Here is a list of all the postings Micky T has made in our forums. Click on a thread name to jump to the thread.
Thread: ER collet chuck for Super 7 |
15/08/2023 12:39:24 |
Hi Peter RDG Tools does an er 32 collet chuck with Myford thread. I bought one a few years ago for a Grayson Lathe that has the same spindle thread as the Myford. I was very satisfied with it.
MickyT |
Thread: What did you do today? 2023 |
23/06/2023 18:17:15 |
I got fed up with the lathe spindle slipping when I took a cut. It was ok when I could do a 25 thou cut but today it slipped at 15 thou. I bought a Brammer belt last year but life got in the way so I decided I’d do it today. I measured the old belt and removed the excess links. After trying it a couple of times and removing a few more links once it had settled in I was able to take a 100 thou cut. Not bad for an old Boxford lathe |
Thread: Aluminium solder |
22/08/2022 18:01:14 |
Hi Robin I’ll take the solder off your hands if that’s ok MickyT |
Thread: Boxford model CUD mk2 lathe |
01/11/2021 09:03:04 |
Hi Sean you can try **LINK** there is a gentleman called Mark Lord on there who sells spares for Boxford lathes via a site called simplylathes.co.uk, you could contact him as he may well have the parts that you need. Regards, MickyT |
Thread: Archives |
31/08/2021 12:55:22 |
Hi Paul I am only able to open the old archive files with an Ipad. That includes the old magazines on the last page of the archive library. I have tried everything I can think of to open them on a computer but have failed so far, that is anything prior to MEW 180. I know that the archives are being updated to htlm5 but it is a slow process and i understand that Neil is chaising it at the moment. MickyT |
Thread: DRO for Boxford AUD |
28/08/2021 20:31:34 |
Hi Mike I have a boxford AUD and I fitted DRO from Arceurotrade DRO. Find the size you require. For fitting look at the following vid on YouTube Link MickyT |
Thread: Hoglet Kick Starter |
27/08/2021 19:44:15 |
Thanks for showing your Kick starter. I have found a couple of suppliers of the sprockets and sprag clutch online. I’d like to make the kick starter as I want to make the engine as close to the original as possible but I am always open to surgestions. MickyT |
Thread: Dickson tool post |
25/08/2021 09:09:49 |
Hi Bob there is a vid on YouTube that covers some repair MickyT |
25/08/2021 05:57:18 |
Thats great Jason I was having a little difficulty visualizing the remade part but its clear now. I still had the shaft as 2 parts in my head with the sprag clutch and sprocket attached to the second part on the left but its much simpler with the shaft as one piece probably stronger too. Thanks once again for taking the time to explain it to me and definitely a better option than the bicycle free wheel sprocket that I had found. Regards, MickyT |
24/08/2021 17:21:06 |
I agree after all it’s all about the look. If I can’t figure your original suggestion, although it does seem straight forward, I may ask you to draw it up for me 👍. Thanks again for your help the kick starter is a long way off as I haven’t started cutting metal yet although I have all the metal for the engine ready to go. MickyT |
24/08/2021 16:30:21 |
Thanks Howard never thought simply bearings did them Thanks Jason same with Arc. I had found the part that you had linked in your second post which is why I asked the original question about uk availability. I do like the idea of making the part as you described shouldn’t be too complicated. thanks again MickyT |
24/08/2021 10:41:06 |
I'm about to start building the Hoglet by Randall Cox. I'm in the process of accumulating the materials required. Could any one tell me where i can purchase the slip sprag clutch or it's equivelant in the UK for the kick starter. Or does any one have an alternative way of starting the engine.
MickyT |
Thread: Archives |
24/08/2021 08:57:16 |
You can view the archives using an Ipad. I use google Chrome on my Ipad for the Internet but the archives can be a bit clunky. MickyT |
Thread: 75mm x 2000mm Belt Linisher Build Thread |
25/06/2021 12:29:32 |
Looks very interesting I look forward to your progress
MickyT |
Thread: Today on Talking Pictures TV |
24/05/2021 09:49:47 |
It should be on Freesat channel 306
MickyT |
Thread: Boxford countershaft part required |
20/05/2021 13:16:23 |
Hi James You could try a gentleman called Mark Lord. He advertises as simply lathes on ebay and has loads of parts for Boxfords. You should also be able to contact him on the Boxford owners site at BoxfordLathe Owners group Regads, MickyT |
Thread: Flash Removal Tool |
22/01/2021 11:52:58 |
That sounds great Neil
MickyT |
Thread: Trunch Trojan |
30/10/2020 10:54:34 |
I like it |
Thread: Bench grinder wheel wobble |
22/07/2020 11:47:46 |
Ive just completed the upgrade to an old off hand 6" grinder as described here **LINK** I followed the instructions in Harold Halls book, Tool and cutter Sharpening No38 in the workshop practice series
MickyT |
Thread: ER Collet chuck for Myford ML7R |
15/07/2020 06:53:45 |
Hi Mark I purchased an ER32 collet check from RDG for a Grayson Lathe which has an identical spindle nose to the Myford and that was very accurate. I have since machined a back plate for a Boxford which I have attached the ER32 Collet chuck to and that is also very accurate. So in answer to your question yes you can machine a new backplate. MickyT |
