What's this called?
Gary Wooding16/02/2023 15:52:46
1074 forum posts
290 photos
I need to measure the thickness of something that is surrounded by a raised border thicker than the item I want to measure. A calliper like this would do the job, but I don't know what its called and can't find anything like it. Any ideas?
Bizibilder16/02/2023 16:00:47
173 forum posts
8 photos
Double ended caliper.  lots on ebay, Amazon, Proops, RDG tools etc
Edited By Bizibilder on 16/02/2023 16:02:12
Mick B116/02/2023 16:01:05
2444 forum posts
139 photos
Dunno what it's called - maybe double-ended caliper - but why not just make or find a flat piece of known thickness greater than the depth of border that fits inside the border, insert it, measure the total thickness, then subtract the thickness of the insert?
Edited By Mick B1 on 16/02/2023 16:02:04
Phil Stevenson16/02/2023 16:01:56
90 forum posts
13 photos
https://www.chronos.ltd.uk/product/double-ended-outside-calipers-6/
ega16/02/2023 16:49:36
2805 forum posts
219 photos
Woodturners use this sort of thing.
Gary Wooding16/02/2023 17:19:03
1074 forum posts
290 photos
Thank you. I tried X-calliper and cross-calliper. I didn't think of 'double ended'.
Mick: Unfortunately, the item I need to measure is on a curved surface.
Phil super716/02/2023 17:38:10
24 forum posts
Try Axminster Tools Under Woodturners Calipers
Michael Gilligan16/02/2023 17:44:03
23121 forum posts
1360 photos
I need mote Coffee … I’s just taken me five minutes to realise that Gary’s illustration represents the shape of the calliper, and is not a drawing of a Möbius strip blush
Martin King 216/02/2023 17:49:38
1129 forum posts
Michael G,
Do i correctly recall a Mobius Bottle?
Also I seem to remember something about a piece of amusing doggerel or poem about it?
Regards, Martin
Ian P16/02/2023 17:55:19
2747 forum posts
123 photos
A friend wanting to measure the thickness of his car fibreglass bodywork made a lash-up double ended caliper with a 80cm throat at one end and a 30mm stroke dial indicator at the other. He made a calibration table to interpret the readings.
Ian P
Michael Gilligan16/02/2023 17:56:41
23121 forum posts
1360 photos
Posted by Martin King 2 on 16/02/2023 17:49:38:
Michael G,
Very nearly yes
https://en.wikipedia.org/wiki/Klein_bottle
Sam Stones16/02/2023 22:11:06
922 forum posts
332 photos
Ditto, Michael.
Even now my brain says it's a 3D ribbon loop, that flips between an inside and an outside centre-riveted continuous strap.
Holding the image flat in two pieces of sheet metal fashioned (as Gary intends), into a double ended caliper is a struggle.
Something stronger than coffee at work?
Cheers,
Sam
Hopper16/02/2023 23:10:42
7881 forum posts
397 photos
Yes, mobius was the first word that came to my mind when I looked at it.
Such double ended calipers are used by cylinder-head modifiers on car and motorbike engines for measuring how much thickness of metal is left between an enlarged port and thin air or the next port etc when grinding out the ports. So might be available from automotive tool suppliers.
Gary Wooding17/02/2023 08:52:47
1074 forum posts
290 photos
Now I come to look at it, it does look like a Mobius strip. Here's a photo of the 3D equivalent - a Klein bottle.
Bootlegger Blacky17/02/2023 09:32:57
54 forum posts
11 photos
Double glazing measuring tool…
https://www.upvchardwaredirect.com/double-glazing-measuring-tool-glass-gauge-15494-p.asp?gclid=EAIaIQobChMIgqXzzp-c_QIVyMLtCh2fhAATEAQYAiABEgIKnPD_BwE
ega17/02/2023 11:12:38
2805 forum posts
219 photos
Eine Kleine Frage:
The liquid in the bottle seems to be above the level of the outlet; is air pressure keeping it in?
Gary Wooding17/02/2023 16:52:47
1074 forum posts
290 photos
You fill it by pumping the liquid through a thin pipe inserted from the bottom and threaded through the 'loop' part. Emptying is the same, but you have to suck instead.
ChrisLH17/02/2023 17:01:13
111 forum posts
7 photos
Can't imagine what it might be but is there a practical application of the Klein bottle ?
ega17/02/2023 17:07:44
2805 forum posts
219 photos
Posted by Gary Wooding on 17/02/2023 16:52:47:
Thanks. I think I had forgotten that the essential feature is that there are no conventional openings in the bottle.
David Davies 817/02/2023 21:19:47
202 forum posts
Found this on the 'net.
A mathematician named Klein
Thought the Möbius band was divine.
Said he: "If you glue
The edges of two,
You'll get a weird bottle like mine."
I'll get my coat.
