Where's this rust come from ?
Bob Wild30/09/2020 23:35:15
99 forum posts
77 photos
Two months ago I bought a tool chest in an attempt to tidy up my workshop.
To my horror many of the tools are going rusty, like this V Block for example:
The only surface affected is that in direct contact with the bottom of each drawer. It look like there is a layer of material which looks like baize (but is not) glued to the wood and the parts are actually stuck to this. So the question is what has caused this, and more importantly how can I prevent it ?
Paul Lousick30/09/2020 23:41:21
2276 forum posts
801 photos
Moisture in the wood ??
peak401/10/2020 00:15:50
2207 forum posts
210 photos
You could line the drawers with VCI rust inhibitor paper.
I've done this with most of my mini Bisley filing cabinet drawers; it's a bit slippery though, so I added a layer of non-slip carpet mesh from Ikea.
Bill
Steviegtr01/10/2020 01:59:09
2668 forum posts
352 photos
Buy youreself a small dehumidier. this will take all the damp from the air in your room., This will stop any rust from accumilating.
Steve.
John Ockleshaw 101/10/2020 04:01:39
56 forum posts
7 photos
Hello Bob,
I would suggest the baize has been fixed in place with PVA adhesive ( Polyvinyl acetate).
Regards, John
John Haine01/10/2020 08:10:58
5563 forum posts
322 photos
A tool chest that rusts tools is not fit for purpose! Return it and get a refund.
John MC01/10/2020 08:22:19
464 forum posts
72 photos
Could it be the type of wood? Some types of wood can cause corrosion, I'm sure this has been discussed on the forum.
I have a wooden toolmakers cabinet (Union?) bought some 40 years ago, corrosion has never been a problem even when my workshop was a cold and damp wooden shed.
Bo'sun01/10/2020 08:30:06
754 forum posts
Posted by John MC on 01/10/2020 08:22:19:
The tannic acid in Oak can cause corrosion in ferrous materials. Oak is not uncommon for Toolmakers tool chests.
Paul Lousick01/10/2020 08:33:21
2276 forum posts
801 photos
A lovely piece of furniture but I don't think it was originally made for storing metal tools.. Buying second hand and not intended for a tool box, it is buyer beware and you cannot expect a refund.
Best option is to seal the drawers or line with a suitable material and coat the tools with an anti rust product. Lots on the market. Lanelin (from sheep wool) used to be what the old timers used. Now availavle in spray cans. Good on your hand also.
Paul.
John MC01/10/2020 08:41:46
464 forum posts
72 photos
Posted by Paul Lousick on 01/10/2020 08:33:21:
Those Clarke toolboxes are available new at very reasonable prices, is the OP's box new?
There's one on display in the window of my local branch of Machine Mart (can I say that?).
Michael Gilligan01/10/2020 08:42:33
23121 forum posts
1360 photos
dont know
https://www.machinemart.co.uk/p/clarke-cmw-9b-9-drawer-wooden-machinist-too/
Edit: John MC got there first
Edited By Michael Gilligan on 01/10/2020 08:45:13
Anthony Knights01/10/2020 08:48:37
681 forum posts
260 photos
cabinet.jpgI have an identical tool chest (Machine Mart), which I bought to store my measuring equipment. It is kept in the house as my workshop has a damp problem in the winter. I have had no issues with rust, so perhaps it is the location of your chest rather than the chest itself.
Edited By Anthony Knights on 01/10/2020 09:00:32
Bo'sun01/10/2020 08:51:48
754 forum posts
Posted by Steviegtr on 01/10/2020 01:59:09:
Steve.
Concur the above 100% for helping to prevent light to moderate surface oxidisation, A "small" dehumidifier is very unlikely to stop rusting as such, unless you have a minute workshop, sealed, with no doors or windows. Having said that, I've had one for around 20 years and wouldn't be without it.
Several points to consider though. Keep windows and doors shut as much as possible, otherwise you'll be demumidifying the world. Consider a unit that has a permanent drain and protect it from freezing. Keep the air intake filter clean (especially if you also do woodwork in the same workshop), Think about a "dessicant" type rather than a "refrigerant" as they can work better at lower temperatures.
Baz01/10/2020 09:00:08
1033 forum posts
+1 for desiccant type dehumidifiers, they also give out a little bit of warm air, every little helps when heating the workshop. I used to have a refrigerant type, which worked well but would freeze solid during winter. I collect the water and use it in the loco.
John Haine01/10/2020 09:13:51
5563 forum posts
322 photos
Bob Wild didn't say his tools rusted before they were in the chest, and they only rusted when in contact with the lining. This implies that the workshop is not damp and causing the rust.
These chests are available new, and so Bob may have bought a new one from Clarks. Michael's link shows that they are sold as tool chests.
So, if Bob bought it new, the first step should be to return it to Clarks as not fit for the purpose for which it was sold.
We are all practical types and try to find solutions to problems, but all too often this leads to us accepting unsatisfactory goods from suppliers.
Frances IoM01/10/2020 09:26:50
1395 forum posts
30 photos
I too would suspect the cabinet was somewhat damp on purchase and that attack on the metal looks very much like what PVA does to metal - woodworkers will see similar if you use a bit of steel pin (even if Stainless Steel) to plug the spout in a flexibottle of PVA
Edited By Frances IoM on 01/10/2020 09:27:35
Journeyman01/10/2020 09:37:21
1257 forum posts
264 photos
It is likely that the baize-like material on the bottom of the drawer is a spray-on coating of some description probably a plastic material either applied as one coat or as a dry flock onto a sprayed on adhesive. Would seem likely that the rusting is caused by an adverse reaction between the coating/adhesive and the tool face.
A few choices, as suggested above return as unfit for purpose, further line the drawers with VLC paper or non-slip drawer liner or scrape off the offending coating and apply a new liner. Leaving the old lining in place it may eventually leach through the new liner. The current lining material may eventually "dry" and the volatile/corrosive agent may go.
Seem unlikely to be the wood as this appears to be pine which is usually benign. Hopefully not the varnish either as this should have lost all the volatile agents by now.
Hope you get the problem sorted as it appears to be quite a useful toolmakers cabinet.
KWIL01/10/2020 09:45:10
3681 forum posts
70 photos
"Felt-lined drawers keep tools from sliding during transport and help prevent moisture damage to contents " or so the Machine Mart sellers blurb says,
Brian Matthews 101/10/2020 09:59:20
1 forum posts
Hi Forum
First post here as a new member, I'm actually a woodworker (with aspirations of engineering so be gentle). This looks like it is coming from the glue rather than the wood but difficult to assess from afar! If the wood was not dry it would create a micro-climate within the drawer causing rust to start all over. If your workshop is damp in any way (excluding the summer months) I would avoid storing tools in a wooden cabinet as it will absorb moisture from the air over time, possibly exacerbating the problem. I would remove the baize and replace it with something impervious.
Happy to answer any wood related questions.
Rod Renshaw01/10/2020 11:04:48
438 forum posts
I agree with most of the above as possible reasons for the rust. The chest was most likely made abroad and shipped by sea and stored in unheated warehouse space and so has had every chance to get damp. The OPs workshop may be heated and drier so that the moisture is coming out of the wood and being trapped in the drawer spaces. Also, PVA may have been used to stick the "baise" down and this glue creates acetic acid as it dries (and may decompose releasing Formic acid? ) Perhaps best to locate a newly owned chest ( even an old one)  empty in the space it will occupy and with the drawers out, for a time, and to use VLC paper liners at least for an initial period. All these problems should disappear over time?
Rod
Edited By Rod Renshaw on 01/10/2020 11:25:20
Edited By Rod Renshaw on 01/10/2020 11:26:43
Edited By Rod Renshaw on 01/10/2020 11:28:49
