choochoo_baloo | 16/07/2018 13:21:34 |
![]() 282 forum posts 67 photos | I am extending my workshop by ~ 3 x 5m. Can others advise on the optimum depth of concrete to use as a workshop floor to take machine tools so that there's no risk of cracking (obviously the ground has been well prepared including scalpings etc etc). In case it matters, I will also finish the concrete pad with a quality warehouse grade 2 part resin to seal it in order to avoid the dust that accumulates as concrete surfaces age. Thanks in advance. |
Muzzer | 16/07/2018 14:00:37 |
![]() 2904 forum posts 448 photos | My workshop / extension has 6" deep concrete which seemed to be what was expected by the regulations. Whether that's specifically mandated or just local practice I don't know. I paid a little extra (a few hundred vouchers) to have steel mesh reinforcement included. It isn't going to crack any time soon.... Bear in mind that resin floor covering isn't going to last unless the concrete is successfully laid. The cowboys who laid mine either did it during a downpour or simply added too much water (I was in China at the time, so wasn't present). Consequently, the surface lacked any obvious strength and now looks like the surface of the moon in places. I sealed and painted the surface but where stressed it has come away. The dream flooring would be something like Flowcrete Flowfresh SL self levelling polyurethane resin. That'll have to wait for the retirement workshop..... Murray Edited By Muzzer on 16/07/2018 14:08:40 |
Brian Wood | 16/07/2018 14:01:29 |
2742 forum posts 39 photos | I imagine 4 inches (100 mm) or so, erring on the side of thicker. Regards Brian |
John McNamara | 16/07/2018 14:14:32 |
![]() 1377 forum posts 133 photos | Hi CB The design of a slab and its edge and cross beams is determined by the type of soil it sits on. and the weight of the building it must support, however building weight is not normally the problem if single story. Soil stability is. Scalpings, sand, crushed rock etc will allow leveling a site but will not really help if the soil underneath them is low grade I know this sounds like a lot of effort but we spend many many ours in our shed, It must be right. (I am not a soil Engineer) I do however work with them as I did on site this morning discussing how to tackle an extension to an 1880 Victorian dwelling, yes the Victorians built attractive buildings however they knew very little about footings, as the often seen cracks prove. I see this time and again, Its a wonder they stay up, and it creates a lot of problems when modifying them. Regards Edited By John McNamara on 16/07/2018 14:15:06 |
Martin Connelly | 16/07/2018 14:19:36 |
![]() 2549 forum posts 235 photos | If it is tied into an existing structure it should match that in order to avoid subsidence cracking. I also put reinforcing mesh in my concrete base. As Muzzer says it isn't going to crack and its not very expensive to add. Martin C |
JasonB | 16/07/2018 14:37:17 |
![]() 25215 forum posts 3105 photos 1 articles | Mine is 4" compacted hardcore and approx 4" concrete with a sheet of A142 mesh, not moved for the last 25yrs. 2.8m x 4.9m. Topsoil dig out and onto the clay. |
Antony Price | 16/07/2018 14:48:09 |
36 forum posts 29 photos | My thoughts! Install a damp proof membrane under the slab Minimum of 100mm/4” Check out and agree the mix ratios prior to work being done. In my case what went in was a bit weak on the cement, which resulted in a dusty top layer Tony |
Mark Rand | 16/07/2018 16:59:44 |
1505 forum posts 56 photos | Posted by Antony Price on 16/07/2018 14:48:09:
Happened for my shed as well. if I'd known the grief it was going to cause I would have complained to the 'large, Warwickshire' cement company that supplied and pumped the concrete. They would have dug it up and re-supplied it as a result of it not being to spec. Driver had sanded and watered the second truck full as he filled too soon and couldn't set off and deliver until we'd got most of the way down the 5m^3 in the pump truck. |
Muzzer | 16/07/2018 20:00:42 |
![]() 2904 forum posts 448 photos | The guys who laid my concrete had one of those mixing systems that is supposed to ensure the correct ratios which I suspect is a requirement for many commercial installations. However, there's no foolproof defence against glue sniffing village idiots with a hosepipe or no regard for the weather. It looked fine for the first couple weeks but the expected final hardness never quite materialised, quite the opposite. The only sensible option would have been another inch or two on top but you need 6" between a garage / workshop level and a living area. And I needed part of the extension on the same level as the existing kitchen to gain the approval of the Domestic Manager. At times like that you just put it behind you and move on. However, it'll be a bit of a bugger moving the heavy gear out across the lunar landscape when the time comes for the next move. Murray |
Bazyle | 16/07/2018 22:58:07 |
![]() 6956 forum posts 229 photos | You should only need 4in of good concrete for a domestic workshop but definitely with steel mesh 1 inch up from the bottom. You can also get fibres to add strength which I have not tried but are pretty cheap so worth considering. Don't do what the youtube cowboys do and plonk down the mesh, throw the watery concrete on and yank the mesh up a bit. I wouldn't use the modern little plastic spacers either as they leave voids. Make 2x2x1 inch cement square spacers each with a twist of wire in it sticking up to attach to the mesh. Sequence should be: dig out topsoil as organic matter would decompose over time and leave voids, pound in hardcore, top with sand blinding to protect the DPC from the hardcore, lay DPC under the 4in EPS insulation, second DPC, add the spacers on extra pads of DPC material to protect the DPC and plastic heating pipe 'cos you can't do it afterwards, pour concrete possibly with modified mix for top 1 in for finer surface, wait a bit, float surface to fine finish. Leave long enough for curing and drying before applying paint, all that water has to go somewhere. |
Michael Gilligan | 17/07/2018 09:03:55 |
![]() 23121 forum posts 1360 photos | Slightly off the topic, but interesting: Whilst searching for information about the threatened hosepipe ban, I found an advert for: **LINK** https://www.plasticshedbase.co.uk/ The specification looks quite impressive MichaelG. |
clogs | 17/07/2018 09:41:22 |
630 forum posts 12 photos |
I always go for 9" for a normal shed, easy to mix ur'self on site...... was it 2 ton of concrete per hour on 1 of the gardening progs...the guy was well over 50.....!!!!! my next build, 10mx10m will be a full 16" thick with rebar etc(ready mix tho) because of a 2 poster car lift...... it'll also be on 50-100mm high density polystyrene isulation with a dampcourse....... Luxury oh Luxury underfloor heating as well.......... |
clogs | 17/07/2018 09:54:30 |
630 forum posts 12 photos | forgot to say, when living in California, on the bigger manul jobs we'd get a gang of mates round to get the work done quick..... the women would turn up before lunch to get the grub ready....... then when the job was done have a B+Q and a few beer's, u get the job done and everybody likes free beer and food..... also a close friend moved to a tiny village in Crete, up in the hill's.......nobody local knew.......after an hour the whole male population turned up to help with the unloading of the truck........after the job was done they, my friends were dragged off to one of the houses for an impromptu meal........how nice is that.......... makes for a great day....it's good to share........well I think so....... clogs |
Bob Brown 1 | 17/07/2018 11:01:02 |
![]() 1022 forum posts 127 photos | Do not forget there are different grades of concrete and you can specify a fibre reinforcement if using ready mix. |
Simon0362 | 17/07/2018 11:48:28 |
279 forum posts 91 photos | Timely topic.... The builders are hard at work on my garage/workshop extension (4m x 6.5m) with a feature that might be of interest to others: I am having two large (5000l) concrete septic tanks installed under the floor which will become part of the structure. They are roughly 1.9m high, 1.6m wide and 2.2m long with a manhole access. We intend to cut a proper trap door size hole in them and install a step ladder style access. Ventilation to be installed as well. I think we can assume that they will be waterproof...... Just large enough for a set of shelving for all of those things that like to be maintained at a near constant temperature - like paints, glues, etc, etc. Number 1 will be for workshop use, number 2 will be the wine cave.....
The guys have just finished digging the hole - they got down to around 30cm above the desired depth and hit bed rock - this morning has seen the slow pneumatic hammering away, layer by layer. Gravel to be laid under the tanks, then side filled and then the real workshop foundations dug around them. When the floor is laid the tanks will become part of the reinforcement. Intending to get one of those super-smooth finishes on the concrete and then seal with 'something'!
(not sure how to twist this around......sorry!)
Simon Edited By Simon0362 on 17/07/2018 11:50:38 |
Ian S C | 17/07/2018 12:03:52 |
![]() 7468 forum posts 230 photos | When I extended the garage for a workshop I got the piece of floor where the lathe is doubled in thickness, and extra reinforcing mesh in that area, it handled earthquakes and after shocks ok, but would not come up to the latest building standards, the foundation regs in NZ are much more complex now. Ian S C |
Speedy Builder5 | 17/07/2018 14:33:08 |
2878 forum posts 248 photos | Simon, I hope they don't float away. When they install septic tanks around here, they fill them with water to stop them floating in the ground water. Even swimming pools can float if they are empty - think concrete Thames barges! Good luck and I hope I am wrong. |
Speedy Builder5 | 17/07/2018 14:34:15 |
2878 forum posts 248 photos | Workshop floor 16" thick - must be a typo unless you have a 500 ton press in the workshop. |
choochoo_baloo | 17/07/2018 14:42:12 |
![]() 282 forum posts 67 photos | Thanks all for the input, useful detail as always on this forum. I should have clarified, this isn't actually an extention as I initialy stated - sloppy language. It's a new stand alone building to sit behind the existing gable garage. After some further research I'm hoping you can all comment on the following:
John McNamara | 17/07/2018 15:11:55 |
![]() 1377 forum posts 133 photos | Hi CB |
