Michael Gilligan | 16/09/2022 09:12:57 |
![]() 23121 forum posts 1360 photos | Sorry for putting this in The Tea Room, but there isn’t a Coffee Bar topic available Can anyone recommend a compact coffee grinder that works well ? … by that, I mean one that grinds beans into a fine powder. I currently use a Bodum 5678, which is about the right size, but doesn’t produce a good powder unless I wave it about to re-distribute the beans ! It is also ridiculously heavy … being a flimsy little machine wrapped in a shiny die-cast shell and is difficult to empty into my small cafetière. [no, I don’t like it much] The size and capacity are about right for my needs, but the performance and handling are not. MichaelG. . P.S. __ the current equivalent [sans the heavy overcoat] is probably this: https://www.bodum.com/gb/en/11160-01uk-3-bistro … so don’t bother recommending that one |
Howi | 16/09/2022 09:34:14 |
![]() 442 forum posts 19 photos | I have one almost identical but under a different name. That type of grinder will NOT produce a fine powder, despite what the advertising says, it is ok for coarse or medium grind but that type of blade grinder cannot produce a fine grind, for that you need the type that uses ceramic grinding wheels. If, as you say, you are using a cafetiere then you do not need a fine grind, medium grind is ideal. The pressure type of coffee machines (the ones used in cafe's etc) does need a fine grind, in order to extract as much coffee flavour out of the beans. When using a cafetiere, the strength of the coffee beans is more important, I try for a high strength rating of 5 or more if used to produce cappachino or latte style coffee, anything below that strength and you don't get a full flavour coffee - all my opinion of course, others may differ. |
Kiwi Bloke | 16/09/2022 09:38:14 |
912 forum posts 3 photos | Agreed - fine is best reserved for for espresso. How about an old-fashioned, hand-cranked Spong? No electrickery bits to fail, and the built-in failure time limit must be a century, at least! |
Michael Gilligan | 16/09/2022 09:57:06 |
![]() 23121 forum posts 1360 photos | Howi I am only using the cafetière to economise on space in a very small kitchen I drink my coffee at ‘espresso’ strength, but am obliged to improvise: I usually pour one small shot and leave the rest to go cold, thus extracting all I can from the [excessively] coarse grind. … I am currently using too many beans MichaelG. . . Edited By Michael Gilligan on 16/09/2022 10:05:35 |
Michael Gilligan | 16/09/2022 10:11:48 |
![]() 23121 forum posts 1360 photos | Posted by Howi on 16/09/2022 09:34:14:
… cannot produce a fine grind, for that you need the type that uses ceramic grinding wheels.
. Which gets us back to the opening question … Can anyone recommend a compact coffee grinder that works well ? … by that, I mean one that grinds beans into a fine powder. MichaelG. |
Kiwi Bloke | 16/09/2022 10:29:19 |
912 forum posts 3 photos | I did! Spong! |
Michael Gilligan | 16/09/2022 10:32:51 |
![]() 23121 forum posts 1360 photos | Posted by Kiwi Bloke on 16/09/2022 10:29:19:
I did! Spong! . Thanks .. but how compact are they ? … It’s O.K. that was just a rhetorical question; I will investigate. MichaelG. . Mmm __ even the Robert Welch one might not fit the available space Edited By Michael Gilligan on 16/09/2022 10:36:35 |
pgk pgk | 16/09/2022 10:48:12 |
2661 forum posts 294 photos | Something sold as a spice grinder or coffee and spice grinder should give a finer grind. Coffee is a personal thing but I gave up bothering with bean grinding or high strength variants or even long duration perculation etc. Currently quite happy with the rich flavour of Lidl Kenyan with a short stand time in cafetiere.. can always increase amount. It's economical is excellent IMO and the grind stays fresh so long as well folded over and a decent bulldog clip. Even more kitchen space saved?
Ady1 | 16/09/2022 10:56:46 |
![]() 6137 forum posts 893 photos | I find Nescafe very good, no mess, nice taste mmmmmm |
Martin Kyte | 16/09/2022 11:02:46 |
![]() 3445 forum posts 62 photos | Mortar and Pestle? regards Martin |
gary | 16/09/2022 11:41:16 |
164 forum posts 37 photos | as said above a blade type grinder is no use for a fine grind. i use a mallita mollino which can be adjusted to suit and has grinding wheels. it is about six years old and still working great. when i started looking for a good grinder i got a shock at the cost of some of them. good luck michael. |
peak4 | 16/09/2022 13:21:30 |
![]() 2207 forum posts 210 photos | I've had a Nemox Lux for several years, which I picked up cheaply off eBay as it was an unbranded machine. Same factory, but no brand name on it; I'd highly recommend one, but the footprint might be a bit large, as well as the price. |
Paul Rhodes | 16/09/2022 13:32:31 |
81 forum posts | Agree with PGK. |
Michael Gilligan | 16/09/2022 15:44:46 |
![]() 23121 forum posts 1360 photos | Thanks for the Krups reference, Bill MichaelG. |
Mick B1 | 16/09/2022 16:27:42 |
2444 forum posts 139 photos | I've found that cheap blade grinders are perfectly capable of producing a dust-fine grind if that's what you want. My objection to them is that the friction of the blade through the grounds locally overheats them and 'darkens' the flavour. Nevertheless they're cheap, widely available, and able to produce a drinkable grind if you run them in bursts with a couple of seconds' cooling-rest between, and stop when the biggest grounds are about sugar-grain sized. I'm unhappy with the length of time this takes, but unwilling to pay the higher price for a burr-grinder until I can see one that works to my liking - but it's very rare to see one in a shop rather than online, less still at a sensible price. All of which means that up to now I've more-or-less decided it's easier to live with the blade grinder. So many things in engineering end up being a compromise... Guess that's because nothing is ever perfect, nor can it be.
Edited By Mick B1 on 16/09/2022 16:33:51 |
peak4 | 16/09/2022 17:04:33 |
![]() 2207 forum posts 210 photos | Posted by Mick B1 on 16/09/2022 16:27:42:
..................but it's very rare to see one in a shop rather than online, less still at a sensible price. ....................... Edited By Mick B1 on 16/09/2022 16:33:51 Currys list quite a few, including the Krupps one I mentioned earlier, but not sure how many are displayed in store, rather than delivered to store for collection. |
Mikelkie | 16/09/2022 19:02:08 |
![]() 135 forum posts 13 photos | My SPONG & CO works well still probably 80 plus years old!! |
pgk pgk | 16/09/2022 19:33:56 |
2661 forum posts 294 photos | Off grinder topic coffee comments.
pgk
Andy Stopford | 16/09/2022 20:29:06 |
241 forum posts 35 photos | I have an older version of this: https://www.dualit.com/products/coffee-grinder Pricey, but still going strong after 20 years' daily use. It's a burr type and produces the fine grind required by my commercial espresso machine. |
Nealeb | 16/09/2022 20:53:19 |
231 forum posts | I use a similar Dualit to Andy, again with an espresso machine. I found the spinning blade grinder to be too unpredictable - the Dualit is a "press the button and it's done" thing. And anyway, I broke the blade trying to grind something too hard for it. Must admit, though, I'm not really a coffee gourmand - just someone who drinks a lot of the stuff! On a related topic - I have a coffee plant in my hall that is absolutely covered in coffee berries, but I have no idea when they are supposed to be picked. Would like to brew my own-grown and roasted coffee at least once, just to say I had done it! |
