Alan Waddington 2 | 16/03/2017 21:37:17 |
537 forum posts 88 photos | Would it be possible to use plastic for a lathe change gear, if so what is the best material to go for ? My old Harrison had a large fibre gear in the train, so I'm assuming there could be a suitable plastic type material that is machinable and readily available. |
Nick_G | 16/03/2017 21:55:52 |
![]() 1808 forum posts 744 photos | . Delrin.?? I posted this only yesterday. **LINK** Nick |
Alan Waddington 2 | 16/03/2017 22:15:29 |
537 forum posts 88 photos | Cheers Nick, I missed that post.....Delrin it is then
HOWARDT | 16/03/2017 22:36:48 |
1081 forum posts 39 photos | We used to use tufnol on larger dp gears or nylatron on smaller ones. |
BW | 20/03/2017 10:13:17 |
249 forum posts 40 photos | I've succesfully used Delrin.
Clive Foster | 20/03/2017 10:41:58 |
3630 forum posts 128 photos | Tufnol is excellent if you use the right grade in the correct grain orientation. Allegedly stronger and better able to cope with shock loads than delrin or nylon. But ideally needs proper attention to lubrication for long life. Delrin and nylon are, up to a point, happy run dry if kept clean. Chocolate fireguard time if you use wrong grade and / or wrong grain orientation with Tufnol. Clive. |
MW | 20/03/2017 10:58:56 |
![]() 2052 forum posts 56 photos | Posted by Clive Foster on 20/03/2017 10:41:58:
Chocolate fireguard time if you use wrong grade and / or wrong grain orientation with Tufnol. Clive. I take It this is with regards to sheet tufnol rather than the round bar? Michael W Edited By Michael-w on 20/03/2017 10:59:28 |
Russell Eberhardt | 20/03/2017 11:17:17 |
![]() 2785 forum posts 87 photos | Tufnol is surprisingly strong if the correct material is used (Woven sheet for gears, not rod which is rolled). I once had a vintage sports/racing car that used a Tufnol gear for the camshaft drive, admittedly the works racing team used a steel gear as they were not concerned with the noise but failures were very rare. However these days I would use acetal (Delrin). Russell. |
HOWARDT | 20/03/2017 12:28:45 |
1081 forum posts 39 photos | we used sheet woven tufnol |
Ian S C | 21/03/2017 11:18:19 |
![]() 7468 forum posts 230 photos | Tufnol gears are/were used to a great extent on printing presses, the ideal lubricant happened to be printing ink. Ian S C |
Muzzer | 21/03/2017 12:26:44 |
![]() 2904 forum posts 448 photos | Nylon PA46 and PA66 are widely used for gears in demanding applications like high temperature automotive actuators. May be an option depending on availability. |
John Stevenson | 21/03/2017 12:33:36 |
![]() 5068 forum posts 3 photos | One problem with the specialised plastics is locating them in small quantities at a reasonable price.
All plastics have rocketed up in price over the last few years. Tufnol used to be available for pence. I have seen works offices thrown up in a corner of the shop and sheeted in with tufnol sheet it was that cheap but now a piece of 1M x 300mm 10mm Whale Tufnol which is what is used for gears is over £100.
The cheaper grade is paper based and the dearer is fabric based. I can only assume they are using £20 notes for the paper grade and Armani for the fabric grade. |
Gordon Brown 1 | 21/03/2017 13:05:37 |
48 forum posts 2 photos | What would Tufnol rod be used for then, if not gears? I only ask as I was fortunate enough to pick up a fabric based rod for peanuts at a car boot sale and it's 76mm diameter by 512mm long, so fairly big. Been looking for use for it since I bought it! |
Muzzer | 21/03/2017 13:14:09 |
![]() 2904 forum posts 448 photos | Good for electrically insulating standoffs, knobs, handles and anything that doesn't need to be metallic. Rather like wood but without quite the same directional weakness. Machines nicely and polishes up with a bit of oil to show the colour textures. The phenolic smell isn't entirely pleasant but it's not particularly hazardous. |
Michael Gilligan | 21/03/2017 13:31:39 |
![]() 23121 forum posts 1360 photos | Posted by Gordon Brown 1 on 21/03/2017 13:05:37:
What would Tufnol rod be used for then, if not gears? . Further to Muzzer's suggestions: Bearings MichaelG. |
Neil Wyatt | 21/03/2017 13:40:22 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Gordon Brown 1 on 21/03/2017 13:05:37:
What would Tufnol rod be used for then, if not gears? I only ask as I was fortunate enough to pick up a fabric based rod for peanuts at a car boot sale and it's 76mm diameter by 512mm long, so fairly big. Been looking for use for it since I bought it! The rod is made by rolling up a sheet of paper or cloth in the resin, before hardening it. This means the layers are like the rings of a tree, so a gear will have the weak direction (between the layers) running across the teeth, making it easy to lose teeth. Gears made from flat sheets have the weak layers aligned so they only have to cope with forces trying to 'spilt' the gear - an unlikely situation in normal use.
Gordon Brown 1 | 21/03/2017 14:33:14 |
48 forum posts 2 photos | Thanks for the replies guys, I had worked out the strength issue with making gears from rod, which is why it is still sitting on my shelf, sooner or later I'll be making something and realise that I can use it. Until then I suppose it will just have to lie there and stare at me! I did think of selling it but you know how it is, sell something like that and the following week it's just what you needed... |
Jon Gibbs | 21/03/2017 14:48:00 |
750 forum posts | I've not used them before but small quantities are available here... HTH Jon |
Gordon Brown 1 | 21/03/2017 15:01:59 |
48 forum posts 2 photos | Strewth! That chunk of Tufnol sitting on my shelf would cost somewhere north of £200 to replace! |
Kettrinboy | 21/03/2017 18:00:43 |
94 forum posts 49 photos | I have several nylon gears in my Harrison L5 changegear set and when i needed one of them for cutting the thread in the backplate for a new chuck I was a bit worried if it would stand the load from cutting a 1.5 " X 6 TPI thread in cast iron but it did it fine , dont know if it would have done it if it had been a tufnol gear though , and a bonus is the geartrain runs a lot quieter with a plastic gear in it because as anybody with a Harrison knows the steel gears can ring a quite a bit at higher speeds. regards Geoff Edited By Kettrinboy on 21/03/2017 18:03:38 |
