Cables
Stephen Follows14/05/2023 17:44:58
119 forum posts
Why is it that when one buys a power tool that comes with a new box that you cannot get the cable back in the box when you put it away?
Fulmen14/05/2023 18:12:41
120 forum posts
11 photos
When you plug it in the extra electrons makes the cable swell.
Vic14/05/2023 18:37:36
3453 forum posts
23 photos
It’s really irritating isn’t it.
luckily I do manage to get both the cable and the hose in on my cars air pump. wink
george baker 114/05/2023 18:51:42
39 forum posts
Hi Vic
I cant
George
Mike Hurley14/05/2023 19:19:38
530 forum posts
89 photos
I never have a problem with the cable, it always seems to be the mains plug that has magically expanded to 2x it's original size
Howard Lewis14/05/2023 19:28:03
7227 forum posts
21 photos
It is subject Newton's Fourth Law; The eternal cussedness of things.
Sometimes attrributed to Sod
Edited By Howard Lewis on 14/05/2023 19:28:39
Stephen Follows14/05/2023 19:44:50
119 forum posts
Ah yes…the plug. There’s a moulded space for everything but.
old mart14/05/2023 19:50:07
4655 forum posts
304 photos
When my old Black & Decker professional SDS drill broke, the only thing worth saving was the cable, which was immediately transfered to my Bosch 2 speed drill. The cable is soft and so easy to get into the case, the Bosch cable got binned.
Dalboy14/05/2023 20:04:30
1009 forum posts
305 photos
Having spent 25years as a plant mechanic from small electrical tools up to larger plant. I now have no trouble getting everything back in the box there is just that little knack to accomplish this simple task.devilcheeky
HOWARDT14/05/2023 20:11:18
1081 forum posts
39 photos
Jests aside I always assumed it was a UK problem with our plug being bigger than everyone else’s and the cable.
Nick Wheeler14/05/2023 21:03:31
1227 forum posts
101 photos
Just as annoying is the need to dismantle the working bits to have any chance of the tool fitting its slot.
The only blow moulded cases I keep are the ones that contain lots of small fittings, like a pipe flaring tool or the pressure testers. Otherwise the cases take up too much room - as part of my recent clear up, I managed to get two both circular saws, jigsaw and the router on the same shelf that the jigsaw case used most of.
Edited By Nick Wheeler on 14/05/2023 21:04:05
Dave Halford14/05/2023 23:39:49
2536 forum posts
24 photos
Posted by Stephen Follows on 14/05/2023 17:44:58:
The packers have to serve a 2 year apprenticeship
Pero15/05/2023 03:34:05
193 forum posts
HowardT - It's not not just a UK thing. They are just as cantankerous here in Australia.
The other problem I can't understand is why the smaller and lighter the tool the more inflexible the cable supplied. I had assumed that his was in an effort to make it more difficult to manipulate the tool but it may also be part of the designed difficulty in getting it back into the box
Nick - I agree with you re blow molded cases. Not only do they take up far to much room but they have a habit of failing at the hinges ( and other places over time ). Attempted repairs are generally unacceptable bordering on impossible, There are some good cases - heavier duty and with real hinges - but these tend to take up even more space. Still they do keep the dust out which is a positive!
Pero
not done it yet15/05/2023 06:04:36
7517 forum posts
20 photos
I generally don’t care about the box, after unpacking. What annoys me is that very few tools have any means of storing the tool neatly - like somewhere to affix the plug or some means supplied to wrap the power lead around the tool, for mains-powered tools.
Speedy Builder515/05/2023 06:43:39
2878 forum posts
248 photos
I find generally that cables are too short or not flexible when cold . Antex soldering irons obviously know that their standard cables are stiff when cold and sell the same iron with a more flexible cable with an uplift in price.
Bob
larry phelan 115/05/2023 08:25:41
1346 forum posts
15 photos
Never had a problem with Hilti tool cables, best type I ever came across.
Also, plenty of room in the box for everything.
As for the others ???????????.
SillyOldDuffer15/05/2023 09:13:24
10668 forum posts
2415 photos
Apart from the cable and plug being tricky to get back in the case, power tool cases are usually shaped with sexy artistic curves that make them difficult to store. My latest purchase, an angle grinder, has to sit on the floor, because the case won't quite fit on the shelf. Plenty of room on the shelf if I bespoke six or seven rectangular wooden boxes, and it rankles that working tools come in cases that won't stack.
Anthony Knights15/05/2023 09:27:02
681 forum posts
260 photos
I buy suitably sized tool boxes for storing portable tools which don't come with their own storage case. I can then store the tools with their various blades, belts or other attachments in one place together with the power cable, charger etc. The boxes can be stacked and I label the case with the contents so I can instantly select the tool required. Just a matter of being organised.
Nick Wheeler15/05/2023 09:28:08
1227 forum posts
101 photos
Posted by Speedy Builder5 on 15/05/2023 06:43:39:
I think that's one of the signs of a better quality tool: you don't need to prop an extension cable close enough to the job that you knock it off every time you breathe out. Although I've often wondered why a euro torch for a mig welder is 3metres long, yet the earth lead barely sticks out of the machine.
not done it yet15/05/2023 14:19:39
7517 forum posts
20 photos
Posted by Nick Wheeler on 15/05/2023 09:28:08:
You don’t normally want, or need, to move the welder. But you do need to move the welding torch from one end of the job to the other. That is why they are different lengths, with the torch being the longer by quite a degree.
Welding torch and lead is much lighter than the welder.
