Member postings for Antony Price
Here is a list of all the postings Antony Price has made in our forums. Click on a thread name to jump to the thread.
Thread: Building the Stent Tool and Cutter Grinder
31/12/2021 17:02:03
Hi Thomas
If you “pm” me with your contact details, I’ll email you with all the copies of the articles I’ve managed to get hold of
Tony
Thread: Shims
28/12/2021 12:36:28
Hi Bill
Old bank/credit/loyalty cards are also a good source of shim/packing
Tony
Thread: Digital Acces to back issue
16/12/2021 20:34:06
Hi Peter
I've just sent you a private message
Tony
Thread: Wanted Advert: Model Engineers Workshop 256 July 2017
02/03/2021 10:54:47
Hi Carl
I’m trying to get in contact with you, but your public profile settings are not letting me. I have a spare copy of MEW 256. Contact me to sort out getting it to you
Tony
Thread: Starting out a young enthusiast
24/02/2021 15:14:10
Hi Vivienne Please see my private message which I've just sent to you
Tony
Thread: Colchester Triumph 2000 taper turning attachment - missing parts
19/06/2020 17:14:53
Hi Martin
Where are you in the UK?
I have one, its from an M250 and I've also been advised it will fit an M300
I can easily do some photos for you. Measuring it up for some drawings, will take a bit longer
Send me a pm for contact details
Tony
25/06/2019 16:42:15
Hi
My thanks to IanT, Thor and JohnF for their offers of help. I now have all the articles I was looking for. I’ve spent this afternoon, reading through the articles in preparation for the build. The castings etc I have are part machined, and it look like the work already done is to a high standard. I now need to understand the modifications that have been done to the original design and if I should/could incorporate them
I think my next job is to document the tooling that came with a Clarkson T+C grinder, I purchased 6 years ago with the intention of getting it up and running. It’s stayed in the corner since, and now I have this project, I think it is time to release both the money and the space.
Thank you to all the offers of help
Tony
24/06/2019 20:49:24
Hi IanT
PM sent
Tony
24/06/2019 20:41:27
Hi Rod
I'm in Leeds West Yorkshire
Tony
24/06/2019 18:40:56
Hi
Is anybody able to help me with getting copies of the Model engineer article series on “Building the Stent Tool and Cutter Grinder” ? The Online archive doesn’t go back far enough. The table below confirms which year and volume the articles appeared in.
If you are able to help please private message me. I’d be happy to pay any reasonable costs for copying and posting.
Thanks
Tony
Year   Volume   Issue    Page
1991  167            3910     624
Blackgates Engineering. Getting started, construction: the main castings
1992   168           3912      44
The trickier operations. The dovetails
1992  168             3914     165
The smaller assemblies. The main feed assembly, picture on page 123
1992   168           3916      264
Cutting of the rack and pinion. The table traverse
1992   168           3918      393
Motor slide assembly, grinding spindle.
1992   168           3920      508
Drive arrangements. The motor and pulley assembly, the tool holders and guides
1992   168            3922     654
Tailstocks and final details. Conclusion
Edited By Antony Price on 24/06/2019 18:46:16
Thread: First Project
17/06/2019 09:45:38
Re: machining experience (zero)... some thoughts
The SMEE run courses on “Basic Training for Model Engineers” , “Lathe Tool Grinding” and “Milling”. I’ve done the lathe tool grinding and milling courses both of which I found useful in raising my knowledge base
The SMEE run a Building a Simple Steam Engine (“The Polly Course). I haven’t done this one, but those that have give it a ”thumbs up” .
The bad news is that the Polly Course only runs one a year and has already started
Tony
Edited By Antony Price on 17/06/2019 09:46:17
Thread: Precision Level or Precision Frame Level
03/05/2019 15:09:52
Hi JB
I’ve just spent the last week sorting out my Harrison T300 lathe...I tried using the Rollie Dads method but found the accumulation of errors (taper adaptor, test bar etc) difficult to resolve, so went for levelling the lathe. Having levelled the lathe, I did a test piece and had an error of 1/1000” over about 6”. Tweaking the relevant lathe foot, now gives me no error over 6”
If you would like a recommendation: the level I used was a Moore And Wright Machinists Spirit Level. 12”/300mm. I found it perfect for the job required. My level was second hand, from the well known auction site. I’ve just checked and there is one currently available (buy it now £79.99)
Hope this helps
Tony
Thread: #10 stock?
23/04/2019 11:00:40
Hi BugBear
Googling brings up
24mm long “Metal Shelf Support PEGS Stud PIN PEG Kitchen Cabinet 5MM Hole” (Amazon)
https://images-na.ssl-images-amazon.com/images/I/81a9LxOPsbL._SL1500_.jpg
At £2.63 including delivery would it e worth a punt to see if they are what you are looking for?
Tony
Thread: My ford quick change gearbox
16/01/2019 11:58:49
Hi David
I would another reference book along side “Screw cutting in the lathe” . For Christmas, I was given “The Gearing of lathes for Screwcutting “ (Crowood Metalworking Guides). It has two chapters “The Myford ML7 and Variants” and “The Myford ML7 with the David Machin Gearbox”. It has lots of detail and, in my opinion well worth the purchase price
Tony
Thread: New member
30/11/2018 08:26:26
Hi Bob!
Gods own Country... surely is Yorkshire?
Welcome from another GOC resident
Tony
Thread: Abwood machine vise screw
27/10/2018 20:45:54
Try http://www.kingston-engineering.co.uk/
Tony
Thread: Pinkgrip
27/10/2018 15:23:51
Hi Rod and John
The problem might be the different expansion rates of the metal to the insulation. Try SikaFlex 512, which is the product used for mounting solar panels on campers/mobile homes...to quote the manufacturer "Sikaflex 512 is a flexible adhesive to allow different materials to expand and contract at different rates"
Most importantly make sure that both surfaces are abraded and cleaned. Sikaflex instructions say 3mm bed minimum.
Just one note of caution! Its good stuff, once its set you will need to chisel it off to remove it
Tony
Thread: What depth concrete base for a workshop extension?
16/07/2018 14:48:09
My thoughts!
Install a damp proof membrane under the slab
Minimum of 100mm/4”
Check out and agree the mix ratios prior to work being done. In my case what went in was a bit weak on the cement, which resulted in a dusty top layer
Tony
Thread: Help with silver soldering (Yorkshire area)
18/03/2018 21:04:52
Hi Keith
Thanks for the prompt, I'll look into it next week. I'm hoping to attend the CuP Alloys on the Road 2018 Club night at Grimsby, on the 17th April. Hopefully I'll be able to say hello there?
Hi Fizzy
Thanks for the offer, I've sent you a private message
Tony
17/03/2018 17:19:13
Hi
I’m hoping that somebody with brazing equipment is willing to help me! The door handle (see photos) is from a 1920’s building and suffered some metal fatigue. I’ve made a repair, which just needs silver soldering into the door handle boss. I’ve tried today with my “plumbers” blow torch, but I can’t get it hot enough to melt the silver solder. Is there somebody in the Yorkshire area (I live in Leeds) who has the correct kit and is willing to help me? The silver solder I’m using (CuP Alloys 455), has a melting point of 630C - 660C
Thanking in anticipation  Tony
Edited By Antony Price on 17/03/2018 17:20:12
Edited By Antony Price on 17/03/2018 17:40:51
