Electrolux vacuum - Need to make a missing wheel
OuBallie23/10/2018 15:08:42
1181 forum posts
669 photos
More advise please, this time on making a replacement wheel that other half somehow 'mislaid' whilst using the vacuum.
I could of course make a mould and use epoxy or similar to make one but wonder what the alternative solutions would be.
The easiest no doubt from wood, the various pieces glued up and then a nut and bolt to secure a large washer on the inside in place of the moulded in 'clip' of the originals.
Electrolux Powerlite 1700W
Geoff
John Rudd23/10/2018 15:26:31
1479 forum posts
Posted by OuBallie on 23/10/2018 15:08:42:
Geoff
Aww, c'mon....just treat her to a new vacuum cleaner...( you could then divert the broken one for the workshop...)
How about making a wheel from alloy, more durable than wood and easier to machine than a steel one?
Edited By John Rudd on 23/10/2018 15:27:41
AJW23/10/2018 15:55:48
388 forum posts
137 photos
Bet you find it once it's made!
Alan
Carl Wilson 423/10/2018 15:56:52
670 forum posts
53 photos
The first question in maintenance is is it worth repairing?
peak423/10/2018 16:11:09
2207 forum posts
210 photos
I know where you are coming from, as I tend to use the workshop to mend stuff too.
However, is your errant wheel listed HERE, sometimes it's just easier.
Bill
Jeff Dayman24/10/2018 04:13:00
2356 forum posts
47 photos
I'd look online first for a replacement wheel. I'd be surprised if you can't find one - millions fell out of that mould, likely.
A piece of Delrin 73 mm diameter would not be cheap, or a plate of it to cut a wheel out of. To get the "collet" style fastening of the old wheel, you would probably have to make the centre in one piece and the wheel from another, with screws thru the webs to join them. Kind of complex and probably expensive for material, and not a great way to fasten a wheel anyway, they did it like that originally for el cheapo manufacturing.
Maybe instead you could fit a tight fitting hard wooden bung glued into the spigot, and pass a steel axle through it. A new wheel to run on said axle could be turned up from aluminum or PVC tube to form a rim and a wheel centre of steel or aluminum or PVC glued and/or pinned to the rim. If you used a bolt with a nylock nut for the axle, no way Her Honour will be losing that one!
Good luck.
Neil Wyatt24/10/2018 10:16:26
19226 forum posts
749 photos
86 articles
A candidate for 3D printing in PETG if there ever was one!
If you have no joy with Bill's link (and I reckon you will) you could use the free Alibre Atom3D licence (plug, plug), draw one up, save as an STL and send it to Shapeways for printing
Colour match may not be spot on...
Martin W24/10/2018 11:29:36
940 forum posts
30 photos
Geoff
If you know the model and number of the cleaner then you could try looking here. They not only stock current machine spares but also some for older models that are now not available from the manufacturer.
Martin
OuBallie25/10/2018 17:10:50
1181 forum posts
669 photos
Thanks for all the suggestions.
I've searches the two sites mentioned, but nothing for the 900252111 model this one is.
Will have to have a think on which of the methods suggested I will use.
Geoff - Updates as and when as usual.
PS.
fixed the £5 Dyson Telescope she bought as 'Not working' at a car boot sale, it taking longer to figure out how to get the motor out than actual fixing, and that entailed a new brush and soldering its lead to the spring holder.
Geoff - It's the satisfaction of bring things back to life instead of binning them.
Howard Lewis25/10/2018 22:42:38
7227 forum posts
21 photos
Geoff,
Right with you on returning things to a useful life, instead of the Kleenex mentality of "scrap and replace"
After all, we are supposed to be Engineers (comes from the same Greek root like ingenious)
Does the wheel HAVE to be "plastic"? I'd rather make one out of Aluminium, and run it on a steel axle secured (possibly threaded) to the housing with an anaerobic.That should outlast the rest of the machine!
Frances IoM25/10/2018 23:28:08
1395 forum posts
30 photos
the reason for plastic rather than metal is that bumps into furniture or paintwork are unlikely to damage them - I found a workable Hoover at our local amenity centre that just needed an full clean + a new wheel which was easily done out of some scrap of nylon bar - very convenient as my too heavy 1st generation Dyson had finally jammed its wheels
Edited By Frances IoM on 25/10/2018 23:28:43
OuBallie04/11/2018 11:02:39
1181 forum posts
669 photos
It's done.
More photos in the 'Vacuum machines' Album.
Dyson:
Apropos my PS on last post, herewith photos of said brush replacement.
They are certainly NOT meant to be replaced and just another design 'feature'.
The brushes are held in place by a cover that has lugs twisted when installed, let alone the hustle in removing the motor.
Dyson Telescopic
Dyson Telescopic
Dyson Telescopic
The brush crumbled as I withdrew it.
Dyson Telescopic
Electrolux:
I will have to resort to using my DSL camera I think in order to prevent the utter annoyance of phone photos appearing sideways.
Howard Lewis' suggestion of an aluminium wheel echoed with my first though.
Herewith progress and end result:
Works a treat
Geoff - i've achieved something lately at last
Jeff Dayman05/11/2018 03:59:44
2356 forum posts
47 photos
Nice job! well done, both on returning the implement to service, and keeping it out of the landfill while it can be made to keep working .
FMES05/11/2018 06:47:29
608 forum posts
With ESpares showing 34 pages of Electrolux wheels and most of them costing less than a tenner, was it really worth while?
martin perman05/11/2018 09:19:39
2095 forum posts
75 photos
There is nothing better than being told you cant fix it and proving you can, I would fix every time.
Martin P
OuBallie05/11/2018 10:41:18
1181 forum posts
669 photos
Jeff/Martin,
yes
FMES:
Checked that site twice now, and all others I could find but nothing for this model machine.
No dimensions shown anywhere that I could find, so wasn't going to go through the hassle of buying, only to return ad nausium.
Only took a few hours to make, governed by the amount of metal the lathe would remove.
Geoff - Most satisfying as was fixing the Dyson.
FMES05/11/2018 11:43:51
608 forum posts
Posted by OuBallie on 05/11/2018 10:41:18:
Jeff/Martin,
yes
FMES:
I bet you didn't email or call them, they found an obsolete pump for my washing machine within two days, and if you provide them with the model and part number details they usually come up trumps.
I don't mind manufacturing things that can no longer be bought, but time is too valuable to be messing around with making stuff that is cheaper to buy.
Sometimes you just have to weigh up costs to replace against time and materials required to manufacture.
Mike Clarke05/11/2018 12:28:45
95 forum posts
Nice job Geoff - and looks smart. I think you should do the other side too!
I once had a little Sharp milling machine which had aluminium handles - and every time I used it my hands would be absolutely jet black. I guess this was mostly down to oil and grease on the skin, but I would be mindful of the potential of the bare aluminium leaving a mark on light coloured carpets.
John Rudd05/11/2018 13:09:05
1479 forum posts
Posted by FMES on 05/11/2018 11:43:51
But if the replacement part made by one'sself is of better quality then the investment is worth it
Geoff, good result....I wish you and your replacement wheel a long and lasting relationship...cheeky
Michael Gilligan05/11/2018 15:00:58
23121 forum posts
1360 photos
Posted by John Rudd on 05/11/2018 13:09:05:
+1 yes
