Decorative effect on steel nut
Does anyone know how this was created?
mrbuilder14/09/2017 11:56:18
71 forum posts
15 photos
Can't say I've seen this before, but doesn't anyone know how this decorative effect was created on this nut?
Nut
RJW14/09/2017 12:04:43
343 forum posts
36 photos
Looks as if it's been shot peened,
John.
richardandtracy14/09/2017 12:33:33
943 forum posts
10 photos
Or left in the bottom of a toolbox in a vehicle for years, and has bounced into everything hard in the box.
Richard.
not done it yet14/09/2017 12:43:00
7517 forum posts
20 photos
If it is a decorative finish and not clened up after corrosion, it was likely tumbled in a mill with some hard, heavy, spiky tumbling media.
MW14/09/2017 12:49:48
2052 forum posts
56 photos
Whatever it is, it looks like a great way to make something look as though it had been cast.
Michael W
Edited By Michael-w on 14/09/2017 12:50:04
Ian P14/09/2017 12:55:25
2747 forum posts
123 photos
Without an idea of scale its hard to say if its is actually decoration. It looks like a well corroded part that has been cleaned and made shiny.
The nut seems a combination of processes. Has a tap been put through it after the surface was 'decorated'?
I cannot imagine what sort of product would benefit from this so called decoration, it does not look very engineering like are pretty in any sense of the word (but I know beauty is in the eye of the beholder)
Ian P
Bazyle14/09/2017 13:20:38
6956 forum posts
229 photos
The top surface is smooth as if fitted to something, How about heavy corrosion followed by electrolysis de-rusting to get into all the crevices in a way that wire brushing doesn't.
mrbuilder14/09/2017 13:21:56
71 forum posts
15 photos
Posted by Ian Phillips on 14/09/2017 12:55:25:
It's a 3/8 BSF nut. Sorry should've chucked a rule next to it.
The look has kinda grown on me. My original thought was a clean up after corrosion but not really sure. Have five of them, all the same.
Edited By mrbuilder on 14/09/2017 13:23:49
Ady114/09/2017 15:30:35
6137 forum posts
893 photos
Might be meant to look that way because the nuts held a cast object in place
Decorative Continuity
David George 114/09/2017 15:58:08
2110 forum posts
565 photos
I used to make plastic tools for a plastic gas pipe fitting manufacturer and some had the same surface texture on the cavity done by chilled cast iron shot blasting on the moulding faces. We had to make a mask to protect the shut out faces as was likely done to the end and thread of the nut.
David
thomas oliver 214/09/2017 18:44:39
110 forum posts
It seems to me that my favourite method of cleaning up rusty nuts and bolts - using a steel wire wheel on the buffer has been used here - witnessed by the rounding off of all sharp edges T. O..
larry Phelan14/09/2017 19:03:39
544 forum posts
17 photos
. This is quite a common object,found in boot sales all over the place. It,s called JUNK.! usually found in boxes full of rusty water and offered for sale at mad money.
Believe it or not,some people actually buy it !.
Ian S C15/09/2017 03:23:08
7468 forum posts
230 photos
When I replaced some missing nuts on some olf farm machinery the new nuts looled out of place. I have a bucket set up for electroliticly removing rust so I reversed the polarity and set it going for an hour or so, pulled the nuts out and wire brushed them and they looked just like the one in the photo, and just like the remaining old nuts on the machine.
Ian S C
mrbuilder15/09/2017 04:23:14
71 forum posts
15 photos
Posted by Ian S C on 15/09/2017 03:23:08:
When I replaced some missing nuts on some old farm machinery the new nuts looked out of place.
I have to agree with that, the alternative new bright zinc plated nuts didn't look right in my application either...
Thanks everyone for all of the thoughts yes
Edited By mrbuilder on 15/09/2017 04:23:35
MW15/09/2017 12:18:37
2052 forum posts
56 photos
I think the likely scenario is that they've been tumbled with stainless steel shot, in a basket, maybe with a little bit of water to keep it cool and keep the dust down.
Michael W
