Martin Kyte | 11/04/2013 13:37:58 |
![]() 3445 forum posts 62 photos | Hi Chaps Any one out there building a synchronome? I have just bought a backplate casting and am casting around for additional info. I have the Electrical Timekeeping (Hope-Jones) book and Electric clocks and Chimes. Could do with a source for swedish iron too if anyone has any bright ideas. regards Martin |
Bazyle | 11/04/2013 15:10:45 |
![]() 6956 forum posts 229 photos | You do know there was a build series in ME about 20 years ago? I think an old GPO relay can be used for the magnet core. |
Russell Eberhardt | 11/04/2013 16:02:30 |
![]() 2785 forum posts 87 photos |
Posted by Bazyle on 11/04/2013 15:10:45:
... or use the core material from a scrap transformer. Russell. |
JasonB | 11/04/2013 16:20:01 |
![]() 25215 forum posts 3105 photos 1 articles |
Or slice up a body panel from a scrap Volvo or Saab |
Martin Kyte | 12/04/2013 09:49:42 |
![]() 3445 forum posts 62 photos | Hi Chaps I have found the ME Jubilee Clock (Edgar Westbury) 1958 but no synchronome. Anyone have any other references to a series in ME ?. Transformer cores are laminations of silicon steel. I need 1" bar stock. I can use mild if I have to or find some meaty solonoids but it's nice to get as close to the original design as possible. I like the Volvo/Saab comment. Volvo's are closer to plate than sheet material. regards Martin |
Michael Gilligan | 12/04/2013 09:58:50 |
![]() 23121 forum posts 1360 photos | Posted by Martin Kyte on 12/04/2013 09:49:42: I need 1" bar stock. I can use mild if I have to or find some meaty solonoids but it's nice to get as close to the original design as possible. . Martin You could try here If you're lucky, it might qualify as an "Engineering Sample" MichaelG. |
Bazyle | 12/04/2013 20:33:39 |
![]() 6956 forum posts 229 photos | Sorry, wrong magazine. Engineering in Minature, Jan 1987 to May 1988 "An Electric Master Clock" by Elliot Isaacs. The index sometimes leaves out the 'An'. I assume the casting is the one from College Engineering |
Johan van Zanten | 13/04/2013 09:13:07 |
![]() 52 forum posts 98 photos | Hi Martin, I restored a synchronome some 15 years ago. The coils were in rather bad state so I desided to replace them by new ones and keep the original coils in spare. I used normal BMS for the cores. There is some remanent magnetism but this does not any harm. You must set the end stops for the armature carefully to prevent metal to metal contact with the coil cores. Succes with your new project. Kind regards, Johan. |
modeng2000 | 14/04/2013 07:07:20 |
340 forum posts 1 photos | A thin non-magnetic spacer such as thick paper can be useful to help prevent the sticking of the armature to the cores by providing a small gap in the magnetic circuit. John |
Ian S C | 14/04/2013 11:41:21 |
![]() 7468 forum posts 230 photos | Last night I was going to write, I'll do it now, a small brass rivit in one of the faces that might touch will prevent the poles sticking. Ian S C |
Martin Kyte | 15/04/2013 09:29:29 |
![]() 3445 forum posts 62 photos | Hi Chaps Thanks for the replies. I have acquired a chunk of swedish Iron curtesy of a friend. It's 3/4 plate so I intend to laminate two slices together to get the thickness. Probably soft solder together. The casting is from CEng and is very good. Point noted re stops and anti-stick tricks. I will try and get hold of the Eng in Min copies. I may well make BMS cores too to make a comparative test, if I do I will post the findings. Martin |
john robinson 6 | 19/01/2014 15:41:49 |
2 forum posts | Howdy, I just finished my first assembly of a Synchronome clock based on the Engineering in Miniature build series written by Elliot Issacs.There were a couple of mistakes in the build series, dimensions for the roller support are incorrect, and drawings for the bearing plates for the gravity arm and the armature are missing. Other than those, the build went well, it takes a fair amount of hand adjustment to set the clock up to allow it to run easily, as the adjustment of the various parts to work together is critical. I used the CES backplate and Hope-Jones book "Electric Clocks and How To Make Them" to verify the magazine dimensions. I'm still working on the case, and hope to have the clock running soon. thanks drive carefully |
john robinson 6 | 08/02/2014 11:20:01 |
2 forum posts | Howdy, I've modified my homebuilt sync, I'm either using ball bearings on all the arbor pivots, or I made the part as a ball bearing. The roller is now a ball bearing but is still mounted on its' arbor with hand broached pivot bearings, the back click is a ball bearing, and its' arbor is also on ball bearings. Because the click ball bearing has an inner and outer race, the bend of the click wire cannot make contact with the outer race, and thus is free turning. I "pinched" (made wider) the end of the wire to keep the bearing in position on the wire. I hope to have this clock running by early next week with an unannealed Invar pendulum rod. This weekend I'm beginning the assembly of an inert atmosphere heat treat oven to anneal the Invar rods I have. thanks drive carefully. johnrobinson |
Brian Williams 15 | 26/07/2015 23:09:00 |
7 forum posts | Hello chaps Does anyone know where I might be able to obtain a count wheel for a Synchronome master clock?? Regards Brian
Swarf, Mostly! | 27/07/2015 10:08:11 |
753 forum posts 80 photos | Hi there, Brian, Why don't you make your own count wheel? If you have either 'Electrical Timekeeping' or 'Electric Clocks and how to make them' both by F. Hope-Jones, they each include a drawing of the count wheel. One merit of the Synchronome is that the pitch accuracy of the count wheel isn't too demanding - it only has to be precise enough for the pawl to gather at least one but not more than one tooth at each swing of the pendulum. Subsequent action, i.e. release of the gravity arm, only occurs once per revolution of the count wheel. I'll retreat to my dugout now!!!!!!!!!!!!!!!!!! Best regards, Swarf, Mostly! |
Brian Williams 15 | 27/07/2015 10:17:11 |
7 forum posts | Hi...thanks for the thought. Sadly, I don't have the equipment to make a count wheel so am keen to track one down. Am I right in thinking they used to be fairly readily available? Regards Brian
Martin Kyte | 27/07/2015 10:54:40 |
![]() 3445 forum posts 62 photos | The minimum of equipment is required for the count wheel. Jewelers saw and a couple of files and the ability to mark out. If you can cross out a clock wheel you can make the count wheel as it's just a rachet and doesn't mesh with anything. Give it a go. regards Martin |
Brian Williams 15 | 27/07/2015 19:58:54 |
7 forum posts | Good advice..thanks, I'll get on the case! Brian |
