Slot Machines: How does a mechanical one arm bandit mechanism work?
Simon Robinson 406/06/2018 13:00:07
102 forum posts
Hi
I know a little about how a one arm bandit works, you pull the lever it sets off a clock and releases the brake holding the wheels. Let go of the lever and the spring activates the ‘kicker’ which sends the wheels spinning.
My questions are:
1) The 3 payout disks correspond to each wheel and are located to the left of the 3 wheels. How does each payout disk connect with each wheel. For example. How does disk 1 connect to wheel 1 when the other two disks are between it and wheel 1?
2) How does the kicker spin the wheels and do the wheels rotate around the axle independently while connected their relevant payout disk?
richardandtracy06/06/2018 13:12:20
943 forum posts
10 photos
In my short and unprofitable experience of one-arm bandits, there is no connection whatsoever between the payout disc and the wheels that rotate.
Richard.
Brian G06/06/2018 14:54:26
912 forum posts
40 photos
Aren't the payout cams located to the left of each wheel as in this video, and simply bolted to the wheels?
Edit: Hopefully this time with player controls
Edited By Brian G on 06/06/2018 14:55:38
Ady106/06/2018 16:32:30
6137 forum posts
893 photos
You might have to buy one to find out
Neil Wyatt06/06/2018 17:19:56
19226 forum posts
749 photos
86 articles
Mentally, slot machines are lost somewhere with signal boxes and engima machines in a part of my brain I'm happy not to explore in detail...
Simon Robinson 406/06/2018 18:38:20
102 forum posts
Posted by Brian G on 06/06/2018 14:54:26:
Thanks for showing the video very helpful
Christopher Dean 112/01/2023 15:32:45
1 forum posts
Can anyone help?
I have an old one arm bandit machine which has been converted to accept the new 1p coin, when i put these coins in they fall straight through the macine, how can this be fixed?
Nicholas Farr12/01/2023 17:31:48
3988 forum posts
1799 photos
Hi Brian G, that's a very informative video, thanks for sharing, not that I've ever thought about them and haven't put a single coin in one for probably 40 to 50 years.
Regards Nick.
Oldiron12/01/2023 18:54:57
1193 forum posts
59 photos
Posted by Christopher Dean 1 on 12/01/2023 15:32:45:
Can anyone help?
Something wrong with the conversion I would imagine. There should be a gate to slow down the coin and divert it into the coin collection box.
regards
Dave Halford12/01/2023 19:26:36
2536 forum posts
24 photos
Posted by Oldiron on 12/01/2023 18:54:57:
Can anyone help?
regards
The coin mech should be removable and still work without the rest of the machine so you should be able to see whats going wrong.
If it's a one penny bandit have you tried a 2 pence piece?
noel shelley12/01/2023 20:14:49
2308 forum posts
33 photos
Old pennys were non magnetic new ones are steel ! could be trouble ? Noel.
Neil Wyatt12/01/2023 21:06:03
19226 forum posts
749 photos
86 articles
In the years since this was originally posted I've seen several of Big Clive's videos.
They are generally very good.
Robert Atkinson 212/01/2023 21:23:55
1891 forum posts
37 photos
Hi Christopher,
We need a bit more information. Apart form what machine, did it ever work after the conversion?
A conversion for personal use does not need a coin acceptor becuse you are not going to cheat yourself. It just needs a tube or chute to connect the slot to the trip lever (or switch if an electrical machine).
My first fulltime job was fixing amusement machines, mostly electronics but had to everthing including old Jennings mechanicals. It was where I first used a lathe. There was a early Super 7 in a corner of the basement. No one used it. I got a copy of Sparey's book and put the 7 to good use.
Robert.
Martin Kyte12/01/2023 21:47:20
3445 forum posts
62 photos
Has anyone ever made a scale model of a one armed bandit?
Could be a first
Robert Atkinson 213/01/2023 16:28:27
1891 forum posts
37 photos
You need a licence to own, sell, make, repair or service a fruit machine. They don't make a distinction on size.
You can get a relatively cheap single machine permit for personal use. In theory even friends are not allowed to put money in a personal machine. And you can't fix a friends machine either.
https://www.gamblingcommission.gov.uk/licensees-and-businesses/page/single-machine-permits
Robert G8RPI.
duncan webster13/01/2023 16:43:23
5307 forum posts
83 photos
Is this another example of regulation over-reach? We get turned away by pubs when trying to perform a traditional mummers play for charity as they don't have a performance licence. All down to politicians not differentiating between a rock band with load amfiers and a group who have been performing for many many years but only a few times a year.
Maurice Taylor13/01/2023 17:06:34
275 forum posts
39 photos
Posted by Robert Atkinson 2 on 13/01/2023 16:28:27:
Robert G8RPI.
Hi ,You do not need a license to own a fruit machine for your own use at home.
Maurice
Robert Atkinson 213/01/2023 18:50:42
1891 forum posts
37 photos
Hi Maurice,
Can you reference a UK goverment document or website that states this please? The Gambling Commision website clearly states
You may be able to apply for a single machine permit instead of a gaming machine technical operating licence if you:
  • collect gaming machines, such as fruit or slot machines as a private individual
  • want to sell, repair or maintain a single machine or part of a gaming machine.
This is an alternative to a full gambling licence, not an option you don't need.
Some have argued that if ONLY you (and not even other members of yor household) use the machine you don't need a licence or permit. This is because you have not made the machine "available". However it is clear that you need a licence or single machine permit to install, repair or maintain (among other things) a gaming machine or part of one. This means for all practical purposes you need a permit because you can't even clean it (maintenence) without one. It is also difficult to show that nobody else uses it.
Like many laws enforcement may be low, but like speeding not getting caught does not make it legal.
Robert G8RPI.
Maurice Taylor13/01/2023 19:39:07
275 forum posts
39 photos
Hi,
These two sites say that a license is not needed for personal use
https://www.onlinegamblingwebsites.com/blog/can-you-install-fruit-machines-in-your-home/
https://www.bettingoffers.uk/articles/buying-fruit-machines-for-use-at-home/
Maurice
Martin Kyte13/01/2023 20:05:08
3445 forum posts
62 photos
If you make a quarter scale machine that takes quarter scale coins how is that gambling?
regards Martin
