Member postings for Phil super7
Here is a list of all the postings Phil super7 has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford Super 7 Quick Change Gearbox issue
17/09/2023 17:41:07
Also Remember the gear you have marked "57" can be turned around, usually only when screw cutting.
Your picture shows gearbox in fine feed mode, hope this helps.
Thread: What's this called?
16/02/2023 17:38:10
Try Axminster Tools Under Woodturners Calipers
Thread: Lathes on casters
19/01/2023 21:41:45
Martin I agree, Consider Lathe's with a slant bed.
19/01/2023 18:59:10
I would serious worry about using a lathe on castors, when a faceplate was being used and out of balance. Also when I was an apprentice i cannot recall any lathe being on castors, they were all secured to the floor.
Thread: Early Super 7
01/06/2022 20:50:58
I agree with Neil, there no shims to adjust the height of the saddle, the only shims used are for the saddle strip.
One of restrictions on regrinding the bed is the rack. Myford use to say 10 thou, as this is the amount of movement the rack can be moved up to re engage with the pinion. Remember regrinding the bed involves repositioning both rack & Leadscrew.
PS I had all these questions rebuilding a S7 many years ago but was fortunate to live not to far away from Myford so use to go to buy parts then go into the workshop and ask the fitters "how do you do this then", they were always very accommodating.
I can also recall asking how old is my lathe, and this gentlemen went of upstairs in the fitters shop came back with a notebook with every machine serial no date and who originally bought it recorded. I wish i knew where that book is now
Thread: Is it possible to by "100% non-stick" spatulas for spreading glue? (ideally made from teflon/FEP)
25/01/2022 18:06:00
I Would go for the non stick glue simples.
Thread: Myford super 7 with gearbox - leadscrew stopped turning
24/08/2021 11:23:43
Check the Grub screw item 174 in Myford gearbox manual, this secures a 26 Tooth gear which is the primary drive into the gearbox.
Thread: 60 degree thread insert
19/08/2021 20:42:37
I do the same as "Old Mart" and I have a Myford never had a problem cutting threads, last cut i always repeat 2 or 3 times to allow for tool "spring"
Thread: cutting spur gears on a mill
19/08/2021 20:35:36
I Recall this method of using a tap to cut a worm wheel was used in an article in MEW some time ago, The article was precise angle adjustment of the table on the Worden T&C Grinder I tried it out worked beautifully.
Edited By JasonB on 19/08/2021 20:47:10
Thread: Newbie needs Advice
03/05/2021 19:49:18
Jenny have a look at vectric cad/cam packages very well supported Link Here vectric.com
Thread: Guiness world record?
16/02/2021 20:35:56
I think it all depends if the workshop pixies are watching at the time.
Thread: Repairing stripped thread in Walker Turner bandsaw
26/01/2021 20:34:53
Repair the thread with a helicoil
Thread: Size question
20/12/2020 21:19:12
You can see why i don't post very often.
Thread: Simple Gearing for Metric Threads on Myford ML7 lathes with gearboxes
31/12/2019 20:35:13
You just need 34 & 33 Teeth Gears , then follow the chart for gearbox settings.These Gears fit onto the Tumbler or (Chart says Mandrel) the same thing, Hope this helps
Thread: Extending router shanks
14/11/2019 19:20:09
Consider how you would eject the taper from the router spindle. The collet nut not only close's the collet but also ejects the split collet.
Thread: TTFN
18/07/2019 20:16:02
I too will miss your input to the forum, i myself find them very interesting, although i do understand how you must feel. I have been a forum member for quite some time but don't post much as i find people are ridiculed by experts! . Silly me thinking this was a hobby and a forum to exchange ideas and help each other. Come back Soon,
Phil
Thread: A Chinese puzzle!
29/06/2019 20:21:52
That looks like a linear bearing
Thread: KX1 CNC Mill Clearance Offer
27/02/2019 19:22:47
A word of caution about changing motor speeds and acceleration , be careful as not getting these set proportionally can effect your tool path.I had a problem cutting a rectangle with square corners, I kept getting rounded corners(radius). drove me nuts endless checking of software. Eventually found it was my speed and exceleration was causing the problem too slow acceleration, mach3 has decelerate and accelerate when changing direction hence round corners. Hope this is of some help to anyone
Thread: Warco VMC worklight
13/10/2018 19:45:57
24 volts 50watts
Thread: Chester 626 Mill Column
23/08/2018 21:42:57
Hello Thought it about time I introduced myself been lurking in the back ground for some time now.
I have a myford super 7 and chester 626, I am probably a bit of a myford nut something to do with my school days,
Athough I do like colchesters tech and apprenticeship days. Now retired
I have had the chester mill for about 10 years now, I have a question? the spindle can be rotated +-45 deg's from vertical and I can understand why ie milling v'ees or drilling holes at an an angle. However the turret can be rotated +-45 deg's, my question is why would you want to do this? I have never found a reason to move it, the spindle just becomes further away from the table
Phil
Edited By Neil Wyatt on 25/08/2018 19:41:30
