Member postings for Philip D
Here is a list of all the postings Philip D has made in our forums. Click on a thread name to jump to the thread.
Thread: How to sale dads stuff
23/07/2023 11:47:17
Stephie, dropped you a private message
23/07/2023 10:19:59
Stephie, I am based in Ilford around the corner. I can have a look and proffer some advice
Thread: Elliott Model 181 Universal Milling Head
22/01/2022 12:47:49
Hi Dean, find your local motor rewinder, they will easily be able to pull the star point out of the existing motor (I had all three on my omnimill done this way) then you can run with a VFD.
Cost was about an hours labour, they also replaced the bearings in one as they were past there best.
I agree with above don't go pulling anything bearing wise until you have had the chance to run it.
Thread: Harrison M300 single phase from new
29/05/2020 09:41:27
600 Group are still going and if you supply the serial number they will be able to confirm if there was any difference in the headstock type. Great lathes, just be aware any parts are 'Pricey' but hopefully you wont need any.
Thread: Hardened and chromed steel rod
19/04/2020 21:02:05
http://www.hydraulicsupplies.co.uk/products/
These guys are good, but they only use one delivery firm (which is expensive). They do allow you to organise your own courier though ..or if your local pop in
Edited By Philip D on 19/04/2020 21:03:44
Thread: CENTEC DIVIDING HEAD
04/04/2020 19:30:28
@Nick Tollhurst I have dropped you a message can you get in touch
Thread: Colchester Student Mk1 Won't Start
23/12/2019 14:37:39
When repairing similar on my M300. I got a thin sheet cut to just the right size for the base and got a local faricator to weld it to the base for a drink, rather than attempt to repair a very poor surface.
Thread: Omnimill 00
12/05/2019 14:59:52
It will be after tuesday ..
12/05/2019 14:59:20
Ian drop me your email, so I can forward manual and the info you require
Thread: Omnimill 00 Opinions
06/05/2019 20:38:19
I am also a Omnimill owner. These a pretty robust mills, when sited in place no lifting should be required
If you can take the time to sort out a VFD, you'll hardly have to faff around with the belts. Please check a recent thread on here for guidance and links to sources of manuals / help.
Finding a good one can take a while (they are in all probablity at least 50 yrs old), make sure the horizontal arbour and end casting are with it ..these are now virtually impossible to find. Later models are 30INT on the horizontal and 3MT on vertical. Also late metric models came with a 27MM horizontal abour ..do check what it is size wize, it caught a few out (including me). I ended up getting it ground down to 1"
Phil
Thread: Omnimill 00
04/05/2019 22:37:33
If it's got the original 3 phase motors, you can get a motor rewinder to pull out the star points and run all the motors off inverters. This is what I ended up doing rather than having to change belts. I actually use the same inverter for both horizontal and vertical, by changing set parameters within the menu of the inverter.
Take a look at http://modeleng.proboards.com/thread/11799/electrical-design-assitance
Check the oil points..virtually all of them are oil points and not grease ..which many users seem to get wrong.
If your going to use coolant I'd recommend fitting an enclosed tank in the base that you can get out..it get bloody messy otherwise .
There is also a yahoo group that has manuals and lots of assistance from previous exploits, albeit is moribund at present ..https://groups.yahoo.com/neo/groups/Elliott_Machine_Tool_Owners/info
Also wash and change the oil in the column, whilst it's of the base ..it will make life easier in the long run
Hopefully you have the horizontal arbour and figure of 8 arbour support ?
Is it 30int on the horizontal and 3mt on vertical ? (some are 3mt on both)
Message me if you need anything more ..as I am not a very frequent visitor
Edited By Philip D on 04/05/2019 22:47:59
Thread: Identifying Collets
25/09/2018 22:08:10
I think after a few mins on a search engine that they are W20 Schaublin thank you Michael and Hans
Edited By Philip D on 25/09/2018 22:09:16
25/09/2018 22:02:07
Michael, it looks like they are 12mm and .125 pitch (m12 metric fine). All imperial sizes ..i wonder if they are european ?
25/09/2018 21:37:45
Not sure if the image is showing ..??
25/09/2018 21:29:52
I need assistance identifying some collets, these are off a Myford Super 7 but think the chuck is modified for the job.
The collets have what looks to be an S or a 5 with and A overlaid ??
Edited By Philip D on 25/09/2018 21:30:51
Edited By Philip D on 25/09/2018 21:33:35
Edited By Philip D on 25/09/2018 21:36:25
Edited By Philip D on 25/09/2018 21:39:57
Edited By Philip D on 25/09/2018 21:41:43
Thread: Brass bar , 55 mm - ?supplier
19/05/2018 23:14:29
L
Edited By Philip D on 19/05/2018 23:24:03
Thread: Elliot Victoria Juniormil
01/05/2018 10:14:52
Colin,
30/04/2018 20:07:31
These are heavy old lumps and quite difficult shaped pieces. An engine crane and two able bodies will be vital. Some rollers as Paul suggests will make life easier.
Like Paul suggested take the vertical head off, If it's got the fibre glass cover remove this first (or you will damage it !!) I'd leave the vertical motor on as this helps with balance.
Take the handles off next or again your likely to damage them, they are keyed on but with a bit of care should come off fairly easily and the removal of the knee gib allows it to be moved away from the column. I'd remove the column door again to save damage. You can split the column from the base and if you remove the horizontal motor this involves 5 Bolts from memory.
Photograph any wiring you disconnect and take a good imperial based tool kit (Allen Keys are a must)
Great Mill and there is a Yahoo group (albeit not very active, is a good resource of relevant information)
Philip
Edited By Philip D on 30/04/2018 20:08:02
Edited By Philip D on 30/04/2018 20:12:39
Thread: Supplier of Small Quantities of Lubricants
28/04/2018 11:40:12
Hi Brian,
I have found that you can get some very good prices and quality at these (usual disclaimer) guys
So 5 litres of ISO68 slideway oil with postage would cost £22
I get that this isn't "branded" ie Castrol etc but for my uses it seems perfectly fine
Philip
Edited By Philip D on 28/04/2018 11:59:26
Thread: 1ph to 3ph Electrics
20/04/2018 21:05:21
Brian,
That would explain it. Just be aware you need to keep the inverter out of tight spaces for airflow and pretty clean as they do attract dust/debris.
Philip
