Cigarette Papers
MC Black 213/07/2020 09:39:01
99 forum posts
In Stan Bray's book "Milling for the Model Engineer", he recommends using cigarette paper to gauge thickness (a sort of disposable feeler gauge).
I've researched Cigarette Papers and discovered that they are available in different colour boxes with different thicknesses (and flavours).
I've written to Rizla+ and NOT had the courtesy of a response
Does anybody use cigarette papers in this way? If so, what colour box, please?
How thick (in either thou or microns) are they, please?
Very many thanks for taking the time to read this and, if you can, for helping.
I hope that you and your families are - and will remain - well.
MC Black
vintage engineer13/07/2020 09:45:28
293 forum posts
I use green rizlas and they are about 1 thou thick.
Steve King 513/07/2020 09:50:36
86 forum posts
95 photos
Red box thickest
Then green
Then blue
The silver
Alot of people use the green but i recommend the red if you can find them.
Chris Evans 613/07/2020 10:00:58
2156 forum posts
Green ones live in my tool box.
Brian H13/07/2020 10:12:50
2312 forum posts
112 photos
I always use blue ones. I don't suppose it matters as long as you measure them and allow for the thickness when setting up.
I use blue ones because, for general purposes the thickness can be ignored and, I always measure the actual part during machining.
MC Black 213/07/2020 10:31:48
99 forum posts
Very many thanks to you all for replying
Has anybody actually measured the thickness of the different colours?
If so, what are the thicknesses, please?
With best wishes and thanks again.
MC
Norman Billingham13/07/2020 10:47:45
56 forum posts
I use the green ones, though not as feeler gauges. The trick I was taught many years ago for setting a milling cutter was to dampen the paper with a bit of oil (or saliva) and stick it to the work then lower the cutter till the paper is dragged off, when you are within 0.001" of the work.
My green ones measure 0.001" + roughly 0.0002, - 0.0000 using a Mitutoyo micrometer.
Andrew Johnston13/07/2020 10:50:49
7061 forum posts
719 photos
I use blue papers, which measure 1 thou thick to the width of the line on the micrometer. I use them for quick 'n' dirty setups on the mills and lathe. For most work on the mills I use this:
And this:
Michael Gilligan13/07/2020 10:54:10
23121 forum posts
1360 photos
Posted by MC Black 2 on 13/07/2020 10:31:48:
Given that they are made from paper, and typically applied to the workpiece by dampening with a lick, I think that might be a trickier project than it first appears.
My working assumption has always been that the blue ones are [were?] near enough to 1thou’ when used for edge-finding.
Baz13/07/2020 11:35:39
1033 forum posts
Have always used green ones, they seem to be more readily available than the other colours, they appear to be pretty much .001” thick.
Steve Crow13/07/2020 11:41:15
429 forum posts
268 photos
I use OCB black packet papers for edge finding. They are ultra thin and slow burning so I use them anyway for smoking.
I've just stuck one in my best mic - 0.02mm so just less than a thou.
Rizla blue, my second choice for smoking is 0.025mm - slightly thicker.
Rizla black or silver are about the same as the OCB's.
ega13/07/2020 11:47:19
2805 forum posts
219 photos
What ever colour you buy, don't forget your pipe cleaners for cleaning your leadscrew.
My impression is that for crude purposes the paper is assumed to have no thickness eg as an edge finder or to be of constant thickness eg test for flatness with surface plate.
Iain Downs13/07/2020 11:59:28
976 forum posts
805 photos
I've come across this and use green papers. I don't think the local co-op had such a variety - and I had no idea which was the thinnest.
The only thing I've found is that moistening the paper (spitting) before applying it doesn't work - it sticks to my finger better than the piece.
Instead I moisten the piece (CT90 or spit) and apply it dry. This is then much more likely to stay on the piece.
Iain
Steve Crow13/07/2020 12:02:38
429 forum posts
268 photos
I get them in boxes of fifty from ebay but they sell smaller quantities or individual packets as well.
Martin Kyte13/07/2020 12:28:50
3445 forum posts
62 photos
George Thomas stated that he cut his into strips and stored them in a convenient box which he said would last him a lifetime. Bit finickity for my taste but there you go.
regards Martin
Grindstone Cowboy13/07/2020 12:29:56
1160 forum posts
73 photos
Posted by ega on 13/07/2020 11:47:19:
I think I've mentioned this before, but they are now marketed as "fuzzy sticks" for use by children laugh
Rob
Dennis D13/07/2020 12:37:11
84 forum posts
I served my apprenticeship at a company called Molins who made cigarette manufacturing machines and in all the workshops there would be a reel of cigarette paper to aid with setting up and we always used to work on 1 thou.
Off-topic the same company during the war made the Molins 6 pounder gun fitted to the Mosquito fighter bomber
Edited By Dennis D on 13/07/2020 12:38:02
larry phelan 113/07/2020 13:11:02
1346 forum posts
15 photos
If it is only to tell when the cutter is about to contact the work surface, what is wrong with simple toilet paper ?
S-W-M-B-O tells me it,s available in many different grades and she knows !!
Even if it does not suit the job, you can still find a use for it !
Just a thought !cheeky
ega13/07/2020 13:41:00
2805 forum posts
219 photos
A further thought: what difference to thickness does the gum make?
MC Black 213/07/2020 13:54:30
99 forum posts
Very many thanks to everybody who has replied.
Stan Bray wrote to cut off the gummed area!
Green seems to be favourite with more members responding in favour than the other colours put together.
I confess that I was NOT aware that other companies manufactured Cigarette Papers other than Rizla+
I am self-isolating at present so will ask my neighbour, who is doing my grocery shopping at present, to buy me a couple of packets of Green (otherwise Blue).
I don't have a toilet near my shed - so cigarette papers will have to do.
Very many thanks again to you all.
MC Black
