Joe McKean | 31/03/2020 07:51:11 |
60 forum posts 3 photos | Can anyone help me with the size of thread to bolt the travelling steady onto the cross slide of a Boxford AUD, I assume it is Imperial but only have metric bolts in the workshop so cannot try them to find out. |
Martin Connelly | 31/03/2020 09:19:56 |
![]() 2549 forum posts 235 photos | The usual options are to use thread gauges if you have some. If not then get either a piece of dowel or coiled paper/card and screw it in and out then measure the marks on the surface. Diameter and thread pitch will give a few possibilities to try. Martin C |
not done it yet | 31/03/2020 09:21:05 |
7517 forum posts 20 photos | Find the minor diameter (with a drill, or other rod, plus micrometer) and check charts for likely imperial candidates? |
Bo'sun | 31/03/2020 09:25:42 |
754 forum posts 2 photos | Using a dowel and/or piece of paper as suggested is much easier than thread gauges on an internal thread. |
Hopper | 31/03/2020 09:27:06 |
![]() 7881 forum posts 397 photos | On a British lathe, most likely If it looks (or feels) coarse it will be BSW or if it looks fine it will be BSF. Diameter will be the next standard fractional size up from the hole down the middle as measured with digital calipers or a rule. Threads tapped into cast iron on old Brit machinery seem to most often be BSW but not always.
Edited By Hopper on 31/03/2020 09:28:08 |
Micky T | 31/03/2020 09:40:05 |
![]() 76 forum posts 29 photos | Hi Joe I'll measure them later on my Boxford for you and let you know
Micky T Edited By Micky T on 31/03/2020 09:40:30 |
Clive Brown 1 | 31/03/2020 09:57:49 |
1050 forum posts 56 photos | They are 3/8" BSW x 2" skt. hd. cap screws. Supplied with my steady by Boxford for my ME10. |
Neil Wyatt | 31/03/2020 12:07:48 |
![]() 19226 forum posts 749 photos 86 articles | Someone asked me to correct the thread title. To be pedantic, although the company was Boxford, the lathes were marketed as Box-Ford Neil |
Oldiron | 31/03/2020 12:51:30 |
1193 forum posts 59 photos | Posted by Neil Wyatt on 31/03/2020 12:07:48:
Someone asked me to correct the thread title. To be pedantic, although the company was Boxford, the lathes were marketed as Box-Ford Neil All the paperwork & name plates on my Boxford have no hyphen in the word. I have several Boxford name plates, change gear plates & books I have collected over the years and none have a hyphen. I Googled Box-ford & got no results apart from Ford roof boxes. I can find no reference to Box-ford any where. I would be very interested to see any examples please Neil. regards regards |
Mike Poole | 31/03/2020 13:04:32 |
![]() 3676 forum posts 82 photos | A quick look at the lathes.co.uk website confirms the presence of the hyphen, a picture and mention in the text. Mike |
Roderick Jenkins | 31/03/2020 13:10:00 |
![]() 2376 forum posts 800 photos | The lathes database **LINK** Shows that the hyphen disappeared sometime around 1960 Rod Edit: Too slow yet again! Edited By Roderick Jenkins on 31/03/2020 13:11:27 |
mgnbuk | 31/03/2020 13:35:08 |
1394 forum posts 103 photos | although the company was Boxford, the lathes were marketed as Box-Ford It was just Boxford when I started working there September(ish) 1980. The logo was the same bold blue font as the current version. Standard lathe colours at the time were the two tone beige/brown & I have a suspicion that the threads may have been all metric at that time, but can't find anything to back that up. Nigel B. |
Peter G. Shaw | 31/03/2020 13:45:14 |
![]() 1531 forum posts 44 photos | Don't forget that Boxford was originally an off-shoot from Denford of Brighouse when lathe production moved, or was setup in Boxtree mills, Halifax, hence Box-Ford. Peter G. Shaw
Grindstone Cowboy | 31/03/2020 14:06:37 |
1160 forum posts 73 photos | There ya go! (Must get a replacement for that when I get round to it...) |
Michael Gilligan | 31/03/2020 15:18:56 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 31/03/2020 12:07:48:
Someone asked me to correct the thread title. To be pedantic, although the company was Boxford, the lathes were marketed as Box-Ford Neil . Clearly the real pedant would have checked the vintage of the lathe in question ... and then [if appropriate] used ‘all caps’ in the hyphenated thread title. Thanks anyway, Neil ... The resulting discussion has evidently grabbed people’s attention, and we’ve probably all learned something along the way. MichaelG.
Clive Brown 1 | 31/03/2020 15:40:18 |
1050 forum posts 56 photos | |
not done it yet | 31/03/2020 16:09:10 |
7517 forum posts 20 photos | The title being changed to ‘Boxford’ (while perhaps not wrong at the moment, means that anyone making a search for just that topic in the future will likely not find it. Makes no odds to me, but it might be useful for many forumers. |
thaiguzzi | 31/03/2020 16:25:22 |
![]() 704 forum posts 131 photos | 1969 VSL here - 3/8 BSW. |
Michael Gilligan | 31/03/2020 16:36:26 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 31/03/2020 16:09:10:
The title being changed to ‘Boxford’ (while perhaps not wrong at the moment, means that anyone making a search for just that topic in the future will likely not find it. Makes no odds to me, but it might be useful for many forumers. . But it’s much better than ’Oxford’ ... Which it was before Neil kindly changed it. MichaelG. |
not done it yet | 31/03/2020 18:24:50 |
7517 forum posts 20 photos | But it’s much better than ’Oxford’ ... Which it was before Neil kindly changed it. yes, maybe. But a search for ‘Boxford’ brings up ten pages. A search for KISS |
