Matt Harrington | 13/04/2019 14:52:15 |
![]() 212 forum posts 16 photos | I'm looking to site my Transwave rotary converter out of my workshop. Firstly I don't have a suitable floor space for it and secondly, if I put it anywhere else, the vibration is too much - ie on top of a cabinet or on a shelf. So the thought was to site it outside in a waterproof box or cabinet. Anyone got any thoughts on this? and, of course, where I may get one! Matt |
SillyOldDuffer | 13/04/2019 15:18:55 |
10668 forum posts 2415 photos | How about a box from this lot. I think the hard part will be wiring it up. The regulations were tightened sharply a few years back. I expect one of the electricians will know. Dave
Edited By SillyOldDuffer on 13/04/2019 15:19:14 |
JasonB | 13/04/2019 15:24:09 |
![]() 25215 forum posts 3105 photos 1 articles | Don't they have louvred sides presumably for cooling which won't work well in a box. |
MichaelR | 13/04/2019 16:06:02 |
![]() 528 forum posts 79 photos | I don't know what size your rotary converter is but this item may do Link it seems to have air vents in door. Mike |
Maurice Taylor | 13/04/2019 17:58:36 |
275 forum posts 39 photos | Would a case from a scrapped air con unit be suitable ,they live outside . |
Matt Harrington | 13/04/2019 18:11:00 |
![]() 212 forum posts 16 photos | Posted by JasonB on 13/04/2019 15:24:09:
Don't they have louvred sides presumably for cooling which won't work well in a box. They do - but was anticipating either a larger cabinet or some form of ventilation. General limiting factor is that the depth (internally) need to be 450mm and then I'm going to have to use a rightangle 3 phase plug. I had thought of a garden box but I think I may end up making something - just need to try and make it resilient to the elements. Maybe a mini garden shed or lean to with lining.... Edited By Matt Harrington on 13/04/2019 18:12:15 |
Nathan Sharpe | 13/04/2019 19:25:25 |
175 forum posts 3 photos | How about a plastic coal bunker? Cheaper than the Adept cabinets and larger. My 500kg bunker is approx. 600 x 1200 x 1000mm, keeps the fuel dry so should keep your RC dry. N |
Bazyle | 13/04/2019 21:21:46 |
![]() 6956 forum posts 229 photos | Keeping the rain off and stopping fog and temperature changes making the guts damp are different things. Electrics don't like damp, especially 400v electrics. |
David George 1 | 14/04/2019 07:18:53 |
![]() 2110 forum posts 565 photos | If you put it outside you may have to put in a small tubular heater and thermostat in the enclosure to keep condensation at bay, have done similar for compressors etc in the past. You can wire a cooling fan if necessary to cool down equipment as well. We just knocked up a wooden and board structure with plenty of room and loovered door David |
Matt Harrington | 14/04/2019 09:45:40 |
![]() 212 forum posts 16 photos | Posted by David George 1 on 14/04/2019 07:18:53:
If you put it outside you may have to put in a small tubular heater and thermostat in the enclosure to keep condensation at bay, have done similar for compressors etc in the past. You can wire a cooling fan if necessary to cool down equipment as well. We just knocked up a wooden and board structure with plenty of room and loovered door David David, I'm tending to think about going this way and I do have a spare tubular heater ! Matt |
SillyOldDuffer | 14/04/2019 10:46:08 |
10668 forum posts 2415 photos | Posted by Bazyle on 13/04/2019 21:21:46:
Keeping the rain off and stopping fog and temperature changes making the guts damp are different things. Electrics don't like damp, especially 400v electrics. Given the cost of replacing a rotary converter and the dangers of wet electrics, that worries me a bit too. Certainly not an insoluble problem but I think there are a number of questions worth asking before deciding on a solution:
Matt's options are much wider if he lives on a farm and can put the box in a sheltered private spot. A different arrangement would be needed if the converter and wiring was to be located next to a public pavement in the window box on the weather side of a London flat. Dave |
Dave Halford | 14/04/2019 19:30:06 |
2536 forum posts 24 photos | It has to be said that every cable company, no matter who built the network does exactly what is being discussed in their streetside equipment cabinets. They all have mains in them and they can all be touched by the public. Some get slugs crawling over the cct boards Nothing dies except the slugs and I don't believe any cabinets catch fire. The worst thing that happens is single skin ones bake in the summer sun, which kills the batteries. |
Jon | 14/04/2019 20:18:11 |
1001 forum posts 49 photos | Other thing to consider is neighbours and the noise putting it outside.
SillyOldDuffer | 14/04/2019 20:23:46 |
10668 forum posts 2415 photos | Posted by Dave Halford on 14/04/2019 19:30:06:
It has to be said that every cable company, no matter who built the network does exactly what is being discussed in their streetside equipment cabinets. They all have mains in them and they can all be touched by the public. Some get slugs crawling over the cct boards Nothing dies except the slugs and I don't believe any cabinets catch fire. The worst thing that happens is single skin ones bake in the summer sun, which kills the batteries. True, but Cable cabinets are probably over the top for Matt's needs.
Dave Halford | 15/04/2019 11:21:02 |
2536 forum posts 24 photos | The old ones are simple boxes, the mains supply got no special treatment. You don't need a Rolls to go shopping Edited By Dave Halford on 15/04/2019 11:26:03 |
Bazyle | 15/04/2019 11:30:55 |
![]() 6956 forum posts 229 photos | Cable cabs don't have mains or even the ELV, it's normally 48v, and all the electronics are in sealed boxes. The telephone wire terminations are the only exposed elements which is why they can suffer from noise on the line. |
Stuart Smith 5 | 15/04/2019 13:54:48 |
349 forum posts 61 photos | I suppose it depends how much you want to spend. Here are links to 2 suppliers of steel cabinets: Or you could make a brick cubicle with a concrete flag as a roof. |
Stuart Smith 5 | 15/04/2019 13:57:38 |
349 forum posts 61 photos | This a drawing of a brick cubicle used for temporary electricity supplies. |
larry phelan 1 | 15/04/2019 17:25:49 |
1346 forum posts 15 photos | I have a 10hp R/c to power my workshop. I mounted it on an angle iron frame,screwed to the wall,one to cut down on the noise by being mounted on a shelf [this was a no-go,too noisy ] The second reason was to save floor space.. There was still some noise from it,not a lot,but this was solved by fitting a plywood cover,open at the bottom. To date this has worked well,noise is very little,damp is not a problem. I would say,keep it inside,too easy to have it knocked off,and they dont come cheap. |
Matt Harrington | 15/04/2019 17:44:58 |
![]() 212 forum posts 16 photos | Posted by larry phelan 1 on 15/04/2019 17:25:49:
I have a 10hp R/c to power my workshop. I mounted it on an angle iron frame,screwed to the wall,one to cut down on the noise by being mounted on a shelf [this was a no-go,too noisy ] The second reason was to save floor space.. There was still some noise from it,not a lot,but this was solved by fitting a plywood cover,open at the bottom. To date this has worked well,noise is very little,damp is not a problem. I would say,keep it inside,too easy to have it knocked off,and they dont come cheap. Larry, I have been deliberating over this and your idea sounds like it is worth a go. I have some high density foam and was thinking about mounting it on that which in turn is on a board which is then screwed to a frame. I am thinking about boarding the loft space in the garage and so if I mount the frame above that I maybe able to save on the noise as well. Remote switching of the RC will be OK (have checked!) By the weekend I should have formed a plan!! Thanks for all the input - I have decided against an outside box ......
Matt |
