What to buy at Ikea?
Wout Moerman25/01/2018 12:20:36
57 forum posts
I probably will visit Ikea on Saturday for buying new mattrasses. But I like a flexible worklight for uses on my workbench. I've seen possitive comments about the Jansjö and the Harte and especially the flexibility of the Jansjö appeals to me. But any other items worth looking at while I'm there? Or not to buy ... ?
Wout
FMES25/01/2018 12:26:13
608 forum posts
Meatballs
Martin 10025/01/2018 12:47:10
287 forum posts
6 photos
Maximera drawers
Various widths depths and heights. Make your own drawer fronts and change the base to aluminium or steel if you need more capacity. Build a standalone cabinet or fit a few under the workbench
For a worklight I'd go for something built like a brick outhouse and designed for a tungsten filament lamp or a halogen...and retrofit an LED. Everything in IKEA will now be LED as standard.
Edited By Martin 100 on 25/01/2018 12:48:06
John Rudd25/01/2018 12:57:33
1479 forum posts
I bought the Jansjo led light for my lathe, the light is now playing up.....I've had it maybe a couple of years. The led is ok, it appears to be an issue with the power supply....
Pay your money and take your choice...
Mick B125/01/2018 13:27:34
2444 forum posts
139 photos
...plus hot dog sausages, Swedish choc and fake caviar made from seaweed...😁
Muzzer25/01/2018 13:46:38
2904 forum posts
448 photos
Bevara bag sealing clips.
The light bulbs are good value for money and seem to last well.
Personally I can't stand the Jansjo lamps. Bought several but really, if the light level isn't bright enough, a sharp, shadowy light source is the very last thing you need. Better just to make sure you have distributed, diffuse (shadow free) lighting is the lesson I learned.
Our nearest Ikeas are about an hour away, so unfortunately we don't get there as often as we'd like.
Murray
ega25/01/2018 14:01:20
2805 forum posts
219 photos
Helmer drawer units and a bottle of Snaps to help with the assembly.
Harry Wilkes25/01/2018 14:19:36
1613 forum posts
72 photos
I've had two jansjo lights for a couple of years without any issues I also have two of these draw unit again without any issues but they were £5 cheaper when I got mine
H
Michael Gilligan25/01/2018 16:02:40
23121 forum posts
1360 photos
Posted by Wout Moerman on 25/01/2018 12:20:36:
... any other items worth looking at while I'm there?
Don't forget to visit 'Clearance Corner'
Grab bargain-priced items that include any decent Aluminium extrusions, and a bag or two of screws & fittings.
Donald Mitchell25/01/2018 16:13:10
90 forum posts
The newer Jansjo lights which I bought about a couple of months ago to supplement my other ones are much superior to the older ones. Different power units, higher voltage. My only complaint is that the plastic clip on the clip-on variety seems to degrade when exposed to light (I was going to say sunlight but there has been no sunlight in Scotland in living memory) I've had to replace the clips on both my older ones by screwing them to the window frame, but the lights are great.
Donald Mitchell.
Bonnie Scotland.
Martyn Duncumb25/01/2018 16:35:48
55 forum posts
I have two BEKVAM kitchen trolleys with small machines on. They can be wheeled into a corner when not in use as two legs have wheels. Frees up workshop space. Now £35 but we’re £30. They have two storage shelves underneath. Strongly built. Martyn
Wout Moerman25/01/2018 16:40:56
57 forum posts
OK, good tips, keep them coming!
I'll certainly will look in the clearance section. Always do and found a lot of good stuff. I'll have a good look at Jansjö but I understand that the light distribution might be a bit harsh. The drawers seem a good buy. I'll see if these measurements will fit my storage. And seaweed caviar certainly sounds very .... interesting.
Mick B125/01/2018 17:22:08
2444 forum posts
139 photos
Posted by Wout Moerman on 25/01/2018 16:40:56:
I thought so. Seemed indistinguishable from real to me, but then the last time I had any real was about 20 years ago or more... angel
peak425/01/2018 20:30:43
2207 forum posts
210 photos
This non-slip carpet underlay is quite good, not very tear resistant, but dirt cheap
Seems to work OK as a drawer liner, and helps stop things sliding around on the bench.
Not bad for rugs on laminate floors either.
Bill
Steve Pavey25/01/2018 21:43:13
369 forum posts
41 photos
Another vote for the Helmer drawer units - I have two pop-riveted together as a mobile base for my 6x4 bandsaw. Also the Bekvam step stool **LINK** is dirt cheap and very useful if you store stuff in the roof joists of your workshop, or if you want to sit down at the bench.
I’m sure there are many other small items like waste bins, stainless roasting tins etc that can be used for washing parts in paraffin or for general storage, digital scales for measuring out epoxy resin, soap dispensers for swarfega- the list is endless.
Vic25/01/2018 21:51:27
3453 forum posts
23 photos
The Hot dogs are nice ...
duncan webster25/01/2018 22:23:47
5307 forum posts
83 photos
Posted by Muzzer on 25/01/2018 13:46:38:
Murray
I go very rarely, and that's far more than I'd like, once you're in you can't get out, the only sure fire way is to follow the fire exit signs
richardandtracy26/01/2018 21:57:09
943 forum posts
10 photos
I have managed to live without ever going to IKEA. The style is distinct, and I think it looks great in houses with large areas of pine or white walls. We have neither, so not for inside the house. Outside, in the workshop, I remain to be convinced that either the furniture or fittings are robust enough. I feel if the surface is horizontal, I should be able to stand on it while carrying something heavy, so 300lb. And if vertical, it should be able to take me falling against it, guesstimate force 200lbf. And if a loose fitting, it should survive dropping onto concrete. Nothing in Ikea's catalogue has convinced me so far. Though, to be fair, very little domestic furniture/fittings have convinced me to use it in the workshop. And if made of chipboard, it always sags under the weight of 'stuff'.
So, my recommendation as to what to get: a healthy dose of window shopping and buy the wife a slap up dinner with the money saved. And a couple of colleagues recommend the meatballs.
Richard.
Muzzer26/01/2018 23:08:31
2904 forum posts
448 photos
When we first started visting Ikea (first Lakeside, then in Vancouver), the food in the cafe was excellent value. I suspect it was offered at cost price to keep the punters happy and "in-store". But on our only trip to Ikea since returning to the UK (Warrington), the cafe food was a long way from being cheap. Still some good products if you know what's worth buying but they lay out the store like a maze to force you to walk through all departments. If you study the maps, you can figure out the shortcuts.
Some of the UK stuff is made of solid and / or "engineered" wood including oak. That's a nice contrast from N America where they seem to hate proper wood and instead prefer things made of heavily stained maple and the like.
Murray
Bazyle26/01/2018 23:23:25
6956 forum posts
229 photos
I thought maple was a nice hardwood?
These drawer sets that are suggested above - are they real metal or plastic? Can't tell from the pictures.
