Bob Perkins | 28/06/2013 19:50:26 |
249 forum posts 60 photos |
some advice from the petrol heads please (not to exclude wise non-petrol heads) after a few weeks I have finally got my Jan Ridders SABINE 2 stroke to run. I have issues with it which I think are related to the ignition circuit, after getting better results from changing the battery upwards a couple of times. I am now using a 12v 15AH dry fit battery with a 12v Lucas coil and a condenser from a mini, which I don't know the value of and a v3 micro switch as a contact breaker. with a fully charged battery the engine will run for about a minute and the fade out. The terminal voltage falls to @ 11.9v under load. i would welcome some advice on the combination of the components. Is the coils too large for the battery? thanks in advance Bob..
DerryUK | 28/06/2013 20:18:31 |
125 forum posts | My motorbike with an electric starter runs an 11ah battery so yours should be OK. Maybe you have a duff coil, measure it's current consumption it should be no more than 3 - 4A with the points closed and engine stationary. It will be less than this with the engine running. Derry. |
martin perman | 28/06/2013 20:25:23 |
![]() 2095 forum posts 75 photos | Bob, In the Stationary engine world we use the choke coil from a fluorescent light fitting which will run with a dry cell battery, very rarely do you see a car coil but if you do it usually connected to a car battery, how hot does the coil get as it could be braking down when hot. Martin P
Edited By martin perman on 28/06/2013 20:26:16 |
Les Jones 1 | 28/06/2013 20:28:16 |
2292 forum posts 159 photos |
Hi Bob, Les.
Bob Perkins | 28/06/2013 20:33:40 |
249 forum posts 60 photos | Thanks for the comments. The coil does get vey hot. I'll take some current readings tomorrow. Would it break down in such a short time.? Can I test it? I can measure the resistance of the primary and secondary windings. Can I test between with a megger? Bob.. |
martin perman | 28/06/2013 20:34:00 |
![]() 2095 forum posts 75 photos | Bob, Another thought, are the points closed until needed or open until needed, if shut you maybe shorting the battery.
Martin P |
Bob Perkins | 28/06/2013 20:35:16 |
249 forum posts 60 photos | The points are normally closed and open at TDC. |
Farmer Dave | 28/06/2013 22:34:18 |
33 forum posts 7 photos | hi Martin I'm very intrested in your sugestion about using flouresant light fitting chokes on the ignition of stationary engines, I have never heard of this before some more information would be much appreciated. Regards Farmer Dave |
LADmachining | 28/06/2013 22:53:59 |
![]() 126 forum posts 11 photos | Make sure the coil isn't rated for use with a ballast resistor, which would drop the nominal 12V from the battery to approximately 7V at the coil during normal running. The resistor is switched out of the circuit when the starter is operated to ensure the coil is not run under-voltage when battery voltage drops under the load of the starter motor. The coil getting so hot so quickly does suggest it is running at too high a voltage.
Anthony |
JasonB | 29/06/2013 07:47:22 |
![]() 25215 forum posts 3105 photos 1 articles | I've used the ballast from light fittings but only on a low tension setup with an ignitor, don't know how they would fair for a HT sparkplug. J |
FMES | 29/06/2013 08:49:58 |
608 forum posts 2 photos | Bob, You say that 'The points are normally closed and open at TDC.' This is way too long @300 degrees plus, dwell time (period of points being closed) should be about 40 degrees I'm going on the old mini distributor points setting information. THis would indeed make the coil run hot and drop the battery voltage. Lofty Edited By Lofty76 on 29/06/2013 08:50:45 |
Les Jones 1 | 29/06/2013 10:09:06 |
Hi Bob, Les. |
martin perman | 29/06/2013 21:21:57 |
Go look at these links **LINK** for low tension
Bob Perkins | 30/06/2013 08:25:35 |
249 forum posts 60 photos | Martin, Les thanks for your feedback. The coil values are similar to the values I measured yesterday. I plan to replace the capacitor for a known value. I had a bit more success yesterday, getting it to run for @ 3 minutes. |
Ian S C | 01/07/2013 13:36:14 |
![]() 7468 forum posts 230 photos | From what I'v read of this motor, it does not have a great reserve of power, so it might be worth doing as I have done with stirling engines, run the motor over with an electric motor for a while with the spark plug out. I build my engines now with the power piston a little less tight in the bore, but even then the power increases with running. Ian S C |
Bob Perkins | 01/07/2013 16:39:36 |
249 forum posts 60 photos | Thanks Ian. I agree friction may be an issue. I'm using a battery drill to start it, and the more I've tinkered and run it, it's now running for longer periods. It ran well for @ 5 minutes by the end of yesterday. I would like to re-visit the ignition circuit and reduce the size the dustbin dimensioned coil and the battery. This is a new topic for me so plan some holiday reading and research on the subject, and hopefully details of a circuit to build. Regards Bob..
jason udall | 01/07/2013 17:01:38 |
2032 forum posts 41 photos | is a v3 micro switch widely used for this?...seems a bit light.. and maybe too slow mechanically.... contact points would typically be 4-6 mm dia. the contacts in a v3 are around 1-2 mm diam and points usally have quite stiff springs to get the flight time down ..v3's are aimed at light operating forces... but as I say if it works elsewhere.. then that might not be the problem.. |
jason udall | 01/07/2013 17:06:23 |
2032 forum posts 41 photos | btw.. many renault ( and others) use a on plug fitted coil..about 30 mm dia ..this might prove more fitting in scale to your engin..**LINK** for example and http://www.qxcomponents.co.uk/CoilCatalogue.pdf Edited By jason udall on 01/07/2013 17:08:12 |
Bob Perkins | 01/07/2013 21:42:28 |
249 forum posts 60 photos | Thanks Jason
The v3 is on the specs for the design, and seems commonly used for the application. I have considered the and have concers over its rating as the contact rating is 3A and my coil is pulling around 3.5A. My experience of using these in industry is that they are under rated and that it should handle 3.5A ok. I guess an electronic ignition circuit will overcome this. The coil info looks interesting thanks again.
bob..
Ian S C | 02/07/2013 13:08:08 |
![]() 7468 forum posts 230 photos | There is a thread on the 'on the plug' coils in another site to do with model engines, I'm just an occasional visitor to that site, I think there are two types, one twelve volt, the other I think is higher. Ian S C |
