Hollowpoint | 01/11/2020 17:58:26 |
550 forum posts 77 photos | Hi guys. I need some help. Again 🙄 My little C0 lathe keeps blowing fuses. Ive had it apart and tested all the usual suspects with the multimeter. Potentiometer, stop switch, microswitch etc and they all seem fine. I deduced it has to be the control board so I removed it and wired it up without the motor to test. The board is blowing the fuse in the plug. I've inspected the board and it visually looks fine. No burnt out components or anything . I'm thinking there must be a short somewhere? At this point I've kinda run out of expertise and talent. What should I be looking for? What should I test. Is there any common things to check? Any help, as always is appreciated.
Hollowpoint | 01/11/2020 18:03:00 |
550 forum posts 77 photos | |
Brian Sweeting | 01/11/2020 18:30:02 |
453 forum posts 1 photos | Cheeky question but have you checked the power lead? |
Nick Clarke 3 | 01/11/2020 18:53:14 |
![]() 1607 forum posts 69 photos | Unfortunately the manual does not seem to list the mains cable on either the exploded diagram or the parts list but this image suggests the suppression components in the mains lead might repay investigation. The mains lead appears to plug into them and they plug via the switch, lamp and fuse into the control board while the earth wire is directly connected to the motor. Interestingly the fuse appears to be in the neutral line??
Edited By Nick Clarke 3 on 01/11/2020 18:57:42 |
Hollowpoint | 01/11/2020 19:14:10 |
550 forum posts 77 photos | Guys, I wired the control board up as below with a different power cord and switch and also using the potentiometer from the lathe (not in picture) to try to eliminate any possibility it could be anything other than the control board. The 3a fuse in the plug tripped immediately. |
Stuart Bridger | 01/11/2020 19:30:06 |
566 forum posts 31 photos | No direct experience of this lathe, but my recommendation would be to check high powered active components first. I.e. diodes and transistors. Not sure if replacement components are easily available though. Not cheap but the complete PCB is available from Arc Euro. Probably the simplest option. |
Maurice Taylor | 01/11/2020 19:47:09 |
275 forum posts 39 photos | I can see bad joints on both side of board ,one on the diode near orange capacitor and one on the other side near serial number.I would think the diodes are shorted and blowing the fuse. I do not mean to be rude ,but if you’re not fully competent with working at mains voltage ,take it to somebody who is. You have to consider the whole board to be at mains potential. Maurice
Hollowpoint | 01/11/2020 20:29:33 |
550 forum posts 77 photos | Stuart - Im trying to avoid spending £100 on a new board if at all possible. 😑
Maurice - Not sure what you mean by bad joints? They all look fine to my untrained eye?
I've just been checking a few components with the multimeter. One of the large diodes (bottom left of 1st picture) is giving continuity both ways. With the positive and negatives reversed. That can't be right? Probably need to remove it from the board and check again? |
Oldiron | 01/11/2020 22:22:59 |
1193 forum posts 59 photos | Posted by Hollowpoint on 01/11/2020 20:29:33:
I've just been checking a few components with the multimeter. One of the large diodes (bottom left of 1st picture) is giving continuity both ways. With the positive and negatives reversed. That can't be right? Probably need to remove it from the board and check again? You need to disconnect one end of each diode from the board to test them properly as you could get a reading across another component on the board. regards |
not done it yet | 02/11/2020 07:33:05 |
7517 forum posts 20 photos | Nipping one leg is a method I have used in the past - then just solder the leg parts back together if OK. |
Hollowpoint | 02/11/2020 21:20:57 |
550 forum posts 77 photos | Well I unsoldered the diode I suspected was faulty and it is indeed shorted. Now just need to find the correct replacements. The diode reads 10A6 where is the best place to buy these? |
John Rudd | 02/11/2020 21:32:43 |
1479 forum posts 1 photos | The diode is 1000v piv rated at 6Amps....try Ebay.... |
Steambuff | 02/11/2020 21:38:22 |
![]() 544 forum posts 8 photos | I would check the other two diodes as well ... in fact I would replace all three! Dave |
Neil A | 02/11/2020 21:43:04 |
160 forum posts | I stand to be corrected, but I think you will find that the 10A6 rectifying diode is rated at 10 Amps and 600 volts. Neil |
Robert Atkinson 2 | 02/11/2020 21:43:47 |
![]() 1891 forum posts 37 photos | I would change all 3 as a precaution. Robert G8RPI. |
Michael Horner | 02/11/2020 22:11:10 |
229 forum posts 63 photos |
Hi Hollowpoint The link should show a circuit diagram of a controller board, unfortunately not yours. The guy is John Swift and is on this site but is dated 2010. It may just give you some idea of what you are taking on. Cheers Michael. |
Maurice Taylor | 02/11/2020 22:22:24 |
275 forum posts 39 photos | Hi Hollowpoint The diodes are on Amazon **LINK** .I would also check if the power transistors are shorted before fitting new diodes. Hope this helps Maurice. |
Hollowpoint | 02/11/2020 22:26:46 |
550 forum posts 77 photos | Thanks guys. I've found them on ebay and on amazon. They aren't expensive so I'll change all 3. Hopefully I'll get it working again. Fingers crossed. 🤞 |
John Rudd | 02/11/2020 22:36:40 |
1479 forum posts 1 photos | Not power transistors.... This board uses 2 scr's and 2 diodes in a fw bridge configuration.... |
Les Jones 1 | 02/11/2020 22:42:03 |
2292 forum posts 159 photos | I suggest that you also check the two TO220 devices which I suspect are SCRs. I think they form a controlled bridge with two of the three diodes. The output of this bridge will feed the motor. The third diode probably powers the control circuit that controls the phase of the trigger pulses to the SCR gates. The small toroidal transformer near the heatsinks will provide isolation between the control circuit and the SCR gates. If one of the SCRs is short circuit and it is not replaced one or both of the diodes that are part of the bridge will be destroyed again when power is re applied. Les. |
