Household paint. An observation!
Mike Hurley06/06/2023 10:14:16
530 forum posts
89 photos
Now the warmer weather is here, many will be tempted to start DIY ,as I did yesterday painting some exterior woodwork. Having had less success in the past with environmentally friendly water based stuff, brought some traditional solvent based instead - Dulux ONCE.
Fine, covered really well, no complaints - apart from the smell! It was horrendous, not the old 'white spirit ' odour but something quite different and nasty. Grateful I didn't use it indoors. My work clothes reek of it and can't get the smell out of my nose. So, beware where you use this stuff
blowlamp06/06/2023 10:32:17
1885 forum posts
111 photos
The best paint I've found recently is Wilko's own brand Exterior Wood and Metal. I've used it inside and out with really good results
Using the Satin version on some new MDF window ledges gave a very nice finish, which blended perfectly with the UPVC window frames. The only thing I needed to do was thin it with water to get the flow I wanted. Simply 'lay off' after each coat to get a very smooth finish.
Martin.
Bazyle06/06/2023 10:35:48
6956 forum posts
229 photos
Seems it's not a new problem - from 2008
Howi06/06/2023 10:37:38
442 forum posts
19 photos
i oo recently bought some white paint for indoors, previously used water based but fount it rubish, so bought solvent based gloss, much better finish, but noticed on tin said 'not for large surfaces' ?????
is it me just getting old?
Perko706/06/2023 12:39:20
452 forum posts
35 photos
A few years ago paints in Australia were oil-based enamels or water-based acrylic and worked well. Then a couple of manufacturers introduced enamels that were suitable for water clean-up. They were horrendous. Did not cover well, streaky when brushed, fussy about which undercoat/primer they would work with, and the cleanup was worse with water than when using turps. Found some other brands that still do the standard water-based acrylic and that is pretty much all I will use these days. Tradition was that you used gloss enamel on interior trims (skirtings, architraves etc) but I have used gloss acrylics for these with no problems and they are easier to repair when damaged. The only enamels I use now are in spray cans for use on metal.
Martin Johnson 106/06/2023 13:47:22
320 forum posts
I used some silver "hammerite" (screwfix own brand actually) from a part tin that was opened at least 10 years ago. Absolutely fine. In that same 10 years, I have lost 2 tins of acrylic red lead to frost.
So which sort of paint is best for the environment? The one that goes direct to the dustbin of course.
Is it me??????????
Martin
Nigel McBurney 106/06/2023 16:56:15
1101 forum posts
some years ago I painted a steel stationary engine trolley for my Blackstone,it was black Dulux ONCE paint, it had a brown tinge in strong sunlight. its called once because you use it once and never use it again,a long time I used Dulux trade on another trolley and iron wheels,this time it took about two weeks to dry and still did not really feel really dry. left it all winter to harden off and mounted the engine on the trolley in the spring. For trolley steel work I now use Screwfix aerosol black.Very difficult to obtain a good black enamel nowadays.
bernard towers06/06/2023 17:53:39
1221 forum posts
161 photos
Look at craftsman's paints they still sell Masons paints (Coach Enamel)
Jelly06/06/2023 17:58:31
474 forum posts
103 photos
I'm fully converted to linseed oil paints for exterior joinery.
I was turned on to them by a friend of a friend who does restorative and architectural joinery work for the national trust and the likes.
Over several years I have slowly stripped and repainting all the woodwork on the house with "Kregzdeit" brand linseed oil paint and whilst it's odd stuff to work with, it goes on extremely well, smells lovely when you're working with it, and lasts phenomenally well even in harsh applications.
Properly applied it won't blister or crack and has sufficient flex to move with the wood as moisture content changes through the year. Over 4-5 years the exterior surface goes a bit powdery, but you can wipe it down and apply another coat of oil (from the same manufacturer) to bring it back to full gloss with a single coat.
Supposedly if that's kept up it will last around 20-25 years before repainting is needed... Certainly in the time I've been using it my father has had to fully prep and repaint the windows on my parents house twice whilst mine just soldier on.
What it isn't however is cheap... Big upfront cost at about £85 per 2.5l can for the initial paint, although the Oil for maintenance is cheaper than repainting with conventional gloss by a country mile.
It felt like a gamble going "buy once, cry once" on exterior paint, but does seem to be paying off, would recccomend.
Edited By Jelly on 06/06/2023 18:00:06
Peter Bell06/06/2023 21:49:08
399 forum posts
167 photos
Jelly---I have the same problem with exterior paint cracking/pealing etc and needing doing fairly soon so I am interested in your approach.
Ive searched "Kregzdeit" but it seems to be mainly exterior cement coated wall type I have found---what am I doing wrong?
Peter
Jelly07/06/2023 08:27:32
474 forum posts
103 photos
I appear to have mis-spelled it, the correct spelling is "KREIDEZEIT".
I have bought it from Mike Wye Associates up to now.
(You have to request a quote online, then they'll confirm their stock levels and email a pro-forma invoice over, which you can pay via the bank or by card over the phone... It's a bit faffy, but the product is worth it IMO)
Peter Bell07/06/2023 15:59:08
399 forum posts
167 photos
Many thanks for the info, Peter
Samsaranda07/06/2023 18:06:18
1688 forum posts
16 photos
A friend of mine was apprenticed as a painter and decorator and in those days they were taught to mix their own paints which included linseed oil and the required pigments. I find modern paints do not last, the slightest amount of weather outside and the paints start to fail, I rue the day that they banned lead based paints I always had good results with them and having grown up in an environment of lead based paints I seem to have survived unscathed, sure there are dangers with lead based products but you manage the risks, man has learnt to live with fire although I am sure some would ban it if they could. Dave W
duncan webster07/06/2023 20:31:32
5307 forum posts
83 photos
I've had good results outside from Sadolin Supadec. It's not very glossy, but it doesn't seem to crack or peel, every few years just wash it down and give it another coat. Water based so cleaning brushes is easy.
I use water based gloss internally as well, doesn't go yellow, goes on a lot easier, dries faster, what's not to like. Just because it's new doesn't make it worse.
Edited By duncan webster on 07/06/2023 20:32:10
Neil Lickfold07/06/2023 21:08:38
1025 forum posts
204 photos
Our older house was painted in Antifoul marine paint in 1971, we only painted it in 2013, because we had the windows and the sliding doors replaced with newer double glazing units. The paint was still good after all those years. Since it was repainted, we now get all the usual insects like prayingmantis nesting and spiders etc. The cost to buy the newer version of the antifoul paint was nearly 6k.
So in 40 years, it was actually a cost effective option, especially if you work where it's used and can buy a hose lot alot cheaper than paying full retail.
The repaint, was done in a water based elsatomeric membrane paint, it's now been 10 years since the work was done, and the paint is in excellent condition. So this is a very viable paint, and being that it has lasted 10 years now will be very happy recommend this type of paint.
Peter Bell08/06/2023 11:05:31
399 forum posts
167 photos
Neil, a search for water based elastomeric membrane paint produces mainly masonry type paint--do you have a brand you used?
An enquiry to Mike Wye has confirmed that KREIDEZEIT is not suitable for our project so the search goes on with Sandolin to be investigated..
The project BTW is a 100+ yr old wooden station building that needs repainting after being treated with spirit based preservative . Ordinary gloss paint soon cracks as the building is subject to full sunlight and it would be good to find a longer lasting solution.
mick H18/06/2023 10:01:07
795 forum posts
34 photos
Sadolin Superdec Opaque was always my "go to" paint for exterior woodwork doing exactly what it said on the tin about coverage and 5 year life and no rubbing down required on repainting. So i had no hesitation in buying a tin to paint my side gates. What a disappointment. Difficulty in covering blemishes and overall coverage poor ....3/4 of litre tin to do 2 gates. As my neighbour remarked, I might as well have been painting with water! I did note however that the product now emanates not from Sadolin but from Crown. So looking for a replacement product for the future. Sikkens (Sico) comes to mind unless anyone can enlighten me further.
Mick
Edited By mick H on 18/06/2023 10:02:12
Mike Hurley18/06/2023 10:20:07
530 forum posts
89 photos
Been nearly a fortnight since I started this thread. Have just been away for week (wasn't I super lucky with the weather! ) but on return was still greeted by the odour of a badly decayed dead sheep near my front door - as someone else rightly commented - it's called Dulux ONCE because that's how often you ever use it.
Pete White18/06/2023 14:41:24
223 forum posts
16 photos
Posted by Samsaranda on 07/06/2023 18:06:18:
I am not expressing an opinion!, but the danger of working and preparing old lead covered surfaces is a big issue, seem to have been glossed over. Sorry!
Loads of stuff out there on internet about the dangers, diy, trade body guidlines etc quite frightening.
A bit off topic, but I can remember my dad taking a sander to the 1950s nobbly ceiling, most of which contained asbestos, filled the house with dust mum was not pleased, You just don't know what damage was done?
Edited By Pete White on 18/06/2023 14:47:10
mark smith 2018/06/2023 18:38:49
682 forum posts
337 photos
Bedec Barn paint is an excellent all round paint for exterior use on wood ,and most surfaces , but unsure how many colours its available in.
