Hevanscc | 19/08/2017 20:51:28 |
89 forum posts 33 photos | A while back I bought a live centre from one of the usual suppliers, for use in a prospective project. So, the day arrived for turning between centers this week but I noticed, on first use, that there was a distinct wobble at the tailstock end. On further examination I found that there was visible play in the bearing. Being relatively new at this game I am trying to avoid jumping to conclusions but I suspect that this should not be so. Any advice gratefully received. Hywel
Nick_G | 19/08/2017 21:38:31 |
![]() 1808 forum posts 744 photos | . So long as it's play in the centre and not your tailstock return it ASAP I spent considerable time (and money) finding a decent live centre. - Some are cheap. ........... Far too cheap.! Others are expensive. ............ Far too expensive.! It can be a minefield. (well at least I found it to be so) My best live centre is a small bodied long nose Rohm which I find is ideal for model engineering as it allows you to still get the tool in on small dia's. But I feel it needs to be shown some respect and I avoid if possible using for interrupted cuts on large square bar etc. Nick |
Hevanscc | 19/08/2017 22:03:58 |
89 forum posts 33 photos | Thanks, I'll try and dig out the receipt or else it will be straight in the bin, having already ruined one job. Another lesson learned after parting with the folding stuff . . . |
Clive Foster | 19/08/2017 22:16:12 |
3630 forum posts 128 photos | As its a modern unit most likely is a badly made one. However there was at least one decent quality old style live centre that normally has a little play in it when unloaded. Separate races and loose balls inside I think so if you do manage to get it apart there are a lot of things to catch. I have what looks to be one such with a bent spindle. Blowed if I can see how it comes apart. Clive. |
Hopper | 19/08/2017 23:27:09 |
![]() 7881 forum posts 397 photos | Posted by Hevanscc on 19/08/2017 22:03:58:
Thanks, I'll try and dig out the receipt or else it will be straight in the bin, having already ruined one job. Another lesson learned after parting with the folding stuff . . . No need for that. The problem is cheap Chinese bearings. Replace the bearings with a good brand name product such as SKF, Timken, FAG, Naachi etc and you will most likely have a good piece of kit. Even the good quality bearings are cheap to buy. |
duncan webster | 19/08/2017 23:43:27 |
5307 forum posts 83 photos | If it's not the bearings the point might not be concentric with the bearing seats. If that is the case rig up a means of stopping it rotating, put it in the headstock and re-machine it. Best of course is to return it if you can |
Chris Evans 6 | 20/08/2017 09:32:49 |
![]() 2156 forum posts | I have used a "Skoda" live centre for over 20 years now and not new when I acquired it. A small long nose one is on my shopping list but there is always other things to buy. |
Andrew Tinsley | 20/08/2017 10:15:26 |
1817 forum posts 2 photos | I inherited a live centre with a lathe. It has always turned true. A few weeks ago I picked it by the nose (silly thing to do!). I heard a click and on close examination I found longitudinal play of maybe 5 to 10 thou! I got a touch bothered and set it up with a bar in the lathe and it still turned true, maybe the play is meant to be there? My best live centre is one I purchased in a shop in Austria 40 years ago (maybe an Emco). I remember trying to explain what this item was to an airport security bloke who checked my hand luggage! Blowed if I could remember what a live centre was in German! In fact I don't think I ever knew. Talk about a long winded explanation! At the time my German was mainly Schweitzer Deutsch and the Austrian is almost a different language. Happy days! Andrew. |
Ian S C | 20/08/2017 10:54:52 |
![]() 7468 forum posts 230 photos | I use Skoda #2MT live centres, I'm on my second one. For about 15 years the first one got a fairly heavy hammering, and the bearings in it collapsed, I took it to the agents to see about over haul, but parts alone would cost more than the price of a new one. Ian S C |
Mick B1 | 20/08/2017 11:18:26 |
2444 forum posts 139 photos | I've got a cheap Chinese running centre I bought about 15 years ago. The cylindrical casing around the bearing is very visibly eccentric, but the point itself is true enough to turn parallel within 2 tenths over 4 inches if the tailstock's properly adjusted (which it wasn't on delivery of the lathe). I guess the wobble induced by the eccentric casing might become a problem if I was turning tiny diameters to microns tolerances, but I'm not. |
KWIL | 20/08/2017 11:20:55 |
3681 forum posts 70 photos | Andrew T, The longitudinal play should disappear when you load it against the job next time. There is normally little restraint in that axis other than the normal slop of the front radial bearings, the thrust bearing taking the axial load. |
Ady1 | 20/08/2017 12:01:59 |
![]() 6137 forum posts 893 photos | Replace the bearing if it's wobbly If you still have too much overhang for a heavier job you can use a fixed steady on the body of the centre which can take it to a better level of stability/stiffness, useful if you only have an MT1 tailstock Edited By Ady1 on 20/08/2017 12:03:54 |
