Michael Gilligan | 13/04/2022 18:26:28 |
![]() 23121 forum posts 1360 photos | I had left our oven for a few weeks without cleaning,, so I set about it this morning. We use Olive Oil for roast vegetables, and unfortunately its splashes bake hard on the [enamel] panels of the oven. After several hours of pretty fruitless hard-labour, I decided to search for advice Google found several recommendations for the use of a paste made from Baking Soda and Vinegar … So I tried that, and it works amazingly well !! So my question is: Can someone please explain the chemistry ? MichaelG. |
duncan webster | 13/04/2022 18:33:46 |
5307 forum posts 83 photos | No, but I have 2 approaches to cleaning ovens
I haven't got enough years eft to waste them cleaning ovens! |
Thor 🇳🇴 | 13/04/2022 18:53:59 |
![]() 1766 forum posts 46 photos | You get carbon dioxide gas, water and sodium acetate, we used to put it in a bottle to create a volcano, or to unclog a drain. Thor |
SillyOldDuffer | 13/04/2022 18:59:20 |
10668 forum posts 2415 photos | Posted by Michael Gilligan on 13/04/2022 18:26:28:
I had left our oven for a few weeks without cleaning,, so I set about it this morning. We use Olive Oil for roast vegetables, and unfortunately its splashes bake hard on the [enamel] panels of the oven. After several hours of pretty fruitless hard-labour, I decided to search for advice Google found several recommendations for the use of a paste made from Baking Soda and Vinegar … So I tried that, and it works amazingly well !! So my question is: Can someone please explain the chemistry ? MichaelG. As much physics as Chemistry I think! Baking Soda (Sodium Bicarbonate) is abrasive, and Acetic Acid attacks Grease, so rubbing the combination into the muck will break up the surface. The acid also reacts with the Bicarbonate to produce bubbles of Carbon Dioxide, many of which will be inside the cracks, crevices and pores of the grease. Although the bubbles are tiny, the pressure exerted as they emerge is enormous. Very difficult to stop a chemical reaction with pressure, as this ex-gun barrel shows! Dave |
Robert Atkinson 2 | 13/04/2022 19:00:44 |
![]() 1891 forum posts 37 photos | Mixing vinegar and bicarbonate of soda while visually impressive does not make a good cleaner. Try them on their own next time. Mixing them basically makes water and CO2 with possibly a tiny amount of sodium nitrate (lye) but it's insignificant. Robert G8RPI. |
pgk pgk | 13/04/2022 19:03:25 |
2661 forum posts 294 photos | I'll admit I see no logic to mixing the two together. If it worked for you then fine. When I needed to clean my oven I found reference to using just baking soda and set too with a will..and ended up with a god-awful mess of caked baking soda on the oven surfaces that took ages to clean off - particularly out of the creases and around the seals. Since then I've just trained myself to wipe the oven out after any usage with eco washing up liquid solution. pgk |
Michael Gilligan | 13/04/2022 19:03:41 |
![]() 23121 forum posts 1360 photos | Posted by Thor 🇳🇴 on 13/04/2022 18:53:59:
You get carbon dioxide gas, water and sodium acetate, […] . Thanks for that, Thor So … does that cocktail react in any peculiar way with Olive Oil ‘lacquer’ ? MichaelG. |
Michael Gilligan | 13/04/2022 19:12:12 |
![]() 23121 forum posts 1360 photos | Just for clarity … Messy as it is: the process is orders-of-magnitude more effective than anything else I tried [and much safer to use than the dreaded Mr Muscle]. MichaelG. |
Peter Greene | 13/04/2022 19:16:48 |
865 forum posts 12 photos | Posted by Robert Atkinson 2 on 13/04/2022 19:00:44:
Mixing them basically makes water and CO2 with possibly a tiny amount of sodium nitrate (lye) but it's insignificant. ... and here's me believing for years that lye is sodium hydroxide. |
Thor 🇳🇴 | 13/04/2022 19:16:58 |
![]() 1766 forum posts 46 photos | Hi Michael, Using baking soda alone to scrub your oven will clean it as it is abrasive, as Dave says the carbon dioxide gas made when mixed with vinegar helps mix and agitate to move dirt particles. Better explanations:
Thor |
Ady1 | 13/04/2022 19:31:51 |
![]() 6137 forum posts 893 photos | cif can be pretty impressive against baked grease |
Michael Gilligan | 13/04/2022 19:33:38 |
![]() 23121 forum posts 1360 photos | Thanks to Dave and Thor … I am reminded of a previous thread on this forum, about micro-bubbles generated in canine toothpaste. I am happy to believe that the underlying process is generally similar. MichaelG. . Ref. https://www.model-engineer.co.uk/forums/postings.asp?th=144313&p=1 Edited By Michael Gilligan on 13/04/2022 19:36:14 |
Georgineer | 13/04/2022 21:29:27 |
652 forum posts 33 photos | Posted by Peter Greene 🇨🇦 on 13/04/2022 19:16:48:
Mixing them basically makes water and CO2 with possibly a tiny amount of sodium nitrate (lye) but it's insignificant. ... and here's me believing for years that lye is sodium hydroxide. I'd like to learn how to make sodium nitrate from acetic acid. George |
bernard towers | 13/04/2022 22:19:02 |
1221 forum posts 161 photos | Lakeland Ovenmate for me |
Clive Hartland | 13/04/2022 22:22:38 |
![]() 2929 forum posts 41 photos | I have seen dish washer tabs rubbed onto the surfaces clean the glass doors. |
Robin Graham | 14/04/2022 01:01:26 |
1089 forum posts 345 photos | Posted by Michael Gilligan on 13/04/2022 19:33:38:
Thanks to Dave and Thor … I am reminded of a previous thread on this forum, about micro-bubbles generated in canine toothpaste. I am happy to believe that the underlying process is generally similar. MichaelG. . Ref. **LINK** Edited By Michael Gilligan on 13/04/2022 19:36:14 I think you're right to be happy in that belief Michael. I use a 15% solution of sodium hydroxide with a bit of surfactant myself. It works well, but it's messy and even at that concentration it takes several hours for the chemistry to work. I shall certainly try the vinegar/bicarb method! On the chemistry front I'm pretty skeptical about claims that vinegar 'attacks' grease in a chemical way. It's certainly true that grease can be broken down by dilute acid (acid hydrolysis of esters), but I doubt that the reaction is significant in cleaning an oven. Possibly it has some mild solvent action? On canine tooth cleaning - I don't think I reported back on my plan to use the ultrasonic toothbrush for rust removal. Pure funk I'm afraid. The risk of domestic disharmony if it went wrong was too great. I expect it would work though. Might be good for cleaning ovens (slowly) as well. Robin Edited By Robin Graham on 14/04/2022 01:03:16 |
AdrianR | 14/04/2022 08:41:42 |
613 forum posts 39 photos | Try Borax Substitute (sodium sesquicarbonate), mix it to a paste with water, rub it in and leave a while. Not as good as Sodium Hydroxide, but a lot safer. I had a problem with a sticky yellow stain from cooking oil on my plastic mixer bowl, it was removed in minutes. It also removes the sticky yellow that builds up around the cooker.
Anthony Kendall | 14/04/2022 08:44:28 |
178 forum posts | Posted by duncan webster on 13/04/2022 18:33:46:
I haven't got enough years eft to waste them cleaning ovens! Well said Duncan - with you all the way. There are other similar things e.g. cutting lawns, cleaning cars, the possibilities are endless! |
martin perman | 14/04/2022 09:18:49 |
![]() 2095 forum posts 75 photos | There is one other method, my wife gets a guy in to clean the oven, I do my best to keep the glass top clean. Martin P |
SillyOldDuffer | 14/04/2022 09:44:50 |
10668 forum posts 2415 photos | Posted by Robin Graham on 14/04/2022 01:01:26:
Thanks to Dave and Thor … I am reminded of a previous thread on this forum, about micro-bubbles generated in canine toothpaste. I am happy to believe that the underlying process is generally similar. MichaelG. . Ref. **LINK** Edited By Michael Gilligan on 13/04/2022 19:36:14 ... On the chemistry front I'm pretty skeptical about claims that vinegar 'attacks' grease in a chemical way. It's certainly true that grease can be broken down by dilute acid (acid hydrolysis of esters), but I doubt that the reaction is significant in cleaning an oven. Possibly it has some mild solvent action? ...That's what I was hinting at when I said the answer was as much to do with physics as chemistry. Dilute Acetic Acid isn't like Caustic Soda, which attacks fats aggressively; Vinegar only has a mild dissolving effect. Simply splashing vinegar on a dirty oven won't get it clean. It's important that the Bicarbonate / Acid mix be a paste, in which the Bicarbonate and Acid are slowly reacting to produce micro-bubbles, AND there are plenty of sharp Bicarbonate crystals to act as an Abrasive, AND there's enough fluid to penetrate tiny cracks and crevices, AND the paste is rubbed in enthusiastically by the operator. Works in much the same way as soapy Brillo-pad, except the Brillo pad abrades with steel-wool, soap breaks up the fat and there are no micro-bubbles. Cleaning an oven with a solution of Sodium Acetate made by carefully neutralising Sodium Bicarbonate with Vinegar is a waste of time. It's not reactive or abrasive and there are no micro-bubbles. Caustic Soda paste, made with water, can be splashed on and left. The alkali breaks fats up, so the operator can leave the oven to soak and wash the whole lot off with water a few hours later. Sodium Bicarbonate would do the same but take a lot longer. Anyone tried Isopropyl alcohol? Apart from the cost, fumes, and fire hazard I think it might work well. Ditto petrol... Dave
