Where to buy
Ossie | 16/07/2013 20:14:07 |
15 forum posts 11 photos | Hello all I have a few carbide tipped cutting tools which now need sharpening, I read that you need a green grinding wheel which I bought from RGD tools on eBay. After fitting the wheel to my grinder the vibration was horrendous and not running true, I only have a cheap grinder and it has always run really smooth. What I would like to know from the experienced model makers is do I buy another green wheel or do I get another grinder that comes fitted with green wheels if that's possible if so could someone point me in the direction of a shop or website where I can purchase one. I am quite a new lathe user and have some HSS tools and some carbide tipped tools. Any advice would be greatly appreciated Many thanks Dave. |
jason udall | 16/07/2013 20:31:17 |
2032 forum posts 41 photos | Firstly.. Green or otherwise wheels need to be trued..to attain the balance required for smooth operation.. The wheel would have been suplied with plastic bushes to get the wheel mostly centered on the grinder spindle. .any eccentricity will throw the spindle out of balance and cause the vibration you see. It is an important safety matter that these are used. .also old hands used to "ring" wheela before fitting..hang wheel on pin and light tap with a mallet a good wheel rings like a bell and a dull thud would cause the wheel to be rejected. .l am no expert but I treat grinding wheels with some caution. Any way as to green wheels for carbide. .Diamond wheels seem to be the way to go here. .run true out off the box , no truing requires during use and cut much better/flatter..over to others for futher suggestions |
John Stevenson | 16/07/2013 20:34:23 |
![]() 5068 forum posts 3 photos | Green grit is old hat now.
Move on to diamond. |
John Widger | 16/07/2013 20:51:13 |
1 forum posts | Hi dave, You say your wheeel is not running true, this is the problem, as it needs dressing to bring it true this should stop all the vibration. I use a single point diamond dresser (Arc-Eurotrade £10) . Place the diamond on the rest, so it lays flat supporting the weight in the Right hand, place the Left hand flat on top of the diamond, and roll it across the face of the wheel, keeping it flat on the rest.( It would be best to practice this action a few times without the grinder running to get the feel of it.). Move the Diamond in slightly, and repeat, a few small passes are better than 1 big one. The vibration should reduce as you dress the wheel, until it cleans up all the way round. Use Appropriate safety equipment, and cover any machinery to prevent ingress of the dust. Hope this helps John |
maurice bennie | 16/07/2013 21:07:17 |
164 forum posts 1 photos | Hi Ossie as you have now bought a wheel look on internet for GRINDING WHEEL DRESSER get a bar one not a single stone one. GENTLY feed the dresser ,holding square on the rest so that it just brushes the wheel until the re is no vibration. Do check ,as previously mentioned, that the centre has the spacer fitted'properly and the cardboard washers are fitted each side of the wheel. Good luck Maurice |
Ossie | 16/07/2013 22:06:26 |
15 forum posts 11 photos | Thanks for the good responses, so what I am learning is a diamond wheel is the way to go, but any wheel could need dressing to make it run true. Are there various qualities of diamond wheel as I don't want to end up with a poor quality wheel just to be told you should have not bought that make, I have a 6" grinder what would be a ball park figure to pay for a reasonable quality diamond wheel. Many thanks Dave. |
magpie | 16/07/2013 22:22:23 |
![]() 508 forum posts 98 photos | Hi Dave. Take a look at www.arceurotrade.co.uk . No connection to them, just a very satisfied customer. Cheers Derek. |
David Littlewood | 16/07/2013 23:12:13 |
533 forum posts | Dave, I got a diamond cup wheel from Arc, as Magpie suggests. It was well balance without any adjustment on my T&C grinder, and it grinds tungsten carbide very well. Also very reasonable price. John S is absolutely spot on, green grit is old hat. David |
Springbok | 17/07/2013 04:03:37 |
![]() 879 forum posts 34 photos | Also was the centre a very neat fit if not so that is where your vibration is comeing from. but use diamond Bob
Gordon W | 17/07/2013 12:07:40 |
2011 forum posts | I do very little grinding of carbide, so the green wheel will do for now. Check the supplied center bush, I've had them well out of square and size, had to make bush last time (for a std. grey wheel.) |
Trevor Wright | 17/07/2013 12:42:03 |
![]() 139 forum posts 36 photos | Dave, If the wheel is vibrating then there is something amiss. There should be plastic spacers to hold the wheel on centreline and paper pads for the sides of the wheel. You should not have to dress the wheel for true from new, if it is that far out then send it back as it is faulty. Vibrating wheels can shatter and cause serious injury..... As mentioned earlier, "ringing" of the wheel is necessary to check for cracks.......hold the wheel by one finger through the hole and tap the wheel with a knuckle quickly NOT a hammer. If the wheels rings it is good, if it is dull then it is cracked and should be binned or dropped on the floor and broken to prevent anyone else using it. Grinding wheels are far more dangerous than they appear so don't take chances..... Green grit wheels are ok but don't last long on carbide, but are cheaper than diamond wheels. The price you pay will depend on how often you are likely to use it. trevor |
Ian S C | 17/07/2013 14:14:23 |
![]() 7468 forum posts 230 photos | After you have broken the faulty wheel, you can use the bits to dress the new wheel on the grinder. Ian S C |
Billy Mills | 17/07/2013 17:18:29 |
377 forum posts | Diamond wheels are so much safer and long lasting than green stones. They are supplied " dressed", you just spend some time centering and clamping till they run true. The price is very fair and they are easier to get hold of than greens, you also don't have the worry that they have been dropped-possably cracked- in transit. Neither do you need to redress or sweep away piles of green grit.
Billy. |
Ossie | 17/07/2013 19:01:24 |
15 forum posts 11 photos | The centre bush is a nice fit I think the hole is in the wrong place, I emailed rdg tools on eBay and had a reply saying they have sent a replacement wheel so I will see what that one is like. Does anyone know where I can purchase a new bench grinder that comes with diamond wheels fitted as standard, I am new to all this engineering stuff I'm 55 just purchased a Myford ML7 plus many other bits and pieces, so far I have made a chuck key with a knurled end I might add I reckon it has cost me about £1800 to make. Thanks for all the great responses Dave. |
Rik Shaw | 17/07/2013 19:30:29 |
![]() 1494 forum posts 403 photos | Green wheels were commonly used for "roughing" carbide but although they will remove material they do it very inefficiently. The result is heat. The cure is quenching. Unfortunately, hot carbide dunked in water (depending on the grade of carbide) can produce fine fractures rendering it U/S. Much better is to use a coarser diamond wheel for roughing and swap to a finer grit for finishing. I am not a perfectionist however so I use a coarse diamond wheel for ALL my carbide. It works for me! PS. I use a cup wheel but if you are mounting a diamond lap on a standard bench grinder it's best to use a DTI on the OD of the wheel (rotate wheel by hand of course) to get it running true, this way you'll avoid vibration. Rik |
dcosta | 17/07/2013 20:15:53 |
496 forum posts 207 photos |
Hello all,
Edited By dcosta on 17/07/2013 20:16:11 |
Rik Shaw | 17/07/2013 20:51:34 |
![]() 1494 forum posts 403 photos | Hello Dias - 3000rpm is plenty good enough for the average small 80-150mm diamond wheel. ----- Rik |
Clive Hartland | 17/07/2013 21:28:19 |
![]() 2929 forum posts 41 photos | Bear in mind that Diamond wheel is not a 'Jobbing' wheel, you should not try to take off a lot of metal with it. It is for dressing an edge and the lightest touch should be used, if you smell the resin smell then you are working the wheel too hard. As mentioned earlier, do the hard work on a green grit wheel and finish on the diamond wheel. Clive |
Ossie | 18/07/2013 12:25:58 |
15 forum posts 11 photos | Just received this from Rdg tools so I guess there was a problem
the replcement went yesterday hope this one is better for you we checked the box the first one came from and they were all as bad or worse so we checked and sent you a good one.
Thanks for all the responses
dcosta | 18/07/2013 12:49:27 |
Hello Rick, |
