To Pin or Not To Pin
Martin Kyte10/09/2019 14:10:18
3445 forum posts
62 photos
Reading some comments on pinning crankshafts on another thread and getting ready to complete a loco crankshaft raised the question do I or don't I pin the webs. Could someone with a brain more used to doing stress calcs than me solve this question once and for all and maybe find the fault in my logic too.
Scribblings gave me a value around 6630lb's force yeald strength for a 3/4 inch dia 3/4 inch crankpin in a 3/4 inch web. Assuming a 1/4 inch pin is used diametrically (rather a large size) I came up with 2000 lb shear strength or 4000lb for the double shear which is less than the failure point of the loctite joint. So if the loctite fails so will the pin.
If the loctite fails at a higher torque than the pin the pin must then fail too making the pin redundant. If the arrangement is that the pin fails at a higher torque then the loctite is redundant. And before you say that the pin and the loctite share the load that can only happen if there is movement which there cannot be. and assuming we haven't come up with some cunning plan to pre-stress the pin before hand.
The only conclusion I can come to is pin it or loctite it but not both.
regards Martin
PS loctite do encourage the use of chemical retainers with interference fits and I can see the point of that because it's clear that the bond and the shrink fit will both add to the strength of the joint.
Edited By Martin Kyte on 10/09/2019 14:12:47
Neil Wyatt10/09/2019 14:49:35
19226 forum posts
749 photos
86 articles
The function of the pin is to stop nagging doubts in a corner of your mind
Jeff Dayman10/09/2019 14:55:33
2356 forum posts
47 photos
Not debating strengths or stress, but just an observation - the loctite statements assume that there was enough loctite, it was chemically OK, and the cure went perfectly. These things usually do occur just as it says on the bottle. But if it doesn't and something goes wrong with the cure, and you don't also have a pin in place, bad things are going to happen.
I like to hedge my bets on cranks and links by using loctite and also using spring pins, the type at link below. Just my opinion, and food for thought.
mick H10/09/2019 14:56:37
795 forum posts
34 photos
Apocryphal only, but I have heard from a loco man that caution should be exercised in using WD40 type lubricants as they can adversely affect Loctite joints. FWIW.
Mick
Michael Gilligan10/09/2019 15:39:52
23121 forum posts
1360 photos
Posted by Neil Wyatt on 10/09/2019 14:49:35:
I thought Religion was an unacceptable subject for discussion on this forum.
devil
Edited By Michael Gilligan on 10/09/2019 15:40:25
Baz10/09/2019 15:49:16
1033 forum posts
Where has religion been mentioned?
Michael Gilligan10/09/2019 15:51:25
23121 forum posts
1360 photos
Posted by Baz on 10/09/2019 15:49:16:
Neil wrote:
"The function of the pin is to stop nagging doubts in a corner of your mind"
... Which reads like Religious dogma to me.
Edited By Michael Gilligan on 10/09/2019 15:52:41
Andrew Tinsley10/09/2019 15:54:44
1817 forum posts
I wonder where the sense of humour went? Nice one Michael.
Andrew.
Nigel Graham 210/09/2019 16:22:05
3293 forum posts
112 photos
On those original calculations, which appear to be simply the static strengths of the crankshaft's components, the dimensions suggest to me a 7-1/4"g loco, so hefty piston areas and fairly long strokes hence crank radii.
However, what is the maximum shear load on the crank-pin likely to be, and perhaps more importantly, that on the web-to-shaft joint? Would the crank-pin shear load really approach a ton, even as a resultant of two cylinders at maximum cut-off and steam-chest pressure?
You don't give the details but a quick calculation gives a piston load of about 700lbs with 100psi in the cylinder, on a 3" bore; and that will apply until cut-off, although the torque developed on the joint between crank-webs and driving-axle (not crank-pin, as the big-end journal is sliding round it) will obviously go from 0 at dead-centre to maximum ft-lbs at slightly before mid-stroke. It's that the web-shaft joint, subject to a strong torque rather than simpler lateral (though rotating) load in the crank-pins and their joints, I'd regard as the potential weak-point.
The greatest shearing stress on the crank-pin, but with minimum axle torque, for each cylinder is at dead-centre or very slightly after, ignoring lead and admission pressure-rise effects. Short of taking indicator-diagrams, the actual pressure will be unknown but somewhat less than what the boiler gauge indicates. The crank load is partly relieved by connecting-rod angularity transferring some of it to the cross-head guides as the stroke proceeds, but the load obviously orbits the pin without trying to turn it, so alternating the stress directions.
Whilst appreciating it's necessary to ensure everything being strong enough, I think there will be a reasonable Factor of Safety in that proposed crank-pin assembly, but I'd worry more about that web-to-shaft joint. Still worth using both glue and pin though - and making everything as near to optimum as possible.
On using 'Loctite' and 'WD-40'...
I'd be happy to err on the side of caution and keep WD-40 away from 'Loctite' or indeed any adhesives apart from fully-cured epoxies, but despite what it says on the tin, it is not really a lubricant!
Nor really a penetrating fluid for anything but very light seizing, for which the good old 'Plus-Gas' is the purpose-made and better.
"WD" was chosen by the manufacturers as it stands for "Water Dispersant", its primary function, and it's good at that. It seems to be a paraffin compound, so is also good for washing proper lubricants out of bearings.
It is also good for cleaning a locomotive or other steam miniature after running, used sparingly with a clean cloth, but the water-repellent film it leaves is thin and not very tenacious, so for storage longer than a week or so I'd still wipe lubricating-oil over the cleaned bright parts.
It's quite handy as a cutting fluid for aluminium though!
Martin Kyte10/09/2019 16:42:06
3445 forum posts
62 photos
You are absolutely correct and of course I should have said web to shaft.
The point is why it's worth using glue and pin if indeed that is the case.
The question is about absolute failure modes really rather than what a loco would realistically produce. I'm really trying to acertain if there is any point at all in pinning as well as loctiting. The calcs (of which I am not best placed to do) should show if the pin is stronger or less strong than the loctite.
The crank pin dims were pulled out of the air as an example and as I said a 1/4 inch pin through the web is perhaps rather larger than would be typical.
The other side of the coin is the logical argument as expressed in my post.
At the moment I feel that there is no good argument for pinning if using loctite on the basis if the one fails then theother is going to as well.
The peace of mind argument is the same as Fred Dibnah banging in the ladder irons harder the higher he got. There was no point but he couldn't stop himself from doing it.
Hopefully someone will take the bait and do a proper analysis.
regards Martin
Edited By Martin Kyte on 10/09/2019 16:43:51
JasonB10/09/2019 17:11:17
Taking your figures, you would have a joint good for upto 6000 if just using loctite and a perfect joint. Or a joint good for 4000 if just using pins but to get them both to fail you would need 10,000 so the combined use is stronger than one or the other.
That gives me peace of mind as per my reply in the other thread even if over any load that is likely to be applied..
not done it yet10/09/2019 17:30:09
7517 forum posts
20 photos
Posted by Jeff Dayman on 10/09/2019 14:55:33:
Belt and braces are rarely both required but not finishing with your trousers round your ankles, when either of the two fails, certainly gives one peace of mind.smiley
duncan webster10/09/2019 17:35:49
5307 forum posts
83 photos
Posted by JasonB on 10/09/2019 17:11:17:
It's all about stiffness. As the OP says, if the loctite hasn't failed, the pin isn't loaded, or at least not very much, and if the loctite fails then the pin follows in quick time. They are not really sharing the load. Drilling a diagonal hole for a pin (if that is what is meant) reduces the strength of the shaft considerably. I once literally blew up a 1te jack trying to get some loctited wheels off, 17mm dia * 20 long seat. Scaffold pole on the jack handle and the cylinder burst. Get it nice and clean, use new loctite (it has a shelf life), and observe the manufacturer's recommendation for fits
Edited By duncan webster on 10/09/2019 17:37:19
fizzy10/09/2019 18:02:13
1860 forum posts
121 photos
Also bear in mind that whilst loctite may state that you have 10 minutes playing time before it cures to such a degree as to make manipulation by hand impossible I have found almost without exception that the true time is just a few seconds (I favout 272 for general fixings as it doesnt run). I would pin the crank.
Ron Laden10/09/2019 18:25:06
2320 forum posts
452 photos
I agree with Fizzy I was recently fitting the wheels to the axles on the class 22 using Loctite 638 and I didnt seat one correctly, when I realised which was no more than 30 seconds later I couldnt budge it, it was solid.
So despite what Loctite quote re working time in practice it is somewhat different.
Michael Gilligan10/09/2019 18:28:34
23121 forum posts
1360 photos
Posted by fizzy on 10/09/2019 18:02:13:
Not disputing your findings, but just a couple of thoughts:
  1. Copper is a powerful catalyst for the methacrylate curing process
  2. 272 is high-strength for a threadlocker ... but may not be optimum as a 'retainer'
https://www.henkel-adhesives.com/us/en/product/threadlockers/loctite_272.html
  • Breakaway torque on M10 bolts of 23 Nm
Edited By Michael Gilligan on 10/09/2019 18:29:10
Edited By Michael Gilligan on 10/09/2019 18:31:15
duncan webster10/09/2019 19:06:18
5307 forum posts
83 photos
Old loctite goes off more quickly, if you adjust it after it has started going off it weakens the bond. Don't ask how I know. If you do have to get it apart, warm up the joint, then clean it all up with paint stripper to get the residue off before you remake it.
Nigel McBurney 110/09/2019 19:38:29
1101 forum posts
I think in a large loco I would use square keys with keyways in shaft and crank ,made tight and driven in,plus loctite. An lternative I have used on small o/crank i/c engine with one inch shafts and crankpin was shrink fit plus 1/4 inch taper pins driven in hard and not meant to come out, no complaints from customer.
John Olsen11/09/2019 06:59:42
1294 forum posts
108 photos
I've just received the latest "Funnel" magazine from the Steam boat association and there is some discussion there about pinned and loctited crankshafts for the Leak compound engine. Apparently the published build instructions from Camden press suggest doing it that way, and apparently quite a lot of people have had trouble with cranks made that way. I didn't have the Camden book when I built mine, just the original Model Engineer articles, so I went for a crank locally cast in SG iron, which is also what the Funnel now suggests as a solution. It is interesting that the pinned and loctited ones should give trouble, since in a steam launch there should not generally be a lot of shock loading, unless you are in the habit of running hard aground. I would have thought that a locomotive would be more demanding.
Press fits with no keys work fine on many motorcycle crankshafts, but getting the right degree of interference could be a bit of a challenge in the home workshop
Robert Atkinson 211/09/2019 07:33:37
1891 forum posts
37 photos
I would dry assemble. drill for a small (1/8" / 3mm) pin and then clean and assemble with loctite retainer (correct fits etc). The pin is only an assembly aid to make sure everything is aligned properly. If you do use a large pin and loctite there will be some load sharing between the two as nothing is completely rigid.
Robert G8RPI.
