Brass bar , 55 mm - ?supplier
capnahab19/05/2018 11:49:07
194 forum posts
17 photos
I need to make some bearing retainer rings for a set of BSA bike wheels, ( possibly originally B44 for a metisse build). They are just over 2 inches diameter so not critically 55 ml, - 2 ⅛ inches would do.
I need about 6 inches.
Can anyone recommend a supplier?. Or has anyone got some they want to sell ?
Cheers
Nick
Edited By capnahab on 19/05/2018 11:50:05
Brian H19/05/2018 12:00:32
2312 forum posts
112 photos
It would be useful to know your approximate location.
John Rudd19/05/2018 12:05:27
1479 forum posts
Macc models have 2-1/2" stock....
You could try M-Machine in Darlington...
Edited By John Rudd on 19/05/2018 12:05:46
capnahab19/05/2018 12:08:28
194 forum posts
17 photos
I am near Ilkley Brian.
pgk pgk19/05/2018 13:13:19
2661 forum posts
294 photos
M machine are usually quite decent .. does it have to be copper? Since these are rings could cast hollow PB be used? It might reduce cost.depending on id.
pgk
mgnbuk19/05/2018 13:17:29
1394 forum posts
103 photos
eBay item number: 273050215411
A 200mm length of 55 diameter is £60 delivered - out of touch with metal prices, so don't know if that is par for the course or OTT
HTH
Nigel B
Chris Evans 619/05/2018 19:27:00
2156 forum posts
At those prices I would be making them out of a decent grade of aluminium. Are they like the seal retainers found in models like Ariel front and rear hubs?
Bill Pudney19/05/2018 22:12:45
622 forum posts
24 photos
Most bearing retainers I've seen have been circlips............
cheers
Bill
Philip D19/05/2018 23:14:29
33 forum posts
L
Edited By Philip D on 19/05/2018 23:24:03
capnahab19/05/2018 23:54:26
194 forum posts
17 photos
Chris - thanks , good point , no idea what arials look like but the wrecked ones in are brass so I will be sticking to brass.
Bill, - not much good at keeping the mud out tho.
Edited By capnahab on 19/05/2018 23:54:53
capnahab20/05/2018 09:30:19
194 forum posts
17 photos
Thanks chaps , some good suggestions - seems the £60 isn't too bad when I will get about 6 out of it. A supplier of vintage parts is charging £20 for a single in aluminium.
Phil Boyland20/05/2018 09:45:46
49 forum posts
13 photos
Live steam models in Little Eaton do 2.25” at £6.36 per inch.
Mark Rand20/05/2018 16:19:11
1505 forum posts
56 photos
If it's of any help, I've got some 3" CZ121 bar you could use How about £25 for 6" and £6.50 for Myhermes shipping?
Only because I had a B25 as a student laugh.
capnahab20/05/2018 18:03:51
194 forum posts
17 photos
It’s a deal sir. Many thanks. I will pm you.
capnahab21/05/2018 18:05:27
194 forum posts
17 photos
Hi Mark, if I have done it correctly you should have a message in you inbox
Cheers
Mark Rand21/05/2018 19:55:10
1505 forum posts
56 photos
Replied the same way
john carruthers22/05/2018 08:21:40
617 forum posts
180 photos
Trepan them from sheet?
