry), Regards to all, Ken. . If I recall correctly: Honing involves the use of hard abrasive stones, typically more than one, mounted on a mandrel ... and finishes to a preset size. Lapping involves a relatively soft "plug" loaded with abrasive paste ... and the finished size is therefore perhaps less predictable. Just to confuse matters: one of the classic Honing machines is made by Delapena.
MichaelG. |
Russell Eberhardt | 10/08/2013 19:32:39 |
![]() 2785 forum posts 87 photos | I don't know what size cylinder you're talking about but I've found one of these works well. Russell. |
Clive Hartland | 10/08/2013 20:07:06 |
![]() 2929 forum posts 41 photos | Reaming as against honing/lapping, the reamer brings a hole to a set size and depending on the quality of the reamer and the amount of metal removed gives a parallel hole with a good finish suitable for most engineering purposes. Honing/lapping is used to bring a bore to a size so that a pre-made item (Piston) will fit with the correct clearance. Lapping is used to produce a very fine surface for rotary or longitudinal motion, again as in a model diesel motor. Automotive honing has an automatic system (Sunrod) where the bore size is dialled in and away it goes until that size is reached. The spiralling motion of about 45 deg. suits the bedding in of the rings on the piston. In fact the bore when viewed is quite visibly marked. The bore, if badly worn can be bored to a set size and then is honed to tolerance. In all, 4 cyl. can take about 40 mins. with a bore size of 3" to 4". For most modelling applications anything up to half inch is OK to ream, above that as the clearances increase then lapping can be used. Not always, as it can be difficult to hone or lap a large dia. hole of limited width so other methods are better. making small spindles in a steel mount I allowed 1/100 mm for 10/15mm dia. This being a hand turned operating knob where any slackness would show up in the optical measuring system. Clive |
JohnF | 10/08/2013 22:57:48 |
![]() 1243 forum posts 202 photos | Hi Ken K, I have used both Delapena and Sunnen hones, mostly Delapena who are in Gloucestershire I think. Personally I have found little to choose between them and most of the tooling is interchangeable. You can get permanent or disposable mandrels, small sizes are always disposable because there is no possibility to fit wear shoes. If you PM me with your email I can send you a PDF of both companies brochures. Stock removal is relatively slow compared to other methods of machining but it depends on size, material and length of the hole as to haw fast you can remove metal. I feel sure the machines Gray is talking about are modern and more sophisticated than my old Sunnen honing machine which is about 60 years old I think but the principal is the same except there is nothing to preset or control the finished size other than experience. Hope this helps John. |
Hopper | 11/08/2013 02:20:48 |
![]() 7881 forum posts 397 photos |
Well Stub, my interest stems from recent unhappy experiences with reaming 1" bores. What was the problem you encountered with reaming? In what application? Reaming is going to be a much more rapid metal removal method than honing. Honing is essentially a finishing technique. Couple of things that make reaming go better include drill the hole undersize first, then bore the hole to within 5-10 thou of finish size. Boring gives a straight, concentric hole for the reamer to then follow. Machine reamer, or at least a fixed hand reamer, will more easily give a good result than an adjustable hand reamer. If I have to use an adjustable hand reamer, I will bore to within a couple of thou, then ream, then take the last half to one thou out with a brake cylinder hone. If you are reaming brass, a worn old reamer actually works best. A new sharp reamer will dig in. Running a small oilstone over the cutting edges of a new reamer will dull them enough to work well on brass/bronze. |
Stub Mandrel | 11/08/2013 09:49:46 |
![]() 4318 forum posts 291 photos 1 articles | I would ream bearing holes, but hone or lap the bore of an internal combustion engine. What application are you looking at now? Neil |
ken king, King Design | 11/08/2013 12:00:47 |
![]() 144 forum posts 239 photos | To complete the picture, my particular problem arose when trying to ream 1inch diameter steam engine cylinders. I have bored them to within a couple of thou, with a very nice, uniform finish. I was using a brand new hand reamer, not an adjustable, and the first bore reamed ok., though not as good as I'd hoped The second was a disaster, with the reamer digging in and jumping from one tooth to the next, six jumps per rev, equal to number of flutes. I never thought of dulling the tool edges; that's kind of counter-intuitive isn't it ? Maybe that would be the answer, but why didn't the effect arise with the first cylinder ? I'm reluctant to put the reamer anywhere near the third and final bore, I think understandably, and that's why I started thinking about other means of improving the surface finish from fine boring to polished. |
Stub Mandrel | 11/08/2013 12:31:44 |
![]() 4318 forum posts 291 photos 1 articles | For steam cylinders, I would either accept a really good bored finish, or hone lightly with very fine grade wet and dry or used emery paper oiled and wrapped around a stick. A polished finish can be counter-productive inm a steamer as it doesn't hold oil. Neil |
Michael Gilligan | 11/08/2013 12:49:00 |
Posted by ken king on 11/08/2013 12:00:47:
To complete the picture, my particular problem arose when trying to ream 1inch diameter steam engine cylinders. I have bored them to within a couple of thou, with a very nice, uniform finish. I was using a brand new hand reamer, not an adjustable, and the first bore reamed ok., though not as good as I'd hoped The second was a disaster, with the reamer digging in and jumping from one tooth to the next, six jumps per rev, equal to number of flutes. I never thought of dulling the tool edges; that's kind of counter-intuitive isn't it ? Maybe that would be the answer, but why didn't the effect arise with the first cylinder ? . Ken, Attempting to answer these points
MichaelG. |
JasonB | 11/08/2013 12:51:16 |
![]() 25215 forum posts 3105 photos 1 articles | Whats the material you are cutting and what are you using as packing or rings, Iron rings in an iron bore will be better suited to a honed finish. O rings in a gunmetal casting will want lapping if they are to last.
J |
Norman Lorton | 11/08/2013 14:17:55 |
31 forum posts 6 photos | I think I know where Ken is coming from as I had the same questions a couple of years ago. The question breaks down into getting a) an accurate bore of correct diameter, and b) a suitable surface finish. I would add a new variable in that striving for either the bore or finish can give an incorrect bore profile, especially a 'barrel' with a larger bore in the centre or a 'flare' with larger diameters at the outsides. I think this is the hardest error to correct for. A reamer gives a good parallel bore of true diameter, up to perhaps 1" in non-professional hands, but the finish might be messy, as Ken says. I find that a flap of emery or wet and dry paper, held in a small wooden split stick, can produce excellent finishes, working from 200-1000 grit with plenty of paraffin or WD40 to wash away material. The job rotates in the lathe at a few hundred RPM and the stick is carefully moved in and out to avoid any creation of the barrel effect. Problem is it also enlarges the bore by 0.0005" or more. Honing (using stones held on a frame) is obviously a superb technique in the professional machines described above as the bore is enlarged from its rough cut by a few thou and the finish of cross honing is perfect for cast iron rings in a cast iron bore, and parallelism is maintained. But, it is most suitable for bores of 2" diameter and upwards. I have seen sets of small hones at the ME Shows and wander what success people have had with them? I did some web research and lapping (grinding paste on soft mandrels) is the described technique for getting accurate bores of suitable finish. I wanted to make some bronze bushes in which would run stainless pushers of diameter 0.8749 - 0.8750. The bushes were 1" long and the differential thermal coefficients of expansion (appx. 0.001" between stainless and bronze over 100 degC) meant careful measuring at a fixed temperature. I bored the bushes to 0.8735 - 0.8740 and then lapped them in the lathe using a home made mandrel with an aluminium body of nominal 0.8730 diameter and an end taper wedge to progressively enlarge it from the centre. The mandrel was designed to enlarge as a slight barrel, so as to counter the effect of it producing a 'flared' bore diameter increase in use. Diamond pastes, plus light oil, starting at 40 micron (400 grit) would remove a thou in 60 seconds. 14 and 5 micron then produced near polished surfaces. Absolutely thorough washing before measuring or changing pastes was essential. Lapping this way produced bores that were so close in diameter to the stainless pushers that they were locked solid at 15 degC, just moved at 25 degC, and slid like glass at 35 degC. If it is an iron piston in an iron barrel one will not see this temperature effect. I have no professional training but taught myself, so make a mandrel lap Ken and have a try! PM me for more if you wish as I have said far too much in this reply and will have bored too many. |
Norman Lorton | 11/08/2013 17:05:10 |
31 forum posts 6 photos | Search also for "Honing bronze cylinder bores" in the search keyword box above as this topic was covered in January 2012. |
Ian S C | 12/08/2013 13:45:18 |
![]() 7468 forum posts 230 photos | on some of my hot air engines I have used a lap made of wood, and charged with grinding paste. The woden cylinder is split length wise, and a wood screw, or wooden wedgeis put in the open end of the split. The lap is held in the chuck of the lathe, and run at a moderately low speed, while the cylinder being lapped is moved back and forth by hand. This is one of the only places I wear a glove, there is a bit of torque, but the work gets quite warm, it's a job that takes time. Ian S C |
