Member postings for paul rushmer
Here is a list of all the postings paul rushmer has made in our forums. Click on a thread name to jump to the thread.
Thread: Smoke box best way too make
23/08/2023 16:39:02
Hi Michael its times like this belonging to a club helps, my club have a set and at least two members me being one. Iam on the cambs essex suffolk boarder if it is any use.
Paul
Thread: what is this
24/06/2023 13:31:29
Gary
I will taik to the right man on monday when I get back to work.
Paul
23/06/2023 20:24:24
Hi
I happen to work for the company that still make the modern version (Bernhard & co). The cylinder or real is mounted in the two bronze bearings and slowly rotated and the grinding wheel is rotated and moved along the large slotted shaft. One of my jobs is to put the slots in the shaft of the modern machines, if you can find a serial no we have all the order books and should be able to find the manufacture date and customer.
Hope this helps Paul
Thread: Best method of selling completed models
22/11/2022 20:16:26
The dealers that spring to mind:- Steam Workshop, Station road steam, Antique steam, Steamdays, Used Myford lathes, View Models & Maxitrack. Several of the material suppliers allso sell used models MJ engineering & GS models.
21/11/2022 19:16:59
Food for thought many of the larger model dealers stock there shelves from the auction houses, but if you buy from a dealer you get some form of garantee or a try before you buy. I was out bid on a small model only to see it listed on ebay for twice the price and sold.
Paul
Thread: Spirit firing and 3.25” gauge.
06/11/2022 20:22:32
Hi
3 1/4 gauge does come up at model auctions some times, last year a greenly electric loco from 1905 came up at my local auction house. I have two midland bogie carrages and a 5 plank open wagon.
Paul
Thread: What is a 'Gedge Flat' as seen on certain railway couplings?
03/11/2022 22:02:22
Roche is correct the drawing says details LMS Locos these did not have a gedge the couplings had a slot in them so the eye of a coupling shackle could pass through it. I hope this makes sence, gedges were normaly only used on freight stock.
Paul
Thread: Another Mystery Tool
02/09/2022 20:51:24
I have one of those from the days the family ran a garage, Its for riviting new linings on brake shoes (drum brakes).
Paul
Thread: Excel pillar drills
14/08/2022 19:42:06
I aggee with Mike not the best quality I use a bridgeport style supplyed by them and it seems a good machine my previous employer had a excel lathe new I preffered to use the much older colchester. Search for excel machine tools coventry they are still in business. In the past they have made tools in UK I use a 12inch rotary table that says made in coventry
hope this helps Paul
Thread: Tufnol or tufnol substitute
18/07/2022 19:37:24
Hi I have used tufnol for springs, the correct type is the sort made with canvas (not paper) the finer type it has the name of a fish possibly carp. As for temperature try 120 C rolled in a tin, the tin is used to not take to must heat from the oven it will spring back so you need a tighter radius. You could use bronze and if to stif machine a stot in the middle.
Paul
Thread: Old lathe identification
30/05/2022 07:24:35
Thanks for the thoughts so far, the head stock is a bronze casting, base is cast iron with plywood infill with mountings for motor so not origional and yes the mounting bracket is a lump of angle.
Thanks Paul
29/05/2022 14:44:08
old latheI rescued this from a scrap heap approximatly 18 inches long with a centre height of 2 1/2 inches, looks commercially made. I dont know wether it is a wood or instrument lathe. Spindle looks 1/2" BSW and solidold lathe Thanks Paul
Thread: Reinventing The Real
29/05/2022 14:02:44
Real engine
Edited By JasonB on 29/05/2022 14:07:18
29/05/2022 14:01:00
Real engineReal engineHi Jason
Thought you mite like to see my fathers take on the real. Fluted columns redesigned piston rod support acorn nuts and a large pulley, he wanted to fit a govener but that never got done.
Paul
l
Thread: boiler connector
26/05/2022 19:11:53
Hi Duncan
Try looking on R.S. components for mate&lock. If it helps you can get the pins out we used the special tool but a simple thin wall tube turned up on the lathe works well it should be a good fit on the pin to close the barbs in then pull on the wire.
Paul
Thread: Milk container top colours
26/05/2022 18:37:04
What I want to know is why are the glass bottles from the milk man differant colours from the plastic ones from the suppermarket?
slow fingers you beet me
Edited By paul rushmer on 26/05/2022 18:40:04
Thread: Supplier of 7/32" Dowel Pins Please?
25/04/2022 19:27:32
Having worn out the pins in my Marlco I watched this thread with intrest , I have just ordered some rollers from Simply Bearings. Many thanks every body.
Paul
Thread: Identity of static engine kit
17/04/2022 12:29:14
Hi Clive
Looks like Tina from GLR to me, If you look on there web site there are pictures of the individual castings.
Thread: Westbury 1831 LMS locomotive
20/12/2021 21:51:40
This one was built by Ivan law and uses a body kit from model engineers laser. I have severial part built (nun by me) and all the articles if I can help I will try looking in my albums
Thread: Track Maintenance
09/11/2021 20:26:04
At Cambridge Model Engineers we use a local company called filcris thay supply many sections of recycled plastic wood. They have advertised in ME in the past.
Paul
