New lathe arrived with rust on the bed
John McCulla | 08/11/2022 16:05:39 |
28 forum posts 16 photos | Hi everyone, This is my first post, so please forgive me if I'm posting in the wrong place. I recently purchased my first lathe, a Warco 250V, and it arrived today. Unfortunately when I opened the box up the bed has what looks to me to be a significant amount of rust on it. My question is this, should I settle for cleaning the rust off or would I be a fool not to push for a replacement machine? |
duncan webster | 08/11/2022 20:24:29 |
5307 forum posts 83 photos | before doing anything physical I'd contact them and send some pictures. If you start any rectification it can invalidate the warranty, although by all accounts Warco are respectable |
Tony Pratt 1 | 08/11/2022 20:28:02 |
2319 forum posts 13 photos | Definitely speak to Warco asap Tony |
Frances IoM | 08/11/2022 20:29:22 |
1395 forum posts 30 photos | normally Chinese goods arrive coated in yellowish 'chicken fat' |
Pete. | 08/11/2022 20:54:29 |
![]() 910 forum posts 303 photos | If you're asking for an opinion on this a photo is essential, one persons opinion of bad condition could be seen as nothing serious to someone else. |
Jelly | 08/11/2022 21:16:39 |
![]() 474 forum posts 103 photos | There should 100% not be rust on the machine if it's brand new. . But (without seeing pictures, in which it may in fact be blatantly obvious rust) if it's just a slight yellow/orange bloom to the machined surfaces, then to avoid a red face I would wipe over a little patch with some white spirit on a rag, or otherwise somehow satisfy myself that it's not just a particularly grim looking cosmoline (other rust protective greases are available) application. So as to spare a red face when asking the supplier "why the [explietive]-ing [explietive] have you delivered a rusty machine to me". . That said if it appears to be just surface rust without any pitting, I would be inclined to:
Edited By Jelly on 08/11/2022 21:17:49 |
old mart | 08/11/2022 21:17:37 |
4655 forum posts 304 photos | If the lathe wasn't new, I would recommend simply rubbing the rust off with oily wire wool. Any stains left will be simply cosmetic, avoid abrasives like scotchbrite and wet and dry paper. Be polite to whoever you get in touch with and they will be much more likely to put things right without bother. Edited By old mart on 08/11/2022 21:20:21 |
John McCulla | 08/11/2022 21:50:15 |
28 forum posts 16 photos | I've attached some photos, it definitely seems to be rust. It's a brand new lathe, not second hand. I've already spoken to Warco, they asked me to send them some photos in an email and they'd get back to me. I guess what I'm wondering is should I push for a new lathe or would be fine to just clean it down with wire wool as already discussed. I'm totally new to using a lathe, and I don't want to end up putting any inaccuracy into the bed, the lathe wasn't cheap after all. This all may be a moot point, Warco may come back to me tomorrow and say they'll replace it, but it is a lot of hassle if it doesn't need done. |
Robert Atkinson 2 | 08/11/2022 21:55:37 |
![]() 1891 forum posts 37 photos | That does not look like a new lathe to me. Apart from the rust, look at the finish atoung the tailstock offset. |
Michael Gilligan | 08/11/2022 22:11:20 |
![]() 23121 forum posts 1360 photos |
. Dare I ask, John ? Is that water I can see ? … if so, is it Warco’s water ? MichaelG. |
John McCulla | 08/11/2022 22:37:47 |
28 forum posts 16 photos | No, that seems to be the only bit of oil that there is on the lathe bed. The rest seems totally dry. With regards to the finish around the tailstock, I had thought maybe that's just what you get with a chinese lathe, but as I said, this is my first one, so I'm no authority. |
Jelly | 08/11/2022 22:53:55 |
![]() 474 forum posts 103 photos | Posted by John McCulla on 08/11/2022 21:50:15:
It does indeed appear to be surface rust, and you most likely could remove it with no consequence... But you should absolutely expect some consession or reparation from Warco if you are going to do that. . To Roberts's point, the tailstock offset corrosion of is the most alarming and egregious... I'm not sure that means it's a used machine, my own interpretation of that photo is of long term exposure to moisture during transit allowing moisture to get under paint in a vulnerable area, which would fit with the lack of corrosion protective grease. But it's still not good and that area warrants further inspection if you are going to accept the machine. . My working thesis is that Warco has reached a level of integration with their suppliers that they can do their QC (which is generally pretty good, I have been impressed with Warco products when I have used them) in the country of origin... But for some reason that lathe wasn't properly prepared for export after inspection, and has been subjected to high humidity during its sea journey, and was then dispatched to you still in its crate without a second UK inspection. |
peak4 | 08/11/2022 23:04:44 |
![]() 2207 forum posts 210 photos | Hello and welcome John, have you spun the lathe up under power?
Pete. | 08/11/2022 23:05:18 |
![]() 910 forum posts 303 photos | I wonder if you might have received a display machine that was cleaned for display then boxed up again? If you do keep it you should expect something in return to tbe value of what it would cost Warco to replace, which would be two pallet courier trips. |
Ady1 | 08/11/2022 23:06:16 |
![]() 6137 forum posts 893 photos | I wouldn't be bothered about a bit of flash rust on the lathe, they are tough However if water has got in and corroded your electronics then it's a return job IMO For a "Brand new Lathe" it looks pretty rough to me, like it's been lying about. Maybe it was on that Evergreen job that was stuck in Suez Edited By Ady1 on 08/11/2022 23:10:03 |
ega | 08/11/2022 23:08:04 |
2805 forum posts 219 photos | I seem to recall that Warco used to inspect every machine themselves. It seems unlikely that the lathe left the factory without the usual protective grease. |
Michael Gilligan | 08/11/2022 23:11:46 |
![]() 23121 forum posts 1360 photos | Posted by John McCulla on 08/11/2022 22:37:47:
No, that seems to be the only bit of oil that there is on the lathe bed. […] . Thanks … that’s one theory out of the window MichaelG. |
Bill Phinn | 08/11/2022 23:26:36 |
1076 forum posts 129 photos | If this isn't a case of the manufacturer failing, unaccountably, to slather the ways et al. with grease before crating, I'd say it's a customer return that was left at Warco's storage facility for some time in the state in which it was returned [i.e. ungreased] and then re-crated and shrink-wrapped without much examination for delivery on to you. Is there any indication that on/off switches have ever been pressed by grubby fingers, a chuck key has ever turned in the chuck key recesses, or the chuck itself has ever gripped anything? |
Swarf Maker | 09/11/2022 01:15:31 |
132 forum posts 7 photos | In addition to what has already been said. it may be an artifact of the photos or lighting, but it appears that the paint is 'dirty' in several areas and is that black oil descending from the headstock behind the chuck? Has all the appearance of a 'returned' item. The lack of 'chicken fat' grease supports that idea. Initial purchaser cleaned it up for use, but then found other faults to require its return. I bought a lathe from Warco and went to collect it. "Oh dear, it hasn't been checked or tested", I was told. No matter, the lid was prized from the box, the plug inserted, button pushed, chuck rotated. "There, all OK and good to go". Appropriate pre-delivery check? - I don't think so! Another incident was with one of the larger milling machines (not mine). Spindle had seized bearing(s) from the very start. A friend bought a 'combination' lathe/mill. No more than a dozen or so hours light use and the milling spindle lower bearing just disintegrated. By then, out of warranty. For the sake of balance, other people have had much better experiences! Edited By Swarf Maker on 09/11/2022 01:18:56 |
Pete. | 09/11/2022 01:42:23 |
![]() 910 forum posts 303 photos | Posted by Swarf Maker on 09/11/2022 01:15:31:
In addition to what has already been said. it may be an artifact of the photos or lighting, but it appears that the paint is 'dirty' in several areas and is that black oil descending from the headstock behind the chuck? Has all the appearance of a 'returned' item. The lack of 'chicken fat' grease supports that idea. Initial purchaser cleaned it up for use, but then found other faults to require its return. I didn't notice that dirty oil drip from the spindle, I'd be inclined to refuse the machine after checking the price, £2750 is a lot of money. |
