Member postings for Stephen Follows
Here is a list of all the postings Stephen Follows has made in our forums. Click on a thread name to jump to the thread.
Thread: DRO
05/08/2023 13:08:59
I have a DRO that was previously used with glass scales. is it usable with magnetic scales? Don't want to buy them and find it doesn't read. Thanks.
Thread: Awkward Question Time! (Genuine Survey, But...)
22/07/2023 15:20:18
I had the same problem, declined to take part in that section. Apparently, my wife doesn't qualify!
Edited By Stephen Follows on 22/07/2023 15:20:39
Thread: Myford oilers
17/07/2023 18:50:52
Does anyone else get frustrated with Myford lathe oilers. In desperation, I bought two new ones from RDG….not cheap but I wanted the right ones.
Three years on and I still can’t get them to work consistently. Some days they barely work others they flood the suds tray.
I often think I’d be better removing them and squirting oil down the holes every half hour or so.
Thread: Safety gloves
13/07/2023 21:27:03
If you must wear gloves thin nitrile ones tear easily. Generally though with machinery it’s no gloves no long sleeves no long hair etc. I got slated on another site when I suggested the danger when a user showed his eight year old daughter using a lathe with her hair dangling over the workpiece. Apparently, safety doesn’t count when it’s kids in a shed. One thing people often forget is rings, could lose a finger if caught.
Edited By Stephen Follows on 13/07/2023 21:28:57
Thread: Copper tube
13/07/2023 21:16:00
M-Metals seem to be the cheapest so far but at £123 plus postage for twelve inches I think I might wait a while and see what comes my way. Thanks for replies.
12/07/2023 22:16:37
I’m looking for some five inch copper tube to make a boiler. The best I’ve found is £248 for twelve inches. Anyone know a supplier who charges sensible prices?
Thread: Collet chuck
07/06/2023 16:22:32
UPDATE ON CHUCK
Spent some more time time today trying to get it true. Although the backplate had been machined and was running true the whole assembly wasn't. Did some measurements on the chuck part and found it to be out by about 0.1 mm in depth. Took a light skim off it and refitted it to the backplate. Ten minutes later everything running true.
I thought the chuck would be perfectly machined, the instructions only mentioned machining the backplate.
05/06/2023 18:02:04
Done it again...
(0.003"
Edited By Stephen Follows on 05/06/2023 18:02:38
Edited By Stephen Follows on 05/06/2023 18:03:09
05/06/2023 17:58:16
Just noticed my original post looks strange. The (0.003&rdquo has morphed into something unrecognisable. I do sometimes post typos but it certainly was nothing like that.
05/06/2023 17:54:30
I have tried rotating using all holes in all positions.
Run out has been measured on the outer surface, at the back of the threaded section and inside the chuck. All are pretty much the same.
Tried tapping in with nylon hammer doesn’t move if tightened, works when slightly loose but runs out again as I tighten up.
05/06/2023 16:22:04
Can anyone help?
I have bought a collet chuck from a reputable supplier to fit my Myford ML7 lathe. Having machined the faceplate as per instructions, the closest I can get it to true is 0.08mm (0.003&rdquo.
Is this acceptable or is there something I can do to achieve higher accuracy?
Spent three hours trying but can’t do any better.
The lathe runs true.
Thread: Steel prices
15/05/2023 19:46:02
what's with steel prices today? I have been searching for 25mm EN1a mild steel round and have seen prices from £9.00 per metre to £36.00 per metre.
Thread: Cables
14/05/2023 19:44:50
Ah yes…the plug. There’s a moulded space for everything but.
14/05/2023 17:44:58
Why is it that when one buys a power tool that comes with a new box that you cannot get the cable back in the box when you put it away?
Thread: Every answer
11/05/2023 23:50:15
Has anyone else noticed that you can find any answer you like on the internet?
I have been debating for months on whether to fit a three phase motor on my Myford ML7 lathe. Apparently the bearings will seize and the lathe will be a worthless pile of junk inside half an hour or it’s the best thing I could do and will give me years of wonderful service at high speeds.
Who does one believe?
Thread: Mill vice
06/05/2023 17:14:23
Thanks for comments and pictures. Looks like I may have to be satisfied with 80mm.
06/05/2023 17:13:01
I presently use a 50mm, OK for really small stuff but insufficient for much else both depth of jaws and width especially when wanting to use parallels.
06/05/2023 17:09:57
Edit, Y axis....senior moment.
06/05/2023 16:39:31
I want to fit a four inch vice to my Warco WM14 Mill. Problem is how much movement I would lose on the Z axis. The distance of the fixing holes from the back of the vice is never given. Has anyone fitted a four inch vice to a small mill successfully?
Thread: Bright steel
04/05/2023 11:22:03
You're right SillyOldDuffer. Unfortunately, before you know it someone will want to split metric into coarse and fine....
