Andrew Tinsley | 28/03/2022 20:56:45 |
1817 forum posts 2 photos | I am running out of my stock of liquid Plus Gas. Searching seems to reveal that it is no longer available, only aerosols seem to exist! Anyone know if and where the liquid variety can be found? I am not a fan of aerosols as it seems to be an uneconomic way of using the stuff! Andrew. |
Michael Gilligan | 28/03/2022 21:07:21 |
![]() 23121 forum posts 1360 photos | Search eBay for PlusGas 500ml MichaelG. |
Nicholas Farr | 28/03/2022 21:31:36 |
![]() 3988 forum posts 1799 photos | Hi Andrew, Plus Gas 1 Litre you can also find some on Amazon if you use them. Regards Nick. |
Michael Gilligan | 28/03/2022 21:39:22 |
![]() 23121 forum posts 1360 photos | That’s a very decent price, Nick MichaelG. |
Nick Wheeler | 28/03/2022 21:58:40 |
1227 forum posts 101 photos | Posted by Michael Gilligan on 28/03/2022 21:39:22:
That’s a very decent price, Nick MichaelG. Not when you can buy 5litres of non-branded penetrating fluid for about £25... |
Michael Gilligan | 28/03/2022 22:44:36 |
![]() 23121 forum posts 1360 photos | If you say so, Nicholas But I’ve been using PlusGas Formula A for at least 40 years now, and I doubt if I would bother changing … I only use small quantities anyway. MichaelG. Edited By Michael Gilligan on 28/03/2022 22:46:04 |
Nick Wheeler | 28/03/2022 23:37:10 |
1227 forum posts 101 photos | I've used most of them over the last 35 years. They all sort of work. The best one is whatever I can scrounge from work. Otherwise, I use whatever is on the shelf of the motor factor/engineering supply/Ebay when I need to get some more. |
Mark Rand | 29/03/2022 09:48:38 |
1505 forum posts 56 photos | I'm also in the situation of running out. Unfortunately, I don't believe that Rapidtools have any in stock. I ordered two litres from them in February and the money was refunded the next day with no explanation... I don't think the 1 litre tin has been available for some years. but the 500ml one is still out there for us stick in the muds.
David-Clark 1 | 29/03/2022 10:37:45 |
![]() 271 forum posts 5 photos | I used plus gas as a lubricant for pressing out zinc washers back in the 1960s. |
Clive Foster | 29/03/2022 11:20:03 |
3630 forum posts 128 photos | My understanding is that, as well as being a penetrating lubricant, real Plus Gas Formula A is able to draw out the included water from rust reducing its volume and hence the sticktion between a rusted in bolt and its nut or rusted shaft and its housing. Which obviously makes things easier to turn or move. A pure penetrating oil merely lubricates the various surfaces, whether between rust and component or between prust particles to ease movement. I have in the past seen several applications of Plus Gas A reduce the binding of a rusted in shaft from immobile with a hammer to stiff hand pull out levels so I'm inclined to believe the claims. But it does need time to work. Overnight is good. WD40 is always to hand and gets used more than it should for all sorts of things despite being pretty crap at everything compared to the job specific special sauces. Clive |
Andrew Tinsley | 29/03/2022 14:29:27 |
1817 forum posts 2 photos | Several companies do a "penetrating oil" that goes by the name of DW-40.,notably Smith Allan and Westway Seems that these are genuine companies that blend some of their products. Just wondering if these are knock offs of WD 40 or are they any good as a penetrating oil? they are priced at £20 for 5 litres, which is a goodly bit cheaper than Plus Gas at £16 for 500 ml I wonder if Nicholas has tried either of them? Andrew. |
Georgineer | 29/03/2022 15:00:02 |
652 forum posts 33 photos | Don't forget that the makers of WD40 now market a whole range of products under the WD40 name, including a penetrating fluid. Mind you, when we ran out of Plus Gas in the 1970s, Dad re-filled the tin with a 50/50 mix of light oil and paraffin. We used it for years and never noticed a difference. George
Mark Rand | 29/03/2022 15:11:47 |
1505 forum posts 56 photos | I've just been told by another seller (Toolite) that they are out of stock of 500ml tins and their wholsaler is not expecting any until June. |
Mike Crossfield | 29/03/2022 15:16:17 |
286 forum posts 36 photos | I haven't got round to trying it myself yet, but Ferrosol from Bilt Hamber gets some very good reviews. Seems to be much more than just a penetrating fluid. https://bilthamber.com/product/ferrosol/ I have used several Bilt Hamber products, mainly on the car, and they have all been excellent, so I would be surprised if this wasn't good as well. Mike |
Andrew Tinsley | 29/03/2022 15:43:11 |
1817 forum posts 2 photos | Just to confirm that Rapid Tools have no stock and don't know when they will get any. Andrew. |
Trevor Drabble | 29/03/2022 15:52:45 |
![]() 339 forum posts 7 photos | I believe D&M Tools sell it . Always had good service from them in the past . No connection other than as a customer . |
Bob Unitt 1 | 30/03/2022 12:00:26 |
![]() 323 forum posts 35 photos | I just squirt the aerosol into a jam-jar, and use the resulting liquid, which seems to work as well as the old-style plus-gas did. |
Robert Atkinson 2 | 30/03/2022 12:41:04 |
![]() 1891 forum posts 37 photos | A 50:50 mix of acetone and automatic transmission fluid has a good reputation. Robert G8RPI |
Circlip | 30/03/2022 13:06:03 |
1723 forum posts | Nearly bought a gallon of WD40 years ago @£26 but was advised by a supplier to buy 'Duck Oil' @ £12 a gallon. Worked for me. Regards Ian. |
Andrew Tinsley | 30/03/2022 13:17:08 |
1817 forum posts 2 photos | I don't believe in the ATF and acetone mix. I have tried several brands of ATF and find that the two are immiscible. They separate out in seconds when you try to mix them. Anyone actually used this mix? if so can they tell me which ATF is miscible in acetone? Andrew. |
