Parting off 130mm Aluminium bar
petro1head06/04/2017 13:30:52
984 forum posts
207 photos
Whats the best way to part off a 130mm dia aluminium bar. Its 40mm long in case thats relevant
Edited By petro1head on 06/04/2017 13:31:09
richardandtracy06/04/2017 13:35:14
943 forum posts
10 photos
On the very few occasions I have done something of that diameter, I have 'parted off' with a band-saw and then machined the cut face to the correct length.
Richard
Emgee06/04/2017 15:00:23
2610 forum posts
312 photos
Same as Richard for me at that diameter.
Emgee
Roger Provins 206/04/2017 15:30:48
344 forum posts
Definitely a bandsaw job if I was doing it.
Neil Wyatt06/04/2017 15:36:09
19226 forum posts
749 photos
86 articles
Me? I'd ask a friend if I could use their big lathe!
petro1head06/04/2017 15:43:20
984 forum posts
207 photos
Band saw it is then
You know me Neil, I don't have any friends
Nick_G06/04/2017 16:13:16
1808 forum posts
744 photos
Posted by Neil Wyatt on 06/04/2017 15:36:09:
Is that the guy with the 'Super-super-super-super Adept' ?? laugh
Nick wink
Gordon W06/04/2017 16:44:13
2011 forum posts
I've just done a bit, half that dia. 70mm. Got the parting tool about 20mm in and chickened out, finished with hacksaw. Still not a bad result, not much cleaning up needed.
Brian Oldford06/04/2017 16:59:30
686 forum posts
18 photos
Posted by Gordon W on 06/04/2017 16:44:13:
So you never got to know the colour of adrenalin then. laugh
SillyOldDuffer06/04/2017 17:13:43
10668 forum posts
2415 photos
I had a similar problem except the aluminium was too big for my bandsaw. So I parted as deep as I could get (about 30mm) and then finished off with a hacksaw. I was wrecked afterwards. Whilst still purple and wheezing I remembered that my local metal emporium would have done the cut for a small fee...
bricky06/04/2017 19:09:00
627 forum posts
72 photos
40mm is relevent as it can't be held in the bandsaw vise.I cut some steel in the bandsaw it was 125mm*40mm long, To hold it I glued blocks of wood together that would fit my vise at 100mm and one block on top the same 100mm. these were glued together with gorilla glue after they had set overnight I glued the disc of steel to the wood with the same glue and clamped overnight.This worked and I cut several discs to make pulleys.
Frank
Chris Evans 606/04/2017 19:17:33
2156 forum posts
I also take advantage of giving the saw operators at my local stockholders a drink. I had some 45 and 50 mm EN16T to cut a couple of weeks ago. 8 pieces off each bar was worth a fiver to have cut.
Niels Abildgaard06/04/2017 21:19:04
470 forum posts
177 photos
I made a two step parting system some years ago and it parted 125 mm seawater resistant for breakfast.
http://www.homemodelenginemachinist.com/showthread.php?t=10176
Niels Abildgaard06/04/2017 21:20:01
470 forum posts
177 photos
I will learn some day
John Stevenson07/04/2017 00:47:35
5068 forum posts
Posted by bricky on 06/04/2017 19:09:00:
Frank
10mm slices being cut off 100 sprockets prior to boring for bearings.
bricky07/04/2017 07:17:08
627 forum posts
72 photos
A good set up John,but I don't have an industrial bandsaw capable of holding my chucks only a hobby saw.
Frank
Neil Wyatt07/04/2017 07:24:32
19226 forum posts
749 photos
86 articles
Posted by John Stevenson on 07/04/2017 00:47:35:
You know I'll get complaints about a picture showing the key left in a chuck cool
Jon Gibbs07/04/2017 07:30:03
750 forum posts
Posted by bricky on 07/04/2017 07:17:08:
Frank
Frank,
There are some ideas in this thread for those of us with small "capacity challenged" bandsaws which will help I think...**LINK**
HTH
Jon
richardandtracy07/04/2017 09:04:48
943 forum posts
10 photos
Frank
It's the general idea that could be useful. Do you have a drill vice & angle plate that would hold it instead? That sort of thing. Or maybe even set the clamps up on the other side of the saw blade where there is more room. There is nothing on a bandsaw that makes one side of the blade much better to use than the other except the flat saw base. And you can fix that if you wish by bolting or welding bits to the saw. In a one off case you could even knock-up a table at the right height from pallet timber and then burn it later if you are so embarrassed about using wood that you need to destroy the evidence face 7 .
Richard.
petro1head07/04/2017 09:43:54
984 forum posts
207 photos
Some interesting ideas, thanks
