Clive Hartland | 28/10/2017 10:04:19 |
![]() 2929 forum posts 41 photos | I removed the snap on back of my Omega and needed to regulate it as it was galloping a little ( 5 sec's a day) Now I want to put the back on again and I cannot get it to snap back on, any help please. I do not want to damage the crystal as the original Omega crystal is about £40 plus. Clive |
Neil Wyatt | 28/10/2017 10:34:32 |
![]() 19226 forum posts 749 photos 86 articles | You can get a proper watch back press with a selection of round plastic dies for about £5 on eBay. |
Clive Hartland | 28/10/2017 11:23:15 |
![]() 2929 forum posts 41 photos | Thank you Neil I will have a look. The watch was overhauled about 2 years back and cost £100.00 I have only just started wearing it again and as said it is galloping away. Clive |
paul rushmer | 28/10/2017 12:09:07 |
104 forum posts 17 photos | Clive machine a piece of mdf to support the front of the watch, place a parallel piece of 2x1 timber across back and use drill press as a press. This has worked for me. Paul |
Clive Hartland | 28/10/2017 15:08:23 |
![]() 2929 forum posts 41 photos | Thanks Paul, that was in my mind to do, just need to go in the garage and do it! Clive |
NJH | 28/10/2017 16:02:07 |
![]() 2314 forum posts 139 photos | Ah Clive Another Omega man! I had one as 21st birthday present - over 50years ago ( ! ) and it is still going strong ...... except that I keep forgetting to wind it. For everyday use I have a battery operated Seiko which keeps perfect time and didn’t break the bank to buy ........... I do still prefer the Omega though! Norman |
Mike Poole | 28/10/2017 17:25:42 |
![]() 3676 forum posts 82 photos | I suppose you Omega chaps didn't put in a bid for Paul Newmans Rolex Daytona? Mike |
not done it yet | 28/10/2017 17:31:55 |
7517 forum posts 20 photos | My Omega has a problem. I hope it only needs a clean. Might be muck on the tuning fork. And my Seiko needs a new o-ring - if one can call the seal an o-ring. |
vintagengineer | 28/10/2017 17:36:38 |
![]() 469 forum posts 6 photos | That's cheap! A new crystal for my Rolex is £300 + £300 for a service!
Posted by Clive Hartland on 28/10/2017 11:23:15:
Clive Hartland | 31/10/2017 08:54:36 |
![]() 2929 forum posts 41 photos | I made a hardwood form that supported the strap bars and that was clear of the glass. I have a small bench mounted vice and I placed the form and watch in between the jaws ( Need 3 hands) and slowly closed the vice and the back snapped on fine. I will save the former in case I need to do it again. Clive |
SillyOldDuffer | 31/10/2017 09:01:29 |
10668 forum posts 2415 photos | Posted by Clive Hartland on 31/10/2017 08:54:36:
I made a hardwood form that supported the strap bars and that was clear of the glass. I have a small bench mounted vice and I placed the form and watch in between the jaws ( Need 3 hands) and slowly closed the vice and the back snapped on fine. I will save the former in case I need to do it again. Clive Smart! I'm impressed. Dave |
Circlip | 31/10/2017 10:10:11 |
1723 forum posts | Trick to ease snapping the back back on, apply pressure to the centre of the back, however slight it allows the outer rim to deflect.
Regards Ian |
Cornish Jack | 31/10/2017 10:47:12 |
1228 forum posts 172 photos | "I had one as 21st birthday present - over 50years ago ( ! ) and it is still going strong ...... except that I keep forgetting to wind it." Norman - Snap!! My constant use job is a Citizen Eco-Drive. Being lazy by nature, it is ideal. Set it to a radio controlled source 7 years ago and leave it on GMT. Now showing about 2 seconds slow - much more accurate than I will ever be!! rgds Bill |
Ady1 | 31/10/2017 11:35:43 |
![]() 6137 forum posts 893 photos | Seiko are the best watches, just not the most expensive |
AJW | 31/10/2017 12:42:08 |
![]() 388 forum posts 137 photos | Just bought an Omega Seamaster - absolutely fantastic, gained 1.5 seconds in 2 days. Alan |
not done it yet | 31/10/2017 13:03:02 |
7517 forum posts 20 photos | Oops! My tuning fork watch is a Bulova diver's watch, not an Omega. |
Fowlers Fury | 31/10/2017 13:05:39 |
![]() 446 forum posts 88 photos | Neil's suggestion about buying the 'proper' press with plastic supports kit is the safest. Choose a plastic base from the selection provided that only contacts the outer, metal part and is not in contact with the crystal. Also mentioned above is the important point that the backs need to pressed in the centre to a slight degree so that they "dish" before snapping on to the rim. I don't think it will help if you select the plastic 'pusher' which is "full width of back". You will need to exert some considerable force on the handle to get the back on again. The Omega should have a thin plastic gasket between the back and the case. It's easily damaged. I'd suggest you order a new one first (Fleabay again) as reseating the old one, which will have likely stretched, is nigh on impossible. If you can get scrounge some clear silicone grease (the "high vacuum" type is best) then smear a tiny amount around the edge of the back. Not only will it help putting the back on but it will provide a better seal. |
SillyOldDuffer | 31/10/2017 13:07:30 |
10668 forum posts 2415 photos | Posted by AJW on 31/10/2017 12:42:08:
Just bought an Omega Seamaster - absolutely fantastic, gained 1.5 seconds in 2 days. Alan Nice watch! However, I noticed over the weekend whilst setting my inexpensive Seiko to Winter Time that it had lost about 20 seconds in the 217 days since I put it on BST in March - apparently it's losing about 0.09 seconds per day. May be complete coincidence of course. I don't really know how consistently my watch keeps time - for all I know it could be varying ±10 seconds per hour. I've never missed a train though. Dave |
Sam Longley 1 | 31/10/2017 13:21:35 |
965 forum posts 34 photos | My Rolex ( 1963) has to be laid on one side or the other at night depending on whether it is gaining or loosing time to allow it to compensate. Still does not keep very good time though. I paid 5 euros for a watch in Dieppe a few years back & it keeps perfect time. price included a spare battery which I have not needed yet. Does not quite have the "bling" though |
Clive Hartland | 31/10/2017 18:46:15 |
![]() 2929 forum posts 41 photos | Omegas and Rolex watches are fetching silly prices now, one in a local Jewellers for £4500 it does have some diamonds on it. My Omega has kept good time until the last O/H, then I was going to use it when taking midday sights on the yacht but strangely the Casio digital watch was more accurate. By far the best watch I have had was Cyma Navy Star, Very thin and kept perfect time. Rolex are known to get a bent balance staff if dropped. I know of one tale, my friend took up Scuba diving as part of his job and was tasked with cleaning out the slot in the dry dock that the cassion sits into to seal the dry dock. In doing so he found a Rolex divers watch still ticking and he took it too the local Rolex agent who verified it was genuine and OK. They did not know where it came from though. At the moment my day watch is a Tag Heur which is very heavy to wear. Clive Edited By Clive Hartland on 31/10/2017 18:47:02 |
