Here is a list of all the postings Bootlegger Blacky has made in our forums. Click on a thread name to jump to the thread.
Thread: What are they? |
04/09/2023 16:55:06 |
What are they? |
04/09/2023 16:54:40 |
04/09/2023 16:54:00 |
Any ideas what these brass/bronze thingys are? |
Thread: Steel |
10/03/2023 09:55:26 |
Wow ! Never mind his arms ! His neck is wider than his head ! |
Thread: What's this called? |
17/02/2023 09:32:57 |
Double glazing measuring tool… https://www.upvchardwaredirect.com/double-glazing-measuring-tool-glass-gauge-15494-p.asp?gclid=EAIaIQobChMIgqXzzp-c_QIVyMLtCh2fhAATEAQYAiABEgIKnPD_BwE |
Thread: Pretty new to this |
29/08/2022 19:33:19 |
EBay item number…..234669193975 |
Thread: Joining flat toothed belting |
18/08/2022 19:16:20 |
Just a thought...if you do strip it down, why not put an extra belt loose out of the way ready for future breaks? If there is room of course! |
Thread: ML7 backgear lever lubrication. |
15/08/2022 22:15:41 |
So,, where does the oil come out when you squirt some in the oil nipple? I would have thought it should come out somewhere on the smaller diameter section where the back gear actually runs ? yes it does. Thanks Hopper. |
14/08/2022 08:41:28 |
I’m with you on this one Richard S2. A blind hole vent sounds like a good answer,So I’ll leave well alone and just oil prior to fitting.Thanks to all. |
12/08/2022 07:44:56 |
Definitely no link between oil nipple and hole ,So should there be ? I could drill an oilway to suit from the small end past the nipple to the hole, any thoughts ? |
09/08/2022 20:01:34 |
I’ve had wires and cleaning fluid and an airline in all the holes,yet cannot find a connection between the nipple and hole shown in the picture? |
09/08/2022 16:56:57 |
09/08/2022 16:56:06 |
Hi all,The oil nipple on the backgear lever shaft is not linked to the tiny hole in the main body? So how does this get its oil? Or am I missing something? |
Thread: myford ml7 headstock pulley |
15/07/2022 08:19:49 |
eBay item number..... 334395184440 £40 |
Thread: Lathe Blowing Fuses |
14/07/2022 22:59:53 |
Here in the UK. You can fit a “C curve” RCD.to your garage mains circuit instead of the “B curve” type. This option is more suitable for inductive loads such as Motors,Fluorescent lights etc. google C curve RCD. |
Thread: Unknown backplate |
17/06/2022 13:55:45 |
Now sold,thanks to all. |
Thread: Myford ML7 clutch |
12/06/2022 23:12:02 |
You’re very lucky to have a clutch. Someone suggested using a masonry nail ! |
12/06/2022 07:15:42 |
Thanks Steve you nailed it. they are in fact to fit a Myford MG12 grinder. I will be selling these with or without the chucks soon. best wishes to all.BB. |
11/06/2022 16:06:44 |
Thread: Smart &Brown L.tailstock lever |
20/05/2022 16:39:03 |
Clive, Thank you so much for taking the time and effort to provide me with such a wealth of information. I now have yet another excuse to spend time in my workshop away from rubbish tv. Best regards, BB. |
