Shell Petrol Can Puzzle
Georgineer22/09/2019 00:35:37
652 forum posts
33 photos
I recently inherited this petrol can from an old friend, and it puzzles me. I've never seen one like it and it's too late to ask him what it is for.
It is a perfectly ordinary Shell can, with the usual embossed lettering and a cast brass cap lettered SHELL MEX. The paint seems to have been black, with a gold Shell emblem on the side. Where it gets puzzling is that there is a cylindrical steel vessel, 3" in diameter and 10½" deep, let into it and soft soldered in place. There is a hint of what may be oil toward the bottom of the inside.
The cylinder gives every impression of being machine made, which I emphasise because the handle is an obvious home-made replacement of brass, soft soldered in place.
So the puzzle is, what was the purpose of this modification, and was it done by Shell? Was it to hold a can of 2-stroke oil? If so, why wouldn't you just mix it straight in with the petrol? Was there a standard Shell 2-stroke oil can which would fit? And why would you want to reduce the capacity of a 2 gallon can to 1 gallon, 2 quarts, 1 pint and 2½ gills? (I stuck that in for the traditionalists. Imperial gallons of course.)
Over to you for suggestions,
George
Alan Johnson 722/09/2019 01:13:17
127 forum posts
19 photos
Vickers Machinegun used a can much like yours. I have a WWII example, but not quite the same - no vertical tube.
Bill Phinn22/09/2019 01:16:11
1076 forum posts
129 photos
Was there a separate cylinder (now missing) that fitted the cavity and held (4 stroke) engine oil for top-ups?
JasonB22/09/2019 07:05:30
Was it to stand a funnel in? Though the old glass 2-stroke bottle is a probability
Speedy Builder522/09/2019 07:09:00
2878 forum posts
248 photos
Spare petrol and a bottle of beer ?
JasonB22/09/2019 07:43:29
JasonB22/09/2019 07:45:51
Pity you don't have the missing bit as they seem to fetch a good price
If you search "shell Duo" taken from that description there are plenty of photos
Edited By JasonB on 22/09/2019 08:20:33
Former Member22/09/2019 08:12:25
1329 forum posts
martin perman22/09/2019 08:18:20
2095 forum posts
75 photos
Out of curiousity whats the can date, look at the base and you will see a number.
Martin P
not done it yet22/09/2019 09:16:38
7517 forum posts
20 photos
I somehow doubt it would be for two stroke oil - at 40:1 (or even 25:1) it would hold enough oil for a lot of refills and would also need some means of measurement to get the correct ratio - so I suspect it was for normal engine oil. Also, were there many two stroke cars around, even, back then? Could be wrong, of course.... Thoughts or evidence?
Brian G22/09/2019 09:29:27
912 forum posts
40 photos
Posted by not done it yet on 22/09/2019 09:16:38:
...Also, were there many two stroke cars around, even, back then? Could be wrong, of course.... Thoughts or evidence?
Perhaps depends on date, the Valveless comes immediately to mind in the pre-WW1 era. Could their rarity make it necessary for motorists to carry a larger amount of two-stroke oil in case they come to a petrol station that didn't sell it. I remember having to carry a bottle of two stroke for my bike back in the 70s because not all garages carried it.
Michael Gilligan22/09/2019 09:31:03
23121 forum posts
1360 photos
< deleted >
Edited By Michael Gilligan on 22/09/2019 09:32:57
roy entwistle22/09/2019 09:43:25
1716 forum posts
not done it yet There weren't many two stroke cars about but there were a lot of motorbikes and Villiers recomended 1/2 pint oil to 1 gallon of petrol
Roy
Former Member22/09/2019 10:22:42
1329 forum posts
not done it yet22/09/2019 11:01:37
7517 forum posts
20 photos
Posted by roy entwistle on 22/09/2019 09:43:25:
Roy
Yes, Roy, but not many motorcyclists would carry around a 2 gallon can of reserve fuel? Stored at home would not necessitate two containers in the one package? I would have thought this combination was for when cars consumed rather more engine oil, than modern engines, and the driver carried a reserve of petrol strapped somewhere on the body work?
I just don’t think they made cans as ‘gimmicks’ back then, so it would have had a sound practical use - unless it was usual for motorists to buy oil dispensed in bulk from a petrol station. Living on a farm, it was usual to have bulk tanks for TVO, cans of petrol (for starting engines from cold) and engine oil in larger containers (gallon tins and 5 gallon drums, commonly). Villagers or townies may have had different customs/habits.
Georgineer22/09/2019 12:45:39
652 forum posts
33 photos
Puzzle solved. It makes such a difference when you know the right words to make a search! Thank you everybody for your suggestions and information. All I have seen on the base so far is flaky rust and cobwebs - I'll look for a date code when I'm next in the workshop.
I doubt I'll be making a replica can, so while I save up for a real one for only £299.99 (may have been repainted in the past!) I'll look for a beer bottle to fit. Thanks for the suggestion, Speedy. At present I'm saving up for this collectible book about gas engines: https://www.ebay.co.uk/itm/Antique-1907-Russian-Empire-book-Gas-oil-other-internal-combustion-engines/183896162971?hash=item2ad110c29b:g:2aAAAOSwi05dNzY0 I'm just glad it isn't a rare first edition.
George
Neil Wyatt22/09/2019 19:05:24
19226 forum posts
749 photos
86 articles
As most people would have mixed their two-stroke at the pump, the oil is probably for general lubrication?
Brian Oldford22/09/2019 19:22:32
686 forum posts
18 photos
Posted by 34046 on 22/09/2019 10:22:42:
Worth keeping and sympathetically restoring.
Collectable item from the 1930's known as a Shell Duo.
There is one on ebay at £695 with plenty of detailed pics of the oil can
Bill
Edited By 34046 on 22/09/2019 10:23:03
There's many items for sale on E-bay at what seems silly prices to some people. Will that petrol can sell at that price?
Georgineer22/09/2019 23:42:16
652 forum posts
33 photos
Posted by Neil Wyatt on 22/09/2019 19:05:24:
I agree, Neil. Since it was common at one time to carry a petrol can strapped to the running board, I'm wondering if the 'duo' can was a neat way of carrying spare oil and petrol in one package. Certainly the large rounded flange on the oil cans I see in pictures would have discouraged them from rattling about while on the move.
At one time petrol was delivered to the customer in 2 gallon cans, before petrol pumps became common. Dad used to tell tales of delivering full cans on his bike and returning with the empties - that would have been in the early-to-mid 1920s at a guess. I presume the 3/- price embossed in the top of the can was the deposit, much like the 3d deposit on lemonade bottles when I was a nip.
I looked for a date code on the rusty bottom of my can, but it's pretty ugly under there. Rather than having to scrape the whole thing, can anybody suggest where I should look first? The panel is corrugated rather than flat.
George
David George 123/09/2019 06:29:35
2110 forum posts
565 photos
I remember buying 2 stroke oil separately, as it was cheaper, then putting in measured amount in to tank before filling with a gallon of petrol, about 1s- 10p a gallon. Filling my James scooter.
David
