Clive Hartland | 06/02/2022 15:09:42 |
![]() 2929 forum posts 41 photos | My car a VW lives outdoors. We live in a wooded semi rural area. The car roof rails have a green growth along the crevices. Also on the trim under the doors. The felt liners that the windows have as a seal also get this green growth. Any suggestions of how to prevent, remove, fix. |
David George 1 | 06/02/2022 15:16:35 |
![]() 2110 forum posts 565 photos | Try burning coal near to the vehicle as the soot and fall out prevents the growth of moss and lichens. We never used to get such growths til the clean air act. David |
Martin King 2 | 06/02/2022 15:19:30 |
![]() 1129 forum posts 1 photos | Hi All, the best case of this green stuff used to be in the sliding window channels of early Mini’s, you could grow potatoes in a good example! Cheers, Martin |
blowlamp | 06/02/2022 15:21:20 |
![]() 1885 forum posts 111 photos | Use a pressure washer?
Martin. |
Clive Hartland | 06/02/2022 15:23:23 |
![]() 2929 forum posts 41 photos | David, I have'nt got a chimney, the whole area is surrounded by woodland. I am going to try a mild vinegar solution to see if it helps. The houses around here are all less than 20 years old, so are built to the clean air act. It is an estate car and now I have found it under the edge of the rear door where it festers unseen!
Clive Hartland | 06/02/2022 15:29:18 |
![]() 2929 forum posts 41 photos | I have a pressure washer so that is one answer, thanks blowlamp. |
pgk pgk | 06/02/2022 15:31:23 |
2661 forum posts 294 photos | It happens here for the same reasons. OH doesn't wash her car and the previous one had moss growing even on the main panels - took me a goodly while to clean it before trade-in after being unwashed for 7 years. pgk |
Spurry | 06/02/2022 15:31:46 |
227 forum posts 72 photos | A pressure washer will definitely get rid of it, on a temporary basis, but be very careful near the rubber seals as they can be damaged with just a little too much pressure. (Experience teaches!) |
peak4 | 06/02/2022 15:33:07 |
![]() 2207 forum posts 210 photos | I wish I knew the answer, as we have the same problem at our house in Buxton. |
Speedy Builder5 | 06/02/2022 15:37:26 |
2878 forum posts 248 photos | Clive, try planting it. You never know, you may get a younger model ! I get the same on my front gates. Pressure washing does get it off, but it is difficult to get it out of the crevices of the scroll work and it comes back every couple of years. I did wonder about bleach which is what they use (in some form) on roof tiles to remove moss. I made a wooden garage out of Douglas fir and treated it with this product Treatment . 3 years down the line and not a spot of "green stuff" and the garage is overshadowed by an ash tree on one corner and a plum tree on another, but no idea as to what it would do on rubber/metal etc. This product is available in the UK UK supplier and for those building wooden sheds etc, I can heartily recommend it. Bob |
Martin Kyte | 06/02/2022 16:16:14 |
![]() 3445 forum posts 62 photos | If it's green then it will be photo synthesising so reducing the light may slow things down a little. Try painting it with a solvent like IPA or maybe try one of the mould killers sold for bathrooms. regards Martin Edited By Martin Kyte on 06/02/2022 16:17:06 |
Robert Atkinson 2 | 06/02/2022 16:21:47 |
![]() 1891 forum posts 37 photos | Best treatment for this is benzalkonium chloride. A detergent and biocide. Available in several forms including patio cleaner. I use Dettol's washing machine cleaner as a source. Dilute 50:50 or 30:70 with water and spray or brush on the green stuff Leave for a few hours and wash off. Helps prevent re-growth. https://en.wikipedia.org/wiki/Benzalkonium_chloride https://www.dettol.co.uk/household-disinfection/laundry/dettol-washing-machine-cleaner-original-250-ml/ Robert G8RPI. |
Tim Stevens | 06/02/2022 16:26:36 |
![]() 1779 forum posts 1 photos | Just remember the rules about using herbicides etc - use them for what they are for, and not otherwise. Something to do with not destroying the planet. I have seen shed roofs crossed by old wireless aerials - plain uninsulated copper. The line where the drips from the aerial fell had no moss and no lichen. Just a thought. Tim |
RMA | 06/02/2022 16:45:58 |
332 forum posts 4 photos | I use sulphate of iron to kill moss on lawns and paths. My car suffers to some extent on one side. That's the side that is mainly hidden from the sun. I turn it round when I think of it and it goes. Be careful with pressure washers, they can reach parts you didn't know existed and they'll strip graphics in no time |
Speedy Builder5 | 06/02/2022 16:47:25 |
2878 forum posts 248 photos | Tim, zinc does the same. No moss below the zinc flashings. |
HOWARDT | 06/02/2022 16:57:38 |
1081 forum posts 39 photos | I think it is more a case of cleaning the vehicle more often. A car I saw the other day was more living green than dead paint. It never seemed to be a problem, perhaps modern water based paints are more prone than older cellulose based ones, |
Emgee | 06/02/2022 17:01:19 |
2610 forum posts 312 photos | I have found pressure washing is liable to lift paintwork if there are any chipped areas so now use it with care but a stiff hand brush soon cleans the growth from widow seals. If still available diluted JEYES fluid disinfectant clears and helps reduce further growth. Emgee |
Nicholas Farr | 06/02/2022 17:13:12 |
![]() 3988 forum posts 1799 photos | Hi, I get the same problem on my car, I scrape it off with a small plastic scraper when it gets too bad to look at it. Regards Nick. |
Robert Atkinson 2 | 06/02/2022 17:29:21 |
![]() 1891 forum posts 37 photos | I suggested benzalkonium chloride because: Robert G8RPI.
Clive Hartland | 06/02/2022 22:05:45 |
![]() 2929 forum posts 41 photos | All good info, I will report back soon. Clive |
