Tap washers
roy entwistle06/03/2018 19:47:26
1716 forum posts
I am aware that this is not a model engineering question but, many years ago one could purchase washers specifically for hot water taps. They were red and made of a fibre type material. All I seem to be able to get the days are black ones made of some plastic like neoprene. They don't last. Any suggestions would be appreciated.
Roy
Billy Bean06/03/2018 20:04:10
174 forum posts
Plenty on ebay.
Just type - fibre tap washers - into the search box.
BB
JasonB06/03/2018 20:10:30
You must be looking at a different e-bay to me none of those look like the tap washers that go onto the jumper and sit down onto the seating.
Not seen the old ones for a long time.
Billy Bean06/03/2018 20:22:47
174 forum posts
Jason
No need for silly remarks.
If you google as I said you will find them.
That is what the original poster asked for.
He makes no mention of this jumper type thing what ever that is as not a plumber.
Billy Bean06/03/2018 20:25:20
174 forum posts
110Pc FIBRE WASHER SET Small-Large Seal Buffers Plumbing Packer Tap Bath Ring
Brand new
ITEM NO 312078772612
Edited to say they are RED
Edited By Billy Bean on 06/03/2018 20:34:02
Simon Williams 306/03/2018 20:38:33
728 forum posts
90 photos
And in fairness to Jason, if you ask an expert you'll get an expert answer.
The sets of fibre sealing washers on ebay just now are not tap washers, they are sealing washers to seal the thread at the back of the tap where it screws into it's mating pipe. That ebay brings them to the screen when the search string contains the words tap and washer is down to the shortcomings of eBay's search engine, not Jason's expertise.
A tap washer, on the other hand, lives inside a tap and is screwed down onto the tap seat by the operating handle and thereby block the flow of water through the tap. It sits on a jumper which guides it onto its seat and stops it distorting under the forces exerted on it by the water pressure.
One hopes that the OP meant what he said when he asked for a tap washer.  His description of same corroborates the terminology he has used.
And you are absolutely right, there is no need for silly remarks.
Edited By Simon Williams 3 on 06/03/2018 20:42:25
martin perman06/03/2018 20:38:47
2095 forum posts
75 photos
Mr Bean,
This is a tap washer, https://www.screwfix.com/p/arctic-products-pegler-tap-washers-5-pack/2070J?tc=DB2&ds_kid=92700020953273697&ds_rl=1249799&ds_rl=1245250&ds_rl=1249481&gclid=EAIaIQobChMIp4yrp8bY2QIVwbftCh11EQCcEAQYAiABEgIzkvD_BwE&gclsrc=aw.ds&dclid=CLOjhLfG2NkCFcau7Qod5cALrw
Martin P
JasonB06/03/2018 20:38:56
Old style red fibre tap washers on the right, my last few and the softer black ones on the leftwink 2
roy entwistle06/03/2018 20:43:53
1716 forum posts
Jason those are exactly the ones I remember, I wish I could find some now
Roy
Nicholas Farr06/03/2018 22:20:34
3988 forum posts
1799 photos
Hi, and for those that don't know, here's an inside view of a stop cock where such washers will fit. The washer is the black bit which seals off the flow of water and the jumper is what it's attached too, which has a spigot that slides up and down in the end of the threaded bit, that can just be seen.
Stop Valve
A tap has the same configuration, but has an open spout on the output side.
Regards Nick.
Edited By Nicholas Farr on 06/03/2018 22:23:54
Martin W06/03/2018 22:59:06
940 forum posts
30 photos
Roy
A quick trawl round the net seems to confirm your comments re availability or not as is the case. However I did find some candidates that might be worth a look the first can be found here and comes as a 3/4 in. diameter but center hole not specified. The other possible option might be one of these which they sell in 1/2" and 3/4" sizes and may just require a quick fettle and a hole drilled to size in the middle. Other than that it's like looking for the proverbial 'Rocking Horse Droppings'. angry.
Cheers
Martin W
peak407/03/2018 00:28:23
2207 forum posts
210 photos
Or you could see ith there's a branch of Grahams Plumbers near you
Bill
FMES07/03/2018 06:20:14
608 forum posts
Posted by martin perman on 06/03/2018 20:38:47:
Mr Bean,
Martin P
Or: **LINK**
and the purpose of the jumper is to prevent back flow
Edited By FMES on 07/03/2018 06:21:35
martin perman07/03/2018 07:57:03
2095 forum posts
75 photos
How do you create a link ?
Martin P
Michael Gilligan07/03/2018 08:08:11
23121 forum posts
1360 photos
Posted by martin perman on 07/03/2018 07:57:03:
Martin P
Use this icon bubblecar.jpg and follow your nose
martin perman07/03/2018 08:19:01
2095 forum posts
75 photos
Michael,
Thanks for that, my first lesson learned for the day smiley
Martin P
robjon4407/03/2018 09:23:20
157 forum posts
Gentlefolk may I put in a word for the Full Stop tap washer kit, available from B&Q & of course all the usual suspects on the internet, take top off tap, remove the upper piece that the old style washers are fitted to, place plastic shouldered bush in outlet hole & press down with special tool (thumb), place plastic upper stem & washer in head of tap, replace, then gently screw down capstan of tap to press all in place. When you have tried one you will not imagine why you didn't invent it yourself, personally I have never had one let me down & at £1.78 got to be worth a try. Three quarter inch ones seem more difficult to acquire but after you have seen one I'm sure it wouldn't be rocket science to make ones own.
Cheers Bob.
roy entwistle07/03/2018 09:40:13
1716 forum posts
Thank you to JasonB and Nick Farr ( For the sectioned tap ) We were shown how to change tap washers at senior school and I tend to think that everyone else had a similar education. But that was 70 years ago
Roy smiley
KWIL07/03/2018 09:54:18
3681 forum posts
70 photos
The Full Stop Kit is designed primarily to deal with damaged valve seats. Tap washer failure (both H & C) as far as I am concerned seems to be more to do with excessive tightening down by my visitors!!
Mick B107/03/2018 10:12:53
2444 forum posts
139 photos
Blimey.
Where've I been?
I never saw or heard of red tap washers till I read this thread.
I must've replaced a dozen or so since the 1970s, and the only one I can remember having trouble with was when I should've refaced the washer seating with one o'them titchy little grinding discs first.
Well, maybe I was just lucky and all the failed washers were on cold taps?surprise
