What do you use on the mill to stop steel chips going everywhere
petro1head23/03/2023 10:57:15
984 forum posts
207 photos
As i have been doing a fair bit of steel machining, especially with my 4 bit facing tool, i was wondering what you used to stop the small steels chips going all over the workshop?
Journeyman23/03/2023 11:11:25
1257 forum posts
264 photos
You could go the whole hog and build a screen like this.
Or perhaps just use the shop-vac strategically placed.
For a slightly simpler type of screen, have a look at the one I did for my WM14 *** Mill Screen ***
Edited By Journeyman on 23/03/2023 11:23:33
Paul Lousick23/03/2023 11:27:08
2276 forum posts
801 photos
My set up is not as sophisticated as John's, just some temporary sheet metal guards and a broom.
Hopper23/03/2023 11:46:30
7881 forum posts
397 photos
Magnetic base with a bit of sheetmetal such as an old biscuit tin lid attached can be handy. Move it around to where it is needed most.
Baz23/03/2023 12:01:24
1033 forum posts
I use a couple of old cardboard boxes, one each end of the table, they catch most of it and Henry the Hoover gets to suck up the bits that escape the boxes.
Weary23/03/2023 12:01:42
421 forum posts
Pieces of card folded and weighed-down with scrap.
Phil
Andrew Johnston23/03/2023 12:34:37
7061 forum posts
719 photos
I don't bother, just sweep the floor afterwards as part of the post machining clean up.
Martin Connelly23/03/2023 13:17:33
2549 forum posts
235 photos
Mag base with some rigid plastic sheet with a small overhang at the top gives flexibility. I just aim to keep the chips away from the operator's direction to reduce the area to be cleaned up.
Martin C
Clive Foster23/03/2023 13:55:38
3630 forum posts
128 photos
+1 for Andrews broom with considerable assistance from an industrial version of Henry.
The mister provides a low power air blow when needed to keep the chips out of the cut and, occasionally, oil when needed. I do make an effort to keep chips brushed off they work and onto the table during the job, pausing as appropriate. Frequent wielding of the vacuum cleaner to pick chips off the table helps a lot.
I have got an industrial "flexible" shielding system that magnetically mounts to the Bridgeport table but pretty much never use it as it gets in the way so much during set up. Table mount systems may make sense when doing repetition work so no set-up needed after getting things right on the first two or three. But thats not what we do.
The only shield totally worth having is something effective at the back of the machine so chips don't disappear behind.
Bench mill users might do well with fold out wings connected to the back shield to keep chips on the bench close to the machine. Two or three folds probably best so they don't close off useful fast space when the machine isn't being used.
JasonB23/03/2023 14:04:40
Vacuum for me on the manual mill combined with trying to feed in a direction that sees the swarf going behind the machine, the insert facemills are as you say the most likely to throw stuff about.
The CNC has a "Trough" around the table that does a good job catching 99.9% of the swarf from standard cutters and is not too restrictive though you don't need to get at or see the work so much on that
Oldiron23/03/2023 14:13:35
1193 forum posts
59 photos
Posted by Weary on 23/03/2023 12:01:42:
Phil
Ditto. Works well.
regards
petro1head23/03/2023 14:19:31
984 forum posts
207 photos
Posted by Oldiron on 23/03/2023 14:13:35:
Phil
Ditto. Works well.
regards
To be honest thats what i uused last night
Dalboy23/03/2023 15:24:07
1009 forum posts
305 photos
Vac up after machining I did try the shield that came with the machine but it just gets in the way I found that after hitting it on a long cut in the x axis. I must make a couple of boards to cover the slots which would aid easier clean up
Brian Baker 123/03/2023 16:32:53
229 forum posts
40 photos
Greetings Warco used to sell a simple perspex shield, with a magnetic base and a flexible stand that works well for me. Not sure if they are still available.
Brian B
Samsaranda23/03/2023 16:47:13
1688 forum posts
16 photos
Arceurtrade sell swarf shields with magnetic attachment. Dave W
noel shelley23/03/2023 18:06:19
2308 forum posts
33 photos
Run with a good flow of suds will tend to keep the bits under control. Noel.
old mart23/03/2023 19:44:39
4655 forum posts
304 photos
_igp2508.jpgThose cheap tv stands which fit on the back are easily made into mill guards. _igp2506.jpg
Jelly23/03/2023 20:04:39
474 forum posts
103 photos
Usually my torso...
Unless I'm cutting very aggressively and getting blue/glowing chips, then it's inevitably my face/forearms/the bit of my neck which isn't covered by the collar of my overalls/any other bare skin.
I tend to sweep up what I can afterwards into a big tub, then periodically will lift the duck-boards and shovel up all the remaining chips into the tub just before doing a run to EMR to weigh in scrap.
