AdrianR | 14/06/2019 17:31:59 |
613 forum posts 39 photos | Hi I am trying to turn down the diameter of a 12mm Acetal rod to 8mm. I have tried a CCMT insert which does not seem to want to cut it. Sort of half cuts and deforms it. Does it want to run fast or slow? If I used HSS what is the best shape of tool to use?. Should I use lubrication? Any other hints? Adrian |
Andrew Johnston | 14/06/2019 17:35:43 |
![]() 7061 forum posts 719 photos | Try a CCGT insert, cut dry and the secret to machining plastic is slowish speed and high feedrates. In theory you can whizz through plastic, but the big problem is it melts - equals a right mess. Andrew |
Roger Woollett | 14/06/2019 17:50:20 |
148 forum posts 6 photos | I have machined Acetal from time to time. I use a HSS - keep it sharp with plenty of rake. I usually use quite high speeds - the same as I would use for brass. This gives a nice finish. |
ega | 14/06/2019 18:09:17 |
2805 forum posts 219 photos | See advice at: https://www.directplastics.co.uk/about_plastics/post/all-about-delrin-as-an-engineering-plastic |
Boiler Bri | 14/06/2019 18:54:45 |
![]() 856 forum posts 212 photos | We use tips made for cutting aluminium. High speed and high feed rate with air cooling.
Bri |
Howard Lewis | 14/06/2019 19:35:14 |
7227 forum posts 21 photos | Adrian, I would be inclined to use a HSS knife tool, or one with a small nose radius. Carbide tips are not really sharp, or intended for plastics. The nose radius will prevent the stress raiser of a sharp corner. Guessing at what you are making, may I suggest turning down the minimum length, for the spigot, and leaving the rest at the maximum required size? No point in making extra swarf for the sake of it! Howard |
Douglas Johnston | 14/06/2019 20:00:11 |
![]() 814 forum posts 36 photos | The sharp polished carbide tips as sold for aluminium are what I use and they work a treat giving a very nice finish. They don't seem fussy about speed or feed rates. In fact I now use these inserts for most of my cutting from plastic to aluminium to mild steel and stainless steel, they are just superb tips especially on smaller lightweight lathes. Doug |
Samsaranda | 14/06/2019 20:05:20 |
![]() 1688 forum posts 16 photos | I have had variable results with carbide on plastic, I now use HSS but make sure it’s sharp, I always cut at a reasonably slow speed, too much speed generates heat which you don’t want. Dave W |
Nick Hulme | 14/06/2019 20:10:57 |
750 forum posts 37 photos | I use polished the TC tooling specified for Aluminium when machining plastic, it works very well. |
Martin Whittle | 14/06/2019 20:57:30 |
102 forum posts 12 photos | The CCGT (which is ground to a polished sharp edge) should work very well indeed on delrin, which is also a joy to machine (if the tool is sharp).. The CCMT does not have a sharp edge at all! It is suitable for taking a deep cut on steel at high cutting rates, where the material at the cutting edge is raised to temperatures where it becomes soft (even close to red heat at the cutting edge). It is totally unsuited to shallow cuts on steel, or on plastics Hope this helps - I have been through this; some CCMT may be good for shallow cuts on steel, some is not, but I recommend CCGT for plastic. Martin |
Martin Whittle | 14/06/2019 21:06:59 |
102 forum posts 12 photos | PS I do use CCMT on steels for heavier use, but use CCGT for more gentle uses on all materials. The sharp tips on CCGT are more easily broken by the shocks from intermittent cutting loads on non-round work . I have generally been very pleased by cheap tooling from China Martin |
John Reese | 14/06/2019 21:34:39 |
![]() 1071 forum posts | I use HSS. Lots of rake and polished top and face. |
Mick B1 | 14/06/2019 22:25:21 |
2444 forum posts 139 photos | Posted by John Reese on 14/06/2019 21:34:39:
I use HSS. Lots of rake and polished top and face. +1, though a moderate rake as for mild steel works fine too, sharp and stoned fine. So long as you're slicing away the material rather than deforming it you can get a nice silky finish. Speed as for brass, but it's not especially critical. |
Gary Wooding | 14/06/2019 22:52:47 |
1074 forum posts 290 photos | I use a sharp tangential tool, medium to high speed. But the long swarf creates a birds nest if you're not careful. For the roughing cuts I move the saddle in bursts to let the swarf escape during each pause. The final, fine, cut is done in one movement so as to get a nice, even, finish. |
Sam Stones | 15/06/2019 01:24:38 |
![]() 922 forum posts 332 photos | Adrian, I sent you a PM. Sam |
AdrianR | 15/06/2019 07:52:41 |
613 forum posts 39 photos | Thanks for all the replies, I will give the HSS a try. I am trying to replace the broken oil pump/lift in my mill. Which in the parts list is called a Muddler. Which a dictionary tells me is a drink stirring stick. |
not done it yet | 15/06/2019 08:43:52 |
7517 forum posts 20 photos | Probably the easiest material I have turned. A sharp tool, I use HSS for this. Reasonably slow speed and watch out for heat - it can burst into flames apparently, except they are invisible! I have never tried to cut that length in small diameter. It likely needs small cuts and a following steady as it will easily deform, particularly with heavy cuts and when warmed up. Definitely keep the pressure axially, not radially. |
AdrianR | 16/06/2019 10:18:40 |
613 forum posts 39 photos | Well it turned out OK in the end, I made a couple of mistakes which ruined the finish in places, but I am happy with it. I rounded the part that broke and the camera angle makes it look a lot longer, |
Mick B1 | 16/06/2019 10:59:03 |
2444 forum posts 139 photos | How did you cut the helix? Looks very coarse for a ME type lathe. |
AdrianR | 16/06/2019 11:57:30 |
613 forum posts 39 photos | Yes it is coarse, it is 19mm pitch. I cut it on my ML2, I luckily had enough change gears to give me a 1:6 ratio i.e. lead screw 6 times faster than spindle, which gave me a pitch of 3/4". As I was overdriving the lead screw, I drove it from the lead screw by hand cranking the hand wheel. I used a narrow parting tool with a lot of rake, and made multiple passes with the left right offset supplied by the cross slide. The swarf was not completely cut free on by the tool, so I had to use a Stanley knife resting against the parting tool to occasionally gut the swarf away. Unfortunately my flexible drive is still in my old workshop down south, If I had that I would have tried using a router/milling cutter with the drive mounted on the cross slide.
