Bernard Reilly | 03/08/2018 22:35:57 |
30 forum posts | Hi all can anyone put me in touch with someone who would be prepared to make up a ring light for my RF25 mill/drill. I have a suitable 4 inch adapter plate .The unit could be powered from a mobile phone charger. I do not posses electronic knowledge to take on this project myself. I would to pay be happy to pay for this service provided it is not an arm or a leg. Thank you Bernard Reilly Glasgow, |
Paul Lousick | 03/08/2018 23:25:17 |
2276 forum posts 801 photos | Hi Bernard, There are lots of inexpensive LED lights available on ebay, including ring lights. Either 5 volt versions which will work with a USB phone charger or 12 volt versions for other power supplies. Both are low voltage units and safe to play with. Paul. Edited By Paul Lousick on 03/08/2018 23:26:32 |
mike T | 03/08/2018 23:34:21 |
221 forum posts 1 photos | Hello Bernard, This is what I use on all my machines https://www.ebay.co.uk/itm/7Sizes-Universal-Car-LED-Halo-Ring-Lights-Angel-Eyes-DRL-Durable-Headlight-Lamp/223015314547?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Da162edbc64be4e19968ff6f73d80a3a7%26pid%3D100675%26rk%3D5%26rkt%3D15%26sd%3D132200509432%26itm%3D223015314547&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Aa62f74ac-976c-11e8-bf69-74dbd1804ddb%7Cparentrq%3A01e8b8881650a9e8318380c5ffeab070%7Ciid%3A1 I use the 120mm diameter version and drive it with a 12 volt 'wall wart' power supply. I glue on some aluminium brackets and magnets. Mike |
Neil Lickfold | 04/08/2018 00:46:29 |
1025 forum posts 204 photos | What a great idea, and really cheap as well. Neil |
martin107 | 04/08/2018 05:35:19 |
62 forum posts 2 photos | This is what I use on my mills they are great with the magnetic base and flexible arm, they just run off a USB charger and at £7 won't break the bank https://www.amazon.co.uk/gp/product/B073FGLYFR/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 Martin |
JasonB | 04/08/2018 06:59:00 |
![]() 25215 forum posts 3105 photos 1 articles | I see Sieg have started to put USB sockets onto their milling machines for us to plug lights and bluetooth devices straight into thus freeing up a wall socket. I prefer a light that can be moved about, if you are using a small short cutter in a ER collet chuck you will get a big black shadow from it where the ring light won't reach.
Edited By JasonB on 04/08/2018 07:00:50 |
David George 1 | 04/08/2018 07:29:16 |
![]() 2110 forum posts 565 photos | This is one I made a few weeks ago
Magnetic base recycled, lamp insides from Ikea, flexible stem ex microphone stem short length of aly tubing David
Neil Wyatt | 04/08/2018 08:01:56 |
![]() 19226 forum posts 749 photos 86 articles | I have a Jansjo table lamp on the headstock of the SC4 - 510. They do a smaller USB version. |
Phil Stevenson | 04/08/2018 09:35:54 |
90 forum posts 13 photos | Not precisely what was asked for but could be interesting nevertheless; mains powered. Look at the several variants. **LINK** Stupid cheap and even cheaper if you take the slow boat from China option. |
Vic | 04/08/2018 11:00:06 |
3453 forum posts 23 photos | I bought a dedicated LED magnetic work light for one of my Lathes and quite frankly the light quality is pants. No where near as good as the Halogen lamp that came fitted to my mill. I’ve since bought an Ikea Jansjo LED and that’s not too bad. Sadly they don’t sell a mag base version though so I removed the plastic base and fitted it to a spare mag base. They do sell a clip on version but it doesn’t look too durable. |
Alan Wood 4 | 04/08/2018 12:46:47 |
257 forum posts 14 photos | I believe the request was for a ring light not a point source on a goose neck. I used a so called Angel Light ring from EBay See **LINK** Contact me if none of the experts can help and I can run you an appropriate 3D print. |
Enough! | 04/08/2018 16:37:42 |
1719 forum posts 1 photos | I built a ring light some time ago - Angel Eyes from eBay + 3D-printed housing. However, as Jason pointed out above (and JS pointed out at the time) it does cast a shadow under some (actually many) cutters and was not nearly as useful as I expected. Plus the housing got in the way occasionally. I took it off in the end. |
