Robin Graham | 18/02/2022 23:38:38 |
1089 forum posts 345 photos | I have a project which would be easier if I could use in line connectors like this: I've tried various search terms, but failed to find them so far. Ideally I'd like single, two, three and four way connectors which can be connected to the wires without any more specialised equipment than a crimping tool or soldering iron. Can anyone help? Robin.
oldvelo | 19/02/2022 01:01:49 |
297 forum posts 56 photos | The round pin "Molex" connections come in multiple sockets. click on the link Molex |
AJAX | 19/02/2022 06:50:12 |
433 forum posts 42 photos | Do a search for JST connectors. |
Paul Lousick | 19/02/2022 06:50:23 |
2276 forum posts 801 photos | Electronic part suppliers should have them. We have local shops called Jaycar and I believe that they are in the UK as well. |
AJAX | 19/02/2022 06:53:30 |
433 forum posts 42 photos | Oops, just noticed the red arrow pointing to the off board connector. I was looking at the PCB. If you want an incredibly simple in line connector, how about a straight through WAGO style connector? |
Former Member | 19/02/2022 09:19:13 |
1085 forum posts | [This posting has been removed] |
noel shelley | 19/02/2022 10:00:07 |
2308 forum posts 33 photos | 3M Scotchlok are a recipe for disaster ! To the best of my knowledge they are only made to piggy back one wire onto another, the connector is made for a given size of conductor - wire small = poor connection and wire to big cuts conductor that then breaks. They have kept many auto electricians in a job ! Noel. |
Circlip | 19/02/2022 10:13:23 |
1723 forum posts | Hmm, Scotchloks, IDC (Insulation Displacement Connector) as stated. a pain for auto electrical quick connections. Strangely enough, a smaller versions favoured by the telecoms companies for both internal socket and external extension connection. Regards Ian.
Edited By Circlip on 19/02/2022 10:13:48 |
Nick Hughes | 19/02/2022 10:52:55 |
![]() 307 forum posts 150 photos | For this sort of application (depending on the current capacity) I use automotive connectors, https://www.autoelectricsupplies.co.uk/product/37/category/7 https://www.autoelectricsupplies.co.uk/product/683/category/7
Edited By Nick Hughes on 19/02/2022 10:57:25 |
Clive Brown 1 | 19/02/2022 13:48:19 |
1050 forum posts 56 photos | The component indicated in the photo. doesn't look like any Scotchloc that I've used. Seems to be the male half of a 2-pin connector, but I don't know the spec. |
Former Member | 19/02/2022 14:40:06 |
Bezzer | 19/02/2022 16:06:54 |
203 forum posts 16 photos | Posted by Circlip on 19/02/2022 10:13:23:
Edited By Circlip on 19/02/2022 10:13:48 The telecom ones are usually called Jelly Crimps,(they're full of a gel) , commonly 2 or 3 way and should only be used on single core cable as they will shred stranded cores.. I used loads of them when I wired track power droppers all over an OO layout with no problems. |
Old School | 19/02/2022 17:37:07 |
426 forum posts 40 photos | Have you tried the Component Shop. https://www.componentshop.co.uk/leads/connectors.html?p=8 |
Robert Atkinson 2 | 19/02/2022 19:15:56 |
![]() 1891 forum posts 37 photos | +1 for JST connector.
Robert G8RPI. |
SillyOldDuffer | 19/02/2022 19:42:53 |
10668 forum posts 2415 photos | The type pictured by Robin might be an XH connector. I like Powerpole Connectors and posted about them about halfway down this forum page. They're a bit clunky though for light electronic work. Dave |
Robin Graham | 19/02/2022 20:08:29 |
1089 forum posts 345 photos | Thanks for replies - all very helpful. I should have been more explicit perhaps - what I'm looking for is the in line type of connector pointed to by the red arrow. The board in the pic is the 'brain' of a toy pony - the various wires bring in signals from sensors on the toy's body and actuate motors which move the head etc. My task is to remount the sensors and motors in a much bigger frame for a theatrical prop, so I need to extent the wires. Following the links it looks like JST connectors are intended only for PCB headers rather than in - line? It looks like automotive connectors are the things I want. I can get a box of 40 assorted from Amazon for a tenner - probably pretty flimsy compared to the more expensive connectors suggested in some replies, but will do the job for what I want I daresay. The thing is powered by six D batteries, so max 9V and not much current I guess. Thanks again, Robin.
Mark Rand | 19/02/2022 21:16:55 |
1505 forum posts 56 photos | I probably shouldn't suggest this, even though the connector is vaguely familiar, but:- 15W Antex with 60/40 solder.
I'll get my coat... Edited By Mark Rand on 19/02/2022 21:17:19 |
Robin Graham | 19/02/2022 23:32:27 |
1089 forum posts 345 photos | Posted by Mark Rand on 19/02/2022 21:16:55:
I'll get my coat... Edited By Mark Rand on 19/02/2022 21:17:19 Eee, there's always one Dave - thanks for the link to Powerpole connectors. They might well be useful for something else, but probably overkill for this project. Robin.
Mark Rand | 20/02/2022 10:01:17 |
1505 forum posts 56 photos | Would this be the variety that you need? |
Robin Graham | 06/03/2022 00:32:12 |
1089 forum posts 345 photos | Well, this has been an eye-opener. I bought a box of connectors (DuPont and JST) together with a new crimping tool which works with both. £35. But not quite right for what I wanted to do or the wire gauges I had to work with. So I investigated further. JST have a range, according to their website, of more than 30,000 styles. Then there's Molex and others. The right things must be out there, but this rabbit hole is too deep for me. I shall resort to the trusty soldering iron as Mark advised, and heat shrink. Thanks for all the advice though - it's been an interesting journey into the weird world of electrical connectors. Robin
