Clive Hartland | 26/07/2021 22:00:37 |
![]() 2929 forum posts 41 photos | I recently bought some AA batteries, a box of 40. Needing to change the batteries in the house fone I tipped out the old ones and inserted the new fresh ones but found that the + contact did not reache the contact in the battery holder. I am convinced that the new batteries + end is shorter than it should be. I will now have to commit surgery on the battery box to cut away part of it to allow full contact. The batteries came from a reputable supplier. |
Grindstone Cowboy | 26/07/2021 22:11:36 |
1160 forum posts 73 photos | I've been finding this more and more recently - but I also think the length of the cells is increasing as they appear to be harder to fit into the available space. Duracell seem to be the major culprits, but I've also noticed that Panasonic Eneloop rechargeables are bigger than the traditional cells. Things like Nikon Speedlights seem to have enough latitude built-in to cope, but older TV remotes are definitely on the lower end of the tolerances. Rob |
Michael Gilligan | 26/07/2021 22:40:08 |
![]() 23121 forum posts 1360 photos | Energizer quotes “industry standard” dimensions : **LINK** https://data.energizer.com/pdfs/l91.pdf I would be interesting to know how yours compare MichaelG. |
AJAX | 26/07/2021 22:44:19 |
433 forum posts 42 photos | Posted by Clive Hartland on 26/07/2021 22:00:37:
I recently bought some AA batteries, a box of 40. Needing to change the batteries in the house fone I tipped out the old ones and inserted the new fresh ones but found that the + contact did not reache the contact in the battery holder. I am convinced that the new batteries + end is shorter than it should be. I will now have to commit surgery on the battery box to cut away part of it to allow full contact. The batteries came from a reputable supplier. Was that a BT cordless phone by any chance? I had exactly the same problem when I changed batteries but when I prised the spring clips out a bit it was enough to make good contact. Alternatively I could have bought the BT approved/branded replacements instead at an inflated price. Update - my phone uses AAA and not AA batteries. |
Grindstone Cowboy | 26/07/2021 23:11:22 |
1160 forum posts 73 photos | Some rough measurements using digital calipers Duracell AA cell Panasonic Eneloop Diam 13.91 to 14.30 (not truly circular) 14.18 to 14.45 Overall length 50.67 50.43 Main body length 48.80 49.17 Pos terminal 1.88 1.30 The plastic sleeve makes accuracy difficult as you get difference depending where exactly you measure, but the above are as close as I could get. Also had to be quick as the caliper were effectively shorting out the cell on a couple of the measurements. So it seems they are both within spec apart from the diameter of the Duracell in certain orientations. I'll try a few others. Rob Edit - Drat! The careful formatting didn't work - first figures are Duracell, second are Eneloop Edited By Grindstone Cowboy on 26/07/2021 23:12:34 |
noel shelley | 26/07/2021 23:38:53 |
2308 forum posts 33 photos | A dab of solder on the contact should work ! Noel. |
Bazyle | 27/07/2021 00:42:18 |
![]() 6956 forum posts 229 photos | Scrunched up heavy tinfoil eg from pie case. |
J Hancock | 27/07/2021 08:25:37 |
869 forum posts | Yes, exactly same problem , the cap end would not reach the contact plate in the can opener. Soldered a 'blob' onto the contact plates , fits all batteries now. |
Macolm | 27/07/2021 09:17:55 |
![]() 185 forum posts 33 photos | Another thing to watch is projection of the plastic sleeve at the negative end. Intemittent problems with replacement AAA rechargables in out Panasonic phones were due to poor contact due to this. They are now fine after trimming flush with a razer blade. |
Nick Clarke 3 | 27/07/2021 09:37:38 |
![]() 1607 forum posts 69 photos | Naming an offender IKEA yellow AA batteries will not work in my Worcester Bosch wireless central heating controller for just this reason |
Oily Rag | 27/07/2021 09:56:35 |
![]() 550 forum posts 190 photos | And I thought this was a thread about Flak Batteries from WWII !!!! |
Vic | 27/07/2021 12:11:12 |
3453 forum posts 23 photos | Posted by Oily Rag on 27/07/2021 09:56:35:
Clive Hartland | 27/07/2021 13:34:00 |
![]() 2929 forum posts 41 photos | Hi AJAX, no, not a cordless fone,just a house fone with answerfone. This is not the only item I have found with battery insert problems and to my mind the makers have changed the design slightly. Answers show it is a problem for people. |
bernard towers | 27/07/2021 13:56:47 |
1221 forum posts 161 photos | I thought it was more that the battery boxes in stuff made in you know where are a bit scant on dims. American stuff that takes batts is ok, or mine is!! |
Peter Spink | 27/07/2021 13:58:59 |
![]() 126 forum posts 48 photos | Posted by Grindstone Cowboy on 26/07/2021 23:11:22:
Some rough measurements using digital calipers . . . Do you now have lots of flat batteries? |
roy entwistle | 27/07/2021 15:54:46 |
1716 forum posts | Anyone measuring batteries with calipers, insert a piece of writing paper between one end of battery and caliper, then measure thickness of paper. deduct paper thickness from battery length. This is not meant to be patronising in any way
I have found some batteries that vary in the same pack Edited By roy entwistle on 27/07/2021 15:58:58 |
Oven Man | 27/07/2021 16:48:06 |
![]() 204 forum posts 37 photos | Posted by roy entwistle on 27/07/2021 15:54:46:
I have found some batteries that vary in the same pack Edited By roy entwistle on 27/07/2021 15:58:58 This is where a cheapo plastic vernier caliper comes in really useful. Peter |
Oldiron | 27/07/2021 16:58:38 |
1193 forum posts 59 photos | Posted by Peter Spink on 27/07/2021 13:58:59:
Some rough measurements using digital calipers . . . Do you now have lots of flat batteries? exactly what I was thinking. regards |
Grindstone Cowboy | 27/07/2021 17:37:04 |
1160 forum posts 73 photos | Posted by Oldiron on 27/07/2021 16:58:38:
Some rough measurements using digital calipers . . . Do you now have lots of flat batteries? exactly what I was thinking. regards Not flat, but one got a little warm
Peter Greene | 27/07/2021 22:54:09 |
865 forum posts 12 photos | Posted by roy entwistle on 27/07/2021 15:54:46:
then measure thickness of paper. deduct paper thickness from battery length ... or just zero the calipers with the paper in. |
