Here is a list of all the postings Brian Williams 15 has made in our forums. Click on a thread name to jump to the thread.
Thread: Brazing brass to steel |
12/02/2016 23:48:16 |
Thanks Keith....That points me in the right direction! Brian
10/02/2016 21:28:11 |
Hello gents I am attempting to join a short length of silver steel (5/16th diameter) to a small piece of brass (1/8th) thick. I'm using silver solder, something called 'auflux' as the flux and am heating it all with a propane torch. My big problem is that I struggle to get the solder to run, and when it does it adheres only to the brass, not the steel. Any ideas where I'm going wrong? All suggestions much appreciated Thanks ...... Brian
Thread: Proxxon 150/E |
01/11/2015 23:22:08 |
Thanks for the response, Jason. I shall check the numbering of the jaws. As regards the appearance, the jaws seem to meet OK and I put a 2mm rod in the chuck and ran the tail stock up to it....and, to my very inexperienced eye, it looked alright....but perhaps I'm missing something. Does anyone know if the chucks often prove problematic on these lathes? Thanks again Brian
01/11/2015 17:32:14 |
Hello Chaps I'm an absolute beginner, not having handled a lathe since my far-off schooldays. I'm having a few difficulties and am wondering if it is me (probably) or the machine I bought a new Proxxon FD150/E lathe and seem to be having a problem with the three-jaw chuck. I turned a small shoulder on an 8mm brass bar, held in the chuck, and got something rather eccentric (in all senses). The result looked like a cam. I then turned a similar feature on a 6mm bar...held in a collet...and it was fine. So it seems there's something wrong with the chuck...or am I missing something? Assuming it is the chuck, what can I do? I'd very much appreciate suggestions or advice! Thanks.... Brian
Thread: Synchronome |
27/07/2015 19:58:54 |
Good advice..thanks, I'll get on the case! Brian |
27/07/2015 10:17:11 |
Hi...thanks for the thought. Sadly, I don't have the equipment to make a count wheel so am keen to track one down. Am I right in thinking they used to be fairly readily available? Regards Brian
26/07/2015 23:09:00 |
Hello chaps Does anyone know where I might be able to obtain a count wheel for a Synchronome master clock?? Regards Brian
