Brian Norman | 21/05/2017 13:44:00 |
19 forum posts | Hi, I intend buying a small lathe that comes with a 3 or 4 jaw chuck. As my funds will not stretch to 2 chucks at present, which would you suggest as a starter? |
SillyOldDuffer | 21/05/2017 13:58:29 |
10668 forum posts 2415 photos | 3-jaw. They are self-centring, convenient, easy to use, and good for 80% of 'beginner' turning jobs (ie gripping round or hexagonal objects with reasonable accuracy). A 4-jaw can can grip a much wider range of shapes BUT it isn't self-centring. Setting them up has to be practised and you need a Dial Test Indicator with Stand to do it. Well worth it, but the purchase can be delayed until you know why it's needed! In theory you can do everything with a simple backplate. In practice people seem not to, usually starting with a 3-jaw, then 4-jaw, and perhaps progressing to a collet chuck. Dave |
Hopper | 21/05/2017 14:14:47 |
![]() 7881 forum posts 397 photos | +1. Three jaw is the "standard" chuck used most of the time. Four jaw is a bit further advanced and used only on certain jobs. |
not done it yet | 21/05/2017 15:53:19 |
7517 forum posts 20 photos |
Maybe, but if you intend to remove and re-chuck a part, the 4 jaw is by far the better choice for concentricity on remounting - if one can master the technique easily or have the time to fiddle until it is right. So it depends... I would say start with a good 3 jaw if your needs are simple. Otherwise, you will find, as many have, that the 4 jaw independent is often the choice (mine is - because it is there ready and waiting. By the time I have changed chucks, the part is centred adequately). As above, re historical operations - turning cylindrical items was often done between centres for best concentricity, particuarly if removing from, and refitting to, the lathe. But fallen out of use for various reasons (modern chucks are better than a worn out old 'un, no spinning drive dogs to keep away from, etc.). I bought a 4 jaw self centering chuck, as well (for the rotary table). But I would not go out and buy another - they will only chuck properly on perfectly round bar, per eg.
Join your local Model Eng. Soc. and practise with a 4 jaw independent, if you have the opportunity or time. Hands on experience is worth far more than a forum reply. If I now had a choice of only one chuck, it would be the 4 jaw independent variety. But that is after 20 years of tinkering.
Rick Kirkland 1 | 21/05/2017 17:12:44 |
![]() 175 forum posts | At last. Somebody talking sense. I shall add that you absolutely DO NOT need a dial indicator and stand to set up a four jaw independent chuck. Fifty one years ago that was proved to me when I was taught how to do it . The four jaw independent chuck is your best friend for accuracy and REPEATABILITY. Edited By Rick Kirkland 1 on 21/05/2017 17:13:29 |
Chris Evans 6 | 21/05/2017 17:41:18 |
![]() 2156 forum posts | If only one chuck it is a three jaw for me, easy to hold hexagon stuff not so easy in a four jaw. Using a three jaw it is easy to make a split bush to grip across the corners of square bar so not that limited. Save up for a four jaw when you need one. |
Andrew Johnston | 21/05/2017 17:48:24 |
![]() 7061 forum posts 719 photos | In decreasing order of popularity I use: 1. Collet Chuck - 75% 2. 4-jaw independent chuck, with or without DTI - 17% 3. Small and large faceplates - 6% 4. 3-jaw self centring chuck - 2% Andrew |
bricky | 21/05/2017 18:29:01 |
627 forum posts 72 photos | I would suggest that you learn to use a 4 jaw chuck ,it will be far more versatile.If you remove work from a 3 jaw chuck it will not be accurate if you replace it,but replacing in a 4 jaw it can be clocked dead true. Frank
Neil Wyatt | 21/05/2017 18:55:54 |
![]() 19226 forum posts 749 photos 86 articles | It depends what you want to do. A 4-Jaw can do anything a 3-jaw can with potentially greater accuracy and lost more. A 3-jaw does most jobs perfectly well and is 'plug and play' - you have to learn how to use a 4-jaw reliably. Personally, I would always recommend a 3-jaw for a beginner as it is one less skill to master before you can actually start cutting metaln and getting to know your new 'companion'. The 4-jaw will come along in its own time and whether you use one or the other the most will depend on your personal preference and the sort of jobs you end up doing. Neil |
Robin Graham | 21/05/2017 20:14:32 |
1089 forum posts 345 photos | Only a hobby metal turner myself, but back in the day I would wander about University workshops waving an envelope with my latest scheme on its back. Mostly the lathes I saw were set up with 3-jaw chucks, the only times I saw 4-jaws were when there was work in them which obviously needed one. The workshop guys had to make one-off weird and wonderful things for research, and it was obviously their go-to chuck. Machines in the postgrad training shops were also equipped with 3-jaws. So my 2d worth would be to go for the 3-jaw until you actually need a 4-jaw. Though I accept that the 4-jaw is more versatile, my limited real-world experience tells me that 3-jaws are the norm for general turning. Rob.
Edited By Robin Graham on 21/05/2017 20:15:46 |
MW | 21/05/2017 20:24:54 |
![]() 2052 forum posts 56 photos | Posted by Robin Graham on 21/05/2017 20:14:32:
Agreed, the fact most lathes today are sold primarily with a 3-jaw should give that fact away. You'd be driven positively insane if you were to dial in each and every turning job on a 4 jaw. Michael W |
JasonB | 21/05/2017 21:05:15 |
![]() 25215 forum posts 3105 photos 1 articles | Has to be the 3-jaw for me, I seldom find the need to use the 4-jaw to do second ops on work to get things concentric enough. I'm sure you have all seen the number of engines I have made and they all seem to run OK so why spend half your time setting up work in a 4-jaw when a 3-jaw will do the job. Maybe others feel the need to work to 10ths or better. I only tend to use the 4-jaw when a round item is too large for my 3-jaw or of a shape that won't fit in the 3-jaw eg square, rectangular, eccentric or an odd shaped casting. I would say my usage for making models both large and small is something like: 50% 3 jaw 35% Collets 14% 4-jaw 1% Faceplate Before I got collets a couple of years ago that would have been more like 80% 3-jaw, 19% 4-jaw 1% FP |
Brian Norman | 21/05/2017 21:37:01 |
19 forum posts | Thank you all for your comments, they have been most helpful, I will probably go for the 3-jaw unless I can stretch the fund's for both! |
Martin Connelly | 22/05/2017 05:48:07 |
![]() 2549 forum posts 235 photos | If you have the option of a 3 jaw with soft jaws as well they can be very helpful for some jobs. You may not need them for a while but if you do then you may find yourself buying a second 3 jaw chuck if the first one does not have them as an option. Martin C |
mark smith 20 | 22/05/2017 09:33:52 |
682 forum posts 337 photos | I decided to use a 4 jaw independant from the start ,as i feel its something you really need to leaarn how to do. I rarely use the 3 jaw as i find i can set up the 4 jaw now in under a minute to an accuracy better than my 3 jaw gives .So dont really see setting up the 4 jaw any sort of inconvenience. Very easy using 2 chuck keys. I do spend a little more time if i need it really accurate. |
ega | 22/05/2017 09:38:20 |
2805 forum posts 219 photos | Did anyone mention that the four jaw independent may well have greater capacity than the corresponding three jaw SC? So, less temptation to overstretch the chuck. Individual usage patterns are interesting but not necessarily helpful to a beginner who may not know what he wants to do. |
Ady1 | 22/05/2017 09:53:23 |
![]() 6137 forum posts 893 photos | If I use the 4 jaw and it's just roughing down I just use the tool point.and spin the workpiece until it just touches around the circumference A DTI is really for secondary operations or tapers for me |
not done it yet | 22/05/2017 11:32:23 |
7517 forum posts 20 photos | A DTI is really for secondary operations or tapers for me
Only because you never re-chuck anything, Ady?
I would suggest that 3 jaw chucks are supplied as standard (generally) because it is convenient for those that don't know the limitations, they are cheap and t
he puchaser will likely need to get a 4 jaw independent fairly soon (extra sale) if they need to do anything other than basic turning.
My advice might be to check the individual chuck prices and go for the most expensive one to buy separately, if the price of lathe and one chuck is the same for either combination!
One might ask the question in a different way. Like... Which would you buy if you were starting again and could only have one chuck? Or ... Which is more useful - a 3 jaw or 4 jaw independent? Or... What did you start with? Or... How soon did you need another chuck? Or ... Does it make a difference whether a quick change chuck or a bolted on variety?
SillyOldDuffer | 22/05/2017 12:37:39 |
10668 forum posts 2415 photos | Posted by not done it yet on 22/05/2017 11:32:23:
... I would suggest that 3 jaw chucks are supplied as standard (generally) because it is convenient for those that don't know the limitations, they are cheap...
One small flaw in the argument perhaps. Size for size aren't 3-jaw chucks more expensive than 4-jaw chucks? They are also widely used in professional workshops by people who presumably know what they're doing. Rather than cheapness, I'd suggest that the advantages of a 3-jaw are all about speed and deskilling at the moderate expense of capacity, accuracy, and flexibility. They are just quick and easy to use. Speaking generally about the range of replies, this has turned into a revealing thread. I would never have guessed that people would have partisan views about beginner chucks! Never mind, I've picked up some useful tips (again). Dave |
Ian S C | 22/05/2017 12:41:39 |
![]() 7468 forum posts 230 photos | When I was at school in the early 1960s, for the first 2 terms in the machine shop we used only the 4 jaw independent chuck, or did our turning between centers, in the 3rd term, after we had mastered(?) the 4 jaw, we were allowed to use the 3 jaw chuck. We were using were old Harrison lathes driven from line shafting as workshops of 100 years ago would have had, although the steam engine that drove the school workshop had been replaced with an electric motor. My vote, four jaw first, then three jaw, it will take a little time at first, but with practice you'll soon speed up. Ian S C |
