Chris TickTock | 02/12/2019 17:36:52 |
622 forum posts 46 photos | Hi I have a small 3mm ish gap between my 75 mm Dia DC motor and the 77 Dia mm bracket I have to hold it. There will be some torque but not too heavy duty. Obviously I wish to pack out the motor so when I tighten the metal clamp it holds the motor without turning when used. I am thinking of some type of rubber tape or self adhesive tape but thought I would see if any one has any ideas. Regards Chris |
Emgee | 02/12/2019 17:46:39 |
2610 forum posts 312 photos | You could use 3 or 4 (120 or 90 degrees) packing pieces between the 2 diameters, wood should be OK for small motor, Emgee |
bill ellis | 02/12/2019 18:03:12 |
71 forum posts 2 photos | A bit of old rubber matting or cushion flooring would be my choice, I'd steer clear of anything metal. Just ensure any cooling ducts are not blocked. |
Mike Poole | 02/12/2019 18:19:05 |
![]() 3676 forum posts 82 photos | A piece of inner tube could do the job but they are getting rare with even motorcycles using tubeless tyres, could be worth a cheeky visit to your favourite tyre fitting place. Mike |
Nimble | 02/12/2019 18:59:05 |
![]() 66 forum posts 6 photos | Hi Chris, A possibility would be to use insertion rubber, available in a number of widths and thicknesses and available in nitrile and neoprenr which should prevent stickiness developing if there is any stray oil about. Neil |
Chris TickTock | 02/12/2019 19:26:42 |
622 forum posts 46 photos | Thanks Guys some really good ideas. Not sure what insertion rubber is but will find out. Regards Chris |
Brian Oldford | 02/12/2019 19:27:29 |
![]() 686 forum posts 18 photos | Would it be possible to wind a number of layers of self-amalgamating rubber tape around the motor body making sure you don't obstruct any ventilation holes?
Edited By Brian Oldford on 02/12/2019 19:27:40 |
peak4 | 02/12/2019 19:54:33 |
![]() 2207 forum posts 210 photos | Go-cart tyres are a useful source of rubber; competition dry track ones being slicks give a nice even surface and the belting internally provides useful reinforcement. Bill Edited By peak4 on 02/12/2019 20:24:05 |
Chris TickTock | 02/12/2019 20:20:41 |
622 forum posts 46 photos | Posted by Brian Oldford on 02/12/2019 19:27:29:
Hi Brian, yes it is certainly possible, I have just looked up what amalgamating means which I have understood to mean it bonds to itself to form one. Now that's fine but it would have to grip the body once the clamp was tightened. I suspect it would work. I am minded to use neoprene eithing from a sheet or washers as this material should stay consistent as it is often used for gaskits. Chris
Grindstone Cowboy | 02/12/2019 20:38:04 |
1160 forum posts 73 photos | +1 for the wood idea. A very handy source is coffee stirrers from your local coffee shop. |
Michael Briggs | 02/12/2019 21:27:42 |
221 forum posts 12 photos | +1 Emgee, I like simple effective solutions. |
Chris TickTock | 02/12/2019 21:35:12 |
622 forum posts 46 photos | Posted by Michael Briggs on 02/12/2019 21:27:42:
+1 Emgee, I like simple effective solutions. Can anyone advocating the use of wood here give a reason why it might be better than for instance neoprene? chris |
Paul Kemp | 02/12/2019 21:43:12 |
798 forum posts 27 photos | Posted by Chris TickTock on 02/12/2019 21:35:12:
+1 Emgee, I like simple effective solutions. Can anyone advocating the use of wood here give a reason why it might be better than for instance neoprene? chris Assuming this is for your grinder 'project' it's probably a good idea to have the motor (thus the wheel) mounted rigidly in relation to the rest / what you are trying to grind (or lap). Paul. |
Chris TickTock | 02/12/2019 21:49:55 |
622 forum posts 46 photos | Posted by Paul Kemp on 02/12/2019 21:43:12:
+1 Emgee, I like simple effective solutions. Can anyone advocating the use of wood here give a reason why it might be better than for instance neoprene? chris Assuming this is for your grinder 'project' it's probably a good idea to have the motor (thus the wheel) mounted rigidly in relation to the rest / what you are trying to grind (or lap). Point taken that a rigid mount is important. However once clamped up neoprene I think would also be firm. There also exists if I use wood an increased risk of causing damage to the motor body as the load will be concentrated on the few points that the wood is positioned.. I agree I am being speculative but will try the neoprene first and the wood as my fall back position. Thanks for all posts...appreciated Chris
Paul.
Ian P | 02/12/2019 22:42:48 |
![]() 2747 forum posts 123 photos | Posted by Chris TickTock on 02/12/2019 21:35:12:
+1 Emgee, I like simple effective solutions. Can anyone advocating the use of wood here give a reason why it might be better than for instance neoprene? chris Using natural resources is better for the environment. IanP |
Ian P | 02/12/2019 22:47:06 |
![]() 2747 forum posts 123 photos | Posted by Chris TickTock on 02/12/2019 21:49:55:
If the motor has a cylindrical body and no other mounting features than presumably the manufacturer will have designed the outer casing to withstand being clamped or held so no need to take any special precautions. Ian P |
not done it yet | 03/12/2019 09:45:30 |
7517 forum posts 20 photos | I think a better solution would be to make a proper bracket/holder to suit the motor and application. Rather than bodging something. |
Michael Gilligan | 03/12/2019 10:06:30 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 03/12/2019 09:45:30:
I think a better solution would be to make a proper bracket/holder to suit the motor and application. Rather than bodging something. .
Engineers have been using them since Noah was a lad. MichaelG. |
Ian P | 03/12/2019 10:20:52 |
![]() 2747 forum posts 123 photos | I have nothing whatsoever against bushings if they are fit for purpose, although I would not describe go-cart tyres, inner tube rubber, amalgamating tape, Neoprene insertion ('insulation'?) rubber or strips of wood as being simple in the context of a holding the motor and therefore spindle of a grinding tool accurately located. Maybe I have the wrong end of the stick and the motor being clamped carries a pulley for a belt drive so a resilient mount might be very appropriate. Ian P |
Michael Gilligan | 03/12/2019 10:28:35 |
![]() 23121 forum posts 1360 photos | Posted by Ian P on 03/12/2019 10:20:52:
I have nothing whatsoever against bushings if they are fit for purpose, . Ian, [for clarity] My question was specifically a response to ‘not done it yet’ MichaelG. |
