andrew lyner | 26/12/2018 22:57:47 |
274 forum posts 5 photos | One of the 'excuses' I used for buying my Mini lathe was to allow me to make up 2" extension tubes and adaptors for my astro telescopes. Ideally, they have internal threads to suppress reflections from the sides of the tube (shallow and no particular pitch required). The lengths of tube involved would be up to say 150mm, which is a lot of overhang so I wanted to make a steady rest so I can work inside the tube safely. There are dozens of designs on Google Images to give me a clue as to a design for a steady that I would have a chance of making but my main question is just how chunky it needs to be. It would be easier if I could make it mostly out of aluminium, and to use some tough 40mm steel angle to sit on the bed. There would be a good area of contact so the off-plane clamping arrangement would not be a problem I think. I do have some 6mm steel plate of the right size but I hesitate to try to mill it on my mini lathe vertical mill slide. I could go easy, I suppose and I could weld it to be steel angle base. Mig welding is another thing I am getting into so it would be a suitable learning project for that skill. Unfortunately it could end up looking like a dog's dinner right next to the nice new painted lathe.
Ady1 | 26/12/2018 23:11:23 |
![]() 6137 forum posts 893 photos | Drummond owners tend to do their own The original Drummond M had a very poor fixed steady |
Ady1 | 26/12/2018 23:14:31 |
![]() 6137 forum posts 893 photos | I tried ball bearings to start with but the loading was too heavy, they dig in Nice fat (phosphor?) bronze finger tips worked best for me |
Nick Wheeler | 26/12/2018 23:15:44 |
1227 forum posts 101 photos | You could easily fabricate a steady from your 6mm plate by screwing and welding it together after cutting out with a jigsaw; barely any milling required. |
Michael Gilligan | 26/12/2018 23:36:47 |
![]() 23121 forum posts 1360 photos | This was a popular design a few https://auction.newengland.co.uk/lots/4-point-fixed-steady-suitable-for-myford-lathe The concept would adapt, I'm sure MichaelG. |
Robbo | 26/12/2018 23:52:55 |
1504 forum posts 142 photos | Have a look at this page on Harold Hall's website homews.co.uk - **LINK** There are lots of designs about |
Michael Cox 1 | 27/12/2018 09:17:42 |
555 forum posts 27 photos | Here is my solution: http://mikesworkshop.weebly.com/large-fixed-steady.html Mike |
roy entwistle | 27/12/2018 09:43:49 |
1716 forum posts | At a pinch could be made from wood but keep lubricated. Roy |
Mick B1 | 27/12/2018 10:03:05 |
2444 forum posts 139 photos | Go for the easiest solution you can afford. If there's a suitable 3-point for your model of mini lathe, or one you could modify, don't waste time you could be using to make the things you actually want. It's too easy to become enmeshed in tooling projects that never leave you free to pursue your real interests. |
Neil Wyatt | 27/12/2018 10:06:52 |
![]() 19226 forum posts 749 photos 86 articles | Here's an alternative approach... Neil |
Ian P | 27/12/2018 10:47:58 |
![]() 2747 forum posts 123 photos | This was a quick lashup on a Boxford. (Tailstock and carriage obscure where the contraption is fixed to the bed) Ian P Edited By Ian P on 27/12/2018 10:48:32 |
JasonB | 27/12/2018 10:51:12 |
![]() 25215 forum posts 3105 photos 1 articles | How much excess meat does the supplied one have, there may be room for enlargement? |
andrew lyner | 27/12/2018 14:37:27 |
274 forum posts 5 photos | Posted by JasonB on 27/12/2018 10:51:12:
The lathe comes without one. But I have only a small milling slide and no circle facility either. |
andrew lyner | 27/12/2018 14:40:08 |
274 forum posts 5 photos | Posted by Mick B1 on 27/12/2018 10:03:05:
Go for the easiest solution you can afford. If there's a suitable 3-point for your model of mini lathe, or one you could modify, don't waste time you could be using to make the things you actually want. It's too easy to become enmeshed in tooling projects that never leave you free to pursue your real interests. That's a good point but i need the practice and the steady wouldn't;t be 'on show' if it ends up a bit scrappy. Edited By andrew lyner on 27/12/2018 14:42:58 |
andrew lyner | 27/12/2018 14:43:59 |
274 forum posts 5 photos | Posted by Michael Cox 1 on 27/12/2018 09:17:42:
Here is my solution: http://mikesworkshop.weebly.com/large-fixed-steady.html Mike Very nice Mike. |
Paul Lousick | 28/12/2018 10:30:20 |
2276 forum posts 801 photos | The January, 2019 edition of MEW has a design for a fixed steady with ball races. Paul. |
